Question about Linksys Computers & Internet
Where do i find my pass word as requested when setting new wireless router
    President:
  • 2,559 Answers
You set it up your self The default is Username empty box(leave it blank) and the password is Admin
Posted on Jul 29, 2009
Setting a password to my wireless router
just click on your wireless setting at the bottom right of your computer it might be under hidden click on to your wireless settings in there it says set your security pass word put a pass word in and remember it and thats it
Dec 13, 2011 | Linksys Wireless-G WRT54G Router
Pass
It seems that you're requesting the password for your Linksys Wireless-G WRT54G router. You should be able to connect to it by going to http://192.168.1.1 in your browser, then using "admin" as the user name and "admin" as the password (both without quotation marks).
Sep 15, 2011 | Linksys Wireless-G WRT54G Router
Hi I am receiving a message "unable to find a
The router can have several different "methods" for making a connection.
You must have configured your computer to ask for a certificate from the router,
but you probably have NOT configured your router to hand-out a certificate.
Reconfigure the router, to use 'WPA' or 'WPA2' method, and set a pass-phrase or a password,
and reconfigure your computer to request a 'WPA' connection, and the request for "certificates" will vanish.
Jun 01, 2011 | D-Link Wireless N 150 Home Router 4Port...
How do I retrieve my router password so I can connect to my Blu-ray and my wireless. When setting up my blu-ray to work with my wireless it will not let me connect....it is requesting a password
hold in the reset switch on the router until it flashes and the router resets to its default user and pass which are
username: leave blank
password: admin
May 12, 2011 | Linksys Wireless-G WRT54G Router
I have new comp. forgot password for wireless router
it is too involed to find the pass word and user name if it has been assigend one prvious siply unplug the router or the small button wich will reste the router do a Google search for default pass word some older ones usually is admin with no password or admin admin once you reset the router you go back and reset all of the settings these setting are how the modem and your i.s.p talks to each other the addtional settings are security for the wireless setting they are set up by you and match to the setting on the wireless device you can do a Google search on wireless security addtionally if you have torrent programs and games or some program that needs a open port to access the internet look up port forwarding
Jun 29, 2010 | Linksys Wireless-G WRT54G Router
Find pass key for our lap top for the family network.
Log into your router's web interface, if possible through a computer connected to the router by cable, by starting an internet browser and navigatng to its maintenance IP address, usually set by many manufacturers to 192.168.0.1 or 192.168.1.1. An authentication request will come up. As you haven't speciffied your router model, there are routers whose both user name and password fields are set to 'admin'. Other routers use 'admin' as user name only, requiring the password field to be left empty. Once you get into the router's web interface, go to the wireless settings, and change the wireless passphrase to a new one of your choice. Make sure to change the other devices, which use to connect to the router, to the same new passphrase.
If you need further details, please, provide your router model and manufacturer.
Hope you are able to sort your problems out.
Regards, Carlos
May 22, 2010 | Computers & Internet
I cannot set WPA under Windows XP... help please...
WPA usually has two formats for encryption. They are TKIP and AES.
Please make sure you get the right type of encryption from your router, the correct SSID for your wireless network and the correct WPA pass code.
In Windows XP, you need to go to
Start/Control Panel/Network Connections
Double click on your Wireless Adapter
Enable it if it requests for you to Enable it
If not, then a window will appear showing you your Wireless Adapter
Click on Wireless Connections
Select the appropriate SSID that you're working with in your Preferred Networks list
Click Properties, then a new window will appear
This window will show you the properties of this particular SSID
Here you can set your pass code and the type of security you've got set up in your router. Since it is WPA then you can select WPA from the drop down box and then select either TKIP or AES.
Make sure you've got the right settings selected to match your router. Or else you will not be able to communicate between your computer and your router.
Hope this helps. Don't forget to vote for me. Let me know how you made out.
Mar 19, 2010 | U.S. Robotics USR5416 (DHUSR5416)...
Hi i hope you can help me i nead to know how to reset the pass word for a linksys wireless n broadband router model wrt160n v2 my laptop had a virrious and i lost everything i do not remember the pass word...
Ok, on the bottom of the router there is a reset button you need something small to push in. Once you press this the router will go back to fatory settings and you can set it up again with a new password and settings.
Nov 05, 2009 | Linksys WRT160N Wireless Router
Need to retrieve pass word
If you have a new router, try accessing your router configuration page and set a new wireless network name and a new wireless password.
Jan 30, 2009 | D-Link 802.11g Wireless Router WBR-1310...
New Modem with a router for wireless Laptop
Some routers have a kind of built in firewall. You need to let the router/modem that it is okay for it to let this information pass through it. Here are your instructions
Overview
Follow the steps in this chapter and use the Gateway’s web-based utility to configure the Gateway. This chapter
will describe each web page in the Utility and each page’s key functions. The utility can be accessed via your web
browser through use of a computer connected to the Gateway. For a basic network setup, most users only have to
use the following screens of the Utility:
• Setup. On the Setup screen, enter the settings provided by your ISP.
• Security. Click the Administration tab and then the Security tab. The Gateway’s default username and
password is admin. To secure the Gateway, change the Password from its default.
There are seven main tabs: Setup, Wireless, Security, Access Restrictions, Applications & Gaming, Administration,
and Status. Additional tabs will be available after you click one of the main tabs.
Setup
• Setup. Enter the Internet connection settings on this screen.
Wireless
• Basic Wireless Settings. You can choose your wireless network settings on this screen.
• Wireless Security. This screen allows you to choose your wireless security mode.
• Wireless Network Access. This screen displays your wireless network access list.
• Advanced Wireless Settings. On this screen you can access the advanced wireless features.
• WDS. The wireless distribution system feature is accessed on this screen.
Security
• Firewall. This screen contains filters and the Block WAN Requests feature. Filters block specific internal users
from accessing the Internet and block anonymous Internet requests.
• VPN Passthrough. To enable or disable IPSec and/or PPTP Passthrough, use this screen.
Jan 20, 2009 | Linksys Computers & Internet
Computers & Internet Logo
327 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
