Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Rear wheel removal from craftman riding mower
The axle doesnt have an e clip, its a completely round except for a small groove in it. i used a flat head screw driver and a hammer and tried spinning it but its not working any ideas???
    Genius:
  • 1,114 Answers
Do you have the rim and tire off and you want to remove the hub?
I believe every rider mower and tractor I've had and worked on had the rear tire attached to the hub as in a car, with lug nuts or lug bolts. Check to see if there are four or five lug bolts that hold the rim onto the hub.
Posted on Jul 29, 2009
How to remove the front tire from a bolens lawn tractor?
Usually there is a spring clip on the axle. These little clips fit in a groove on the axle and are not very noticable. Look up circle clip. A screw driver (fairly large for a mower) can be used to slide them away from the axle. You may have to pull (tap) the wheel to get it off the axle as the last bit of axle sometimes develops some rust and the wheel does not want to slide off freely.
Sep 04, 2014 | Garden
How do I take off the back tire? It has blown
To take off the rear wheel, you are going to need to remove the rubber boot. You can pull it off with a set of pliers. Then see what is holding the wheel on, it could be an E-clip or an external snap ring. To remove the E-clip use a straight screwdriver under the clip and rotate it to loosen. Then pull off the washer(s). The wheel will slide straight off, watch for the key, that is the metal piece that goes into the groove that locks the wheel and axle together for rotation. The external snap ring requires a snap ring pliers.
I hope this gets you going.
Aug 01, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I purchased a older MTD 12 HP lawn tractor. How do I remove the rear wheels in order to replace the tires? Do I need a special tool. I can not see anything to put a wrench to.
theres a screw and a bell washer in the center of the rear wheel , maybe covered by a cap, check this link for a breakdown on that machine as its what I located with the specs you gave http://www.searspartsdirect.com/partsdirect/part-model/Mtd-Parts/Riding-mower-tractor-Parts/Model-33925A/0736/1509200/WL000275/00009
http://c.searspartsdirect.com/lis_png/PLDM/WL000275-00009.png thats the rear wheels diagram
Jul 11, 2011 | Garden
I own a Sears Yard Machine riding mower and the rear tires are flat and I'm trying to remove the tire and take it to tire dealer to check for leaks and plug. My problem is HOW TO REMOVE THE REAR...
there is a cap over the end of the axle, it snaps off. with the rear end jacked in the air remove the C-clip which you find under the cap. the wheels will then pull off. make sure you put them back on correctly, there is an inside and an outside. If you reverse it, you will rub a groove in the tire and it will go flat and have to be replaced and they cost more than car tires. And do not pull the wheel off in the lawn or in a gravel driveway. when the wheel comes off a small key will fall to the ground. you will need to re-install this key when you put it back together or the wheels will not move. if you lose the key into the grass or gravel you will have to go to a real hardware store or small engine repair shop to buy another.
May 24, 2011 | Yard Machines Garden
Changed the tire on my craftman lawn mower and now it will not drive
there is a key keeping the wheel and axle in sync. make sure this did not fall to the ground when you removed the wheel. fits in the slot on axle and wheel. if you lost it you can buy another at a small engine parts store. another possible problem is that you slid the wheel on backwards and it is rubbing against the mower frame.
Aug 22, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Looking for a front axle for a craftman 19.5 briggs and stratton 42" deck green color model do not have the model # also does anyone know if the wheels come off the axle or is it one unit
The wheels usually have a rubber cover in the center, remove that and there is an e-clip that can be removed with a flat blade screw driver, or pliers. The axle beam, spindles and wheels can all be serviced separately.
Jul 01, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How do you remove front or rear wheel on craftman riding mower.model #917.270921
You should find little clips holding them in place. Take a screwdriver and find where the hoop (clip) has a notch in it and put pressure against it...it should pop out (wear eye safety gear). Once clip is off....tire will pull off www.nnyparts.com
May 27, 2010 | Craftsman Garden
Getting Rear Wheel Off A Sraes Craftsman Riding
pull off plastic axle cover in the center of the wheel, remove large e-clip seen on the end with small screwdriver and large washer. take care not to let it fly off somewhere. lift tractor with a jack, pull off wheel then note the location of the square shear pin and save it for reverse assembly
Apr 16, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
How do i remove left rear wheel to replace tire on craftman riding mower model 917272140
First Raise the mower and set the draw bar on a block or jackstand or something. Now pull off the black plastic cap it might be harden from age so pliers will help here. Now take a screw driver and stick it in that small grove in that E-clip and turn the handle to prize off the E-clip. Now remove the large washer there may be two. Pull and rock that tire back and forth there is a steel keyway in the axle. It all could be rusty so spray it with oil and use a hammer on the back side if needed.
Jul 26, 2009 | Garden
I cannot get the rear wheel off the tractor. Question... the ''square key''... I thought mine was missing & secured another one, but WHAT DO I DO WITH THE SQUARE KEY ? Is the original still in the hub part...
Here is what my manual says. It is for a 14 hp 42" mower deck. 6 sped transaxle.
Block up axle securely.
Remove axle cap, retaining ring and washer to allow wheel removal (rear wheel contains a square key. Do not lose).
Repair the tire and reassemble.
On rear wheels only: align grooves in rear wheel hub and axle. Insert square key.
replace washers and snap retaining ring securely in axle groove.
Replace axle cap.
If you send me your email address I can send you a picture as I do not know how to post pictures on here yet.
Apr 24, 2009 | Craftsman Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
558 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
