Car Audio & Video Logo
J
James Montana Posted on Oct 12, 2017
No voltage on 5 amp fuse for radio signal / 04 F 150 am/fm radio, no disc player.
5 Related Answers
Anonymous
  • 129 Answers
  • Posted on Mar 10, 2008
SOURCE: No AM or FM yet cd player works
Friend,
Maybe, there is a problem from the detector of you radio function to the amplifier. Try to check on it first or try resoldering from the detector section
jason
  • 905 Answers
  • Posted on Oct 06, 2008
SOURCE: FM Radio doesn't work
it may be that the fm detector has failed or possibly a tank(tunning coil)
Anonymous
  • Posted on Jan 30, 2009
SOURCE: 2005 dodge caravan rbq am-fm radio w/6 disc cd changer
Contacted local dodge dealer about my in dash 6-disc changer problem. Chrysler seems to have an "exchange" program. They will remove your existing radio, install a "factory reconditioned" unit and send yours in to be repaired and sold to someone else. The dealer told me that my CD's would EVENTUALLY be returned to me from Chrysler. The cost I was given was $265 plus sales tax for the exchange unit, and the labor to remove and reinstall. He said about a half hour labor. Compare this to the $604 for a factory new unit. Hope this helps everyone with this problem. I was told by the Service advisor that it is common for this problem.
Anonymous
  • 156 Answers
  • Posted on Feb 24, 2009
SOURCE: Navagation radio with 6 disc player in dash, cd
Have you tried running a cleaning device through it? The case may be that the laser that actually read the disc is either stuck in place or it has burnt out on it. That's if the cleaning doesn't work.
Anonymous
  • 607 Answers
  • Posted on Apr 06, 2009
SOURCE: !994 Park Avenue FM radio reception poor. AM signal OK
Check antenna connections at radio and antenna assy.. Poor connections will only receive AM and hardly any FM
2answers
I have an 04 Saturn Vue. My radio turns has power, CD player works but I cannot get any sound. Other day when I was driving the speakers got all staticky and then sound went out. I check the 3 fuses and...
What system does it have ? Base or up level ,does it have a amp ? Do you know what a RPO code is ? Without testing no one could say for sure what the issue is . First off would need to know what system we are dealing with .
RPO Options
The entertainment system on this vehicle is configured with either a base or uplevel audio system. Both the base and uplevel audio systems contain a radio, antenna, and speakers.
The following shows the Enteratinment RPOs that are available for this vehicle:
• (UM7) AM/FM Stereo
• (U1C) AM/FM Stereo CD
• (US8) AM/FM Stereo, CD, MP3, RDS, EQ
• (US9) AM/FM Stereo, 6-Disc CD, MP3, RDS, EQ
• (UXQ4) Base Four Speaker
• (U79) Uplevel Four Speaker
• (WBM) Premium Audio
• (U2K) Digital Radio
Circuit Operation
Radio Power: The main radio power is supplied by the 10A RADIO (BATT1) fuse in the body control module (BCM). Radio switch-on power, 12 volts in ACC, RUN or RAP, is supplied by the 10A RADIO (ACC.) in the BCM.
Radio Grounds: The main radio ground provides a ground for the radio circuits. An additional braided ground strap provides a shielding radio case ground to reduce EMI noise. Both grounds are connected together inside the radio.
Radio Speaker Outputs: At zero volume, the plus (+) and minus (-) speaker outputs are both approximately 5-6 volts, measured to vehicle ground. If a plus or minus for any speaker output is shorted to ground or voltage, the radio circuitry will turn OFF all 4 speaker outputs for component protection. Above zero volume, the plus and minus change to create a voltage difference between each other, to drive the voice coil of the speaker.
Radio Park Lamp Input: The radio park lamp input allows the radio to sense when the vehicle parking lamps are ON. When the parking lamps are ON, this circuit goes to battery voltage, and the radio display back-lighting switches from full bright to the brightness level determined by the I/P illumination input.
Radio I/P Illumination Input: A pulse width modulated (PWM) voltage for instrument panel (I/P) illumination is provided to the radio I/P illumination input. The Radio uses this input to directly illuminate the radio buttons and adjust the radio display back-lighting when the park lamp input is ON.
Amplifier Power: The main amplifier power is provided by the 20A PREM AUDIO fuse in the instrument panel fuse block..
Amplifier Radio Speaker Inputs (WBM only): The radio speaker outputs, at a reduced output level for amplified systems, are the amplifier inputs. The amplifier boosts these inputs and outputs them to the vehicle speakers. Speaker plus and minus circuits from the radio change to create a voltage difference between each other. If one speaker plus or minus is open between the radio and the amplifier, the input to the amplifier is approximately half because only one of the circuits is changing. The speaker for that channel then operates at approximately only half the normal volume.
