Question about Dyson Vacuums
I have a Dyson Airmuscle DC28. when doing carpet beater bar shuts off and red on button flashes Acts like too much vacuum. Took prefilter out and works fine. Sucks down to the floor. Help.
Filter is dry and no obstructions. Take out works fine. Put back in fails.
  • Dyson Master
  • 1,546 Answers
This usually indicates a brush roll problem which could be caused by a bad pub, wire loom, or the cleaner head assembly. I recommend you have it checked at your local Dyson repair facility to determine the problem.
Posted on Oct 14, 2017
3 Suggested Answers
SOURCE: I have a dyson DC28
I had the same symptom with my wife's DC28. The problem was associated with the cam driven height adjustment mechanism. The beater bar must rock freely up and down when pressing on the tabs that the end cam lobes actuate. On ours I found hair and crud jammed in between the end of the beater bar and the side of the vacuum head preventing it from moving freely. To clean it out I fashioned a hook tool by straightening a paper clip and bending the tip at 90*, then took a flat screwdriver to pry the gap open a bit so I could use my tool to clean out the buildup.
I removed the plate that holds the cam in place (6 torx screws) to gain access to the rocker tabs, although in hind sight I could have probably just left it in place. It doesn't matter how you set the cam back into place. It's self aligning with the aid of the micro-switches inside.
Hope this helps
Posted on Nov 27, 2011
small6363
  • 18425 Answers
SOURCE: dc28 beater bar does not spin
this link is for manual check belt is ok
http://media.dyson.com/downloads/US/floorcare/Manuals/dc28_opmanual_usa.pdf
Posted on Nov 14, 2012
How do I adjust height for carpet brush on DC28 Dyson animal?
Hi Laura, it's Jack at Dyson
DC28's selector pad (located by the red on/off switch) allows you to select the correct height setting for the particular flooring you're cleaning. Patented Dyson Airmuscle technology will then raise or lower the rotating brush bar within the cleaner head to the correct level for optimum performance, or shut it off for cleaning bare floors or delicate rugs.
I hope this helps, but if you have any further questions or if you're having difficulty with your DC28, you're welcome to get in touch directly. You can reach our experts by emailing askdysonUS@dyson.com
Mar 01, 2015 | Dyson Vacuums
So the beater bar on our dyson DC28 animals to starts to turn then stops. Is there a video or schematic break down out there? Would like for reference for dismantle and rebuild. Thx, Mike
The beater bar on his machine and other dysons dc01,dc07,dc14 is directly driven by the main vacuum motor via a rubber belt(some models have safety clutches). There are no reset switches- the three tabs on the base are to allow removal of the sole plate. If something jams in the beater while operating and left for long enough (about 1 minute) the belt can burn out and need replacement. the belts are cheap, good skill is required to remove the sole plate to install a new belt because they are so tight.
Dec 20, 2014 | Dyson DC28 Animal Bagless Upright Vacuum
Dyson airmuscle
Hi there, it's Jack at Dyson.
I'm glad to hear your Dyson DC28 Airmuscle vacuum has worked so well for you for 5 years, but I'm sorry to hear you're now having difficulty reclining the machine.
It's possible this could occur if an item such as a pen or pencil has been accidentally vacuumed up, and is jamming the changeover valve mechanism. This is easy to check for - after turning off and unplugging the vacuum, lie the machine on its side and open the duct inspection port, then remove any objects or debris:
If you can't find anything, but continue to experience difficulty reclining your vacuum, please get in touch with our experts directly so we can provide further assistance. You can reach us on 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Aug 26, 2014 | Dyson DC28 Animal Vacuum with Airmuscle...
White carpet height buttons flash
DC28's carpet height buttons will flash to let you know if you have the carpet height set too low for effective cleaning. Raising the brush bar to the next available height on the selector pad should resolve this.
If you'd like further advice from our experts after giving this a try, please give us a call on 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Jul 17, 2014 | Dyson DC28 Animal HEPA Bagless Upright...
Also te red light is blinking on my dc 28 animal vacuum
Hi Judi, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your DC28. If the red on/off is flashing, this indicates that something may be jamming the brush bar. To resolve this, please follow the steps shown in the video attached. Make sure there are no obstructions in the cleaner head, and carefully remove any threads or hair from around the brush bar.
You may also want to try raising the brush bar one setting higher using the hight selector pad, as the brush bar will shut itself off if you have it set too low for the carpet pile you're cleaning.
If you'd like some further help after you've given this a try, please email us directly at askdysonUS@dyson.com with your contact details. One of our experts will be in touch as soon as possible to run you through some further troubleshooting.
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Apr 17, 2013 | Dyson DC28 Animal Bagless Upright Vacuum
I just bought a brand new Dyson DC28 and
If you can, check the latest Consumer Reports buying guide for guidance.
Sep 11, 2012 | Dyson DC28 Animal Airmuscle Vacuum Cleaner
I have a brand new Dyson DC28 Airmuscle Vacuumand it is so hard to push and/or pull. Is there a button to make it easier or is it the machine?
Your DC28 is equipped with Airmuscle™ technology, which allows you to raise or lower the brushbar to suit the flooring you're trying to clean. You should be able to make your DC28 easier to push by changing the setting of the carpet height selector. You can find out how to adjust this in the user guide included with the cleaner. In case you don't have yours to hand, here's an online copy:
By raising the brushbar, you should be able to reduce the force needed to push and pull the cleaner. If you've tried this, it may simply be the powerful suction which is making it feel a little heavy to use.
If you're still concerned, please get in touch with us free on 1866MYDYSON or email askdysonUS@dyson.com. One of our experts will be happy to answer your questions.
Kind regards,
Jack
Dyson Customer Service
Jul 23, 2011 | Dyson DC28 Animal Bagless Upright Vacuum
I have a dyson DC28 vacuum and the power button flashes on and off and the beater bar quit turning. I turned it over and found some string caught on the beater bar which I removed, but the beater bar still...
Hope this helps
Mar 15, 2011 | Dyson DC28 Animal Bagless Upright Vacuum
My dyson dc17 will not roll across the carpet, because their is too much suction.?
Turn on the beater bar with the gray button next to the red power button. The powered beater bar will "propel" the vacuum across the carpet.
May 02, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Vacuums Logo
44 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
