It's a general code for some electrical system problem. Ours flashes "SUD" before while the machine is on before flashing "F35" when it stops. I've tracked this done to being a problem with the pressure sensor switch in ours, and it appears to be either from obstruction from too many suds (like using the wrong detergent), or an actual sensor problem. I followed online advice to pull the tube and blow back to clear any suds out, and that cleared it for one cycle, but then the problem came back, so I'm either going to try some other things to clear before calling for a service person to replace the sensor. The part is W10156252 Switch, Analog Pressure Sensor, number 20 of the washer parts diagram.
Hello & Welcome to FixYa
F35 error means that there is some sort of issue
with the steamer electronic board and analog pressure sensor has gone bad.
Check that the hose is firmly attached with the washer and is not blocked. You
can also check the water level pressure switch operation. Please get back to me
if you have any other questions.
Kevin