Amplifier Speaker Outputs (WBM only): At zero volume, the plus (+) and minus (-) speaker outputs are both approximately 5-6 volts, measured to vehicle ground. If a plus or minus for any speaker output is shorted to ground or voltage, the amplifier circuitry will turn OFF either the front outputs or rear outputs for component protection. Above zero volume, the plus and minus change to create a voltage difference between each other, to drive the voice coil of the speaker.
Amplifier Radio-On (WBM only): When the radio is ON, this circuit is pulled to 12 volts by the radio. The amplifier switches ON when this circuit is 12 volts and switches OFF when this signal is 0 volts.
Remote Radio Audio Signal Inputs (UE1 only): Audio output from the OnStar® communications module connects to the remote audio signal inputs of the radio. When the cellular telephone mute signal goes to 0 volts, the radio over-rides any other audio signal and uses these inputs as the source for output to the speakers.
Cellular Telephone Mute (UE1 only): The OnStar® communications module uses the cellular telephone mute signal circuit to over-ride the radio for OnStar® communication. When cellular telephone mute is not active, this circuit is held at 2 volts by the radio. When the cellular telephone mute signal is pulled to ground, the radio over-rides any other audio signal and uses the remote audio signals as the source for output to the speakers. If the radio was OFF when this circuit is pulled low, the radio will turn ON. Additionally, the radio fades the speakers to full front, adjusts the volume to an initial audible level, and sets an AutoTone designed for optimal use with OnStar®. When the mute signal is no longer pulled to ground, the radio returns to the mode it was in previously.
Hooking up a professional or factory scan tool that can read radio codes would be one of the first test's to do .
DTC B1025, B1035, B1045, or B1055 (w/out RPO WBM)
DTC B1025, B1035, B1045, or B1055 (w/ RPO WBM)
DTC B1030, B1040, B1050, or B1060 (w/ out RPO WBM)
DTC B1030, B1040, B1050, or B1060 (w/ RPO WBM)
DTC B1259
The following conditions are present for 250 ms or longer:
B1025 - B1055 01
One of the speaker positive output circuits is shorted to battery.
B1025 - B1055 02
The speaker positive output circuit is shorted to ground.
B1025 - B1055 04
The speaker positive output circuit is open.
Your best bet , take it to a qualified repair shop .
1helpful
2answers
Lost sound on 2005 impala. radio works. seems like amp problem.
Do you have base or up;level system ?
Table 1: Radio Features
Table 2: Cassette Features
Table 3: Compact Disc Features
Table 4: XM Advisory Messages
The radio receives power from the RADIO fuse in the junction block-right I/P. Ground is provided via G201 and G202. The radio is enabled/disabled by class 2 messages from the body control module (BCM). The radio routes audio signals from the digital radio receiver or the vehicle communication interface module (VCIM) to the speakers and/or amplifier when directed by class 2 messages.
The Entertainment System on this vehicle is configured with an AM/FM stereo radio with the radio data system (RDS) and either a cassette player or a CD player or both. CD and cassette. The uplevel system provides the customer with extended range speakers and an audio amplifier. Satellite digital radio (U2K) is available with uplevel systems.
The following list shows the radios available for this vehicle:
• Radio (ULO) - AM/FM Stereo, Cassette with RDS
• Radio (UNO) - AM/FM Stereo, CD and RDS
• Radio (UPO) - AM/FM Stereo, Cassette with CD and RDS .The complexity of the radio systems on these vehicle is mind blowing .
Your best bet take it to a GM dealer , has features you are unawear of .
When the radio is powered up, the radio supplies low level audio signals to the speakers. If the vehicle is equipped with an audio amplifier, the amplifier will boost the signal sent to the speakers.
DTC B1025 Audio Output Circuit
Install a scan tool.
Turn ON the ignition, with the engine OFF.
With the scan tool, monitor the DTC Information for DTC B1025.
Does the scan tool indicate that DTC B1025 is current?
I'm looking for the part number for the power supply for the RCA RS22162 5 disc CD player
I haven't been able to find much about this particular model. I take it that you don't have the original power adapter, because it's usually labeled on the black box what the voltage should be. My only other suggestion is to look on the back of the amplifier. there is usually a label next to there the plug goes into the amp that will say what the input voltage should be.
Best of luck
2answers
I have a 1996 Nissan Maxima with a factory Bose CD player / cassette and radio and it will not turn on what's the solution
Maxima Bose Radio ' eBay
www.ebay.com/bhp/maxima-bose-radio
eBay1995 1996 1999 Nissan Maxima Pathfinder Infiniti J30 Radio BOSE CD tape Player ...Will fit and work in these with BOSE audio package only:1995 - 1999 NISSAN .... 2006Nissan Maxima OEM Bose Cassette & 6 Disc CD Player Radio CR13B ...DESCRIPTION Unit is missing some bottons, 3 of them, this item has NOT ...
Nissan Maxima Bose Stereo ' eBay
www.ebay.com/bhp/nissan-maxima-bose-stereo
eBayWill fit and work in these with BOSE audio package only:1995 - 1999 ... 1996 - 2000 NISSAN Pathfinder. 2004 2005 2006 NISSAN MAXIMA FACTORY BOSE STEREO 6 DISC ... Factory NISSAN INFINITI BOSE Radio, Tape, and CD Player. ... 6 Disc AM FM Stereo Cassette Radio Bose OEM LKQ (Fits: Nissan Maxima).
Nissan Maxima Car Stereo Removal and Repair - YouTube
? 8:52
https://www.youtube.com/watch?v=RT-SZEfeA4Q
Sep 16, 2012 - Uploaded by Factory Car Stereo Repair
Factory Car Stereo Repair .... I have nissan maximal 05..the CD part turns on but the cd won't eject...should ... I have a 2005maxima non-bose radio system. ... my speakers is super in my 05 maxima but my cd player keeps on ...
Nissan - Factory Car Stereo Repair
How to change fm channels
The Sony CDP-CE375 is a CD player, not a radio. It doesn't have any FM channels.
If you're asking about some other device, please specify the make and model.
I was attempting to install a new stereo in my 2000 taurus. it requires to an adapter to put the new stereo in. i got the new adapter and stereo in *kinda* but decided i didnt really know what i was...
check your fuses first. You may have blown one.
Visual Inspection Chart Mechanical Electrical
  • Integrated control panel (ICP) physically damaged, misaligned, any control(s) inoperative
  • Digital audio compact disc player physically damaged, misaligned, any control(s) inoperative
  • Antenna or antenna cable physically damaged, misaligned connection(s)
  • Radio speakers, mounting/speaker cones physically damaged, misaligned
  • Radio ignition interference capacitors, radio frequency interference suppression bond misaligned (also check for cleanliness and metal-to-metal contact)
  • Battery junction box (BJB) fuses F127 (5A), F117 (20A), F127 (5A).
  • Central junction box (CJB) fuse F227 (10A) F211 (15A), F216 (15A), F226 (10A) (wagon only)
  1. If the fault is not visually evident, proceed to diagnose the integrated control panel (ICP) by entering the ICP Self-Diagnostic Mode.
NOTE: To enter the ICP Self-Diagnostic Mode, the ICP must be ON and in radio tuner mode (AM/FM).
  1. Enter the diagnostic mode by pressing and holding preset buttons 3 and 6 simultaneously. This will suspend all radio functions, and display SP.
  1. Preset Button 1 = Audio internal/external SELF TEST. The display will flash SELF while gathering the diagnostic trouble codes (DTCs), then stop flashing when complete. Press the TUNE UP button to display the DTCs if any exist. Record codes and refer to the following table:
ICP SELF-TEST CODES Code Description 0 No diagnostic trouble codes logged 1 No response from rear chassis unit (RCU) 2 No response from cassette player 3 - 4 No response from compact disc player 5 - 6 - 7 No response from remote climate control 8 - 9 Read Only Memory Verification failed
  1. Preset Button 2 = Displays the feature strap for code identification, refer to the following table.
Code Description 01 Base-Electronic Search Radio (ESR) with Manual Climate Control (MCC) 07 Electronic Search Radio with Cassette (ESC) with MCC 17 ESC with Electronic Automatic Temperature Control (EATC) 97 Not programmed default of ESC with EATC
  1. Preset Button 3 = ICP and RCU identification. This test identifies the software level of the ICP and RCU. The ICP is tested first, followed by the RCU. The display will have two sequences of three codes each. The first sequence is for the ICP, the second sequence is for the RCU. For code identification, refer to the following table:
Item Part Number Description 1 - Product variant code 2 - Tape model 3 - CDR
SOFTWARE IDENTIFICATION CODES Product Type Code Description Product Variant Code Description 21 ICP 07
08
09
10
11
12 EATC with AM/FM, cassette player and CD changer
EATC with AM/FM and cassette player
Manual A/C with AM/FM and cassette player
EATC with AM/FM cassette player and CD changer 31 RCU 01
02
03 Analog
Digital
Midline 71 Remote climate control 01 LH drive 52 Compact disc/disc jockey 01
02
03
04 Sony® 10 disc
Sony® 6 disc
Clarion® 6 disc
FMS 6 disc
3answers
How to fix fm japan radio to recieve GCC fm signals ?
You can get a converter like this one.
http://catronics.com.au/fmconverter.html
It's a simple solution and it works.
5helpful
5answers
My radio on my82 honda goldwing dont have sound
there are 3 fuses behind left turn signal with holders that open like a clamshell. one of these is for the amp, its a 15 amp fuse i believe
Top AMP Car Audio & Video Experts
littlewheel
Steve Sweetleaf
Steve Sweetleaf
Alexander
Are you an AMP Car Audio and Video Expert? Answer questions, earn points and help others
