Question about Hoover Washing Machines
Hoover Gemini not taking water when gets to prewash cycle
miket756
  • 2702 Answers
SOURCE: dishwasher stays on prewash cycle
this could be one of the water valves not working (not opening)
Posted on Oct 20, 2009
  • 35 Answers
SOURCE: Hello My gemini top burners cycle on and off,
The burners are designed to cycle on and off, it is technology that helps to keep from burning food. If you are using the correct pan to burner size ratio and high setting on your burner, the water should boil in the normal time. Don't watch the pot (just kidding)
Posted on Dec 01, 2009
Testimonial: "Thought that might be true. I will look into sizing my pots and pans to fit burners more correctly. Thanks for the help and the little bit of humor."
  • 176 Answers
SOURCE: Kenmore 17373 dihwasher overfills on prewash cycle
it is posible to have a presostat(presure gauge) for prewash and this is damaged(bloked) and another for wash, this may be positioned on a main board or in another place. i don't thick you wil fix this problem whit out the qualified personel. also can beanother problem and for this you must call an specialist.
Posted on Feb 14, 2010
blueextc3221
  • 15935 Answers
SOURCE: Prewash light starts flashing when drum full of water
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
FitzOriginal
  • 842 Answers
SOURCE: prewash valve won't shut off,getting
Almost certainly the fill sensor is faulty (Little round device with a plastic pipe coming off the bottom). You may find that simply pulling off the tube, blowing down it and then re-fitting it fixes the problem. If not, you may have to replace the sensor
Posted on Jul 01, 2011
Hoover gemini washing machine
Has it pumped ALL the water out when it's time too spin
Jun 07, 2013 | Washing Machines
My Asko Front load washer model W6021 Prewash
hi you need to replace the inlet valve,take off the top panel and you will see the valve behind the soap drawer with the black hoses.you can get a book from asko.com.au
Jun 15, 2010 | Asko W6021 Front Load Washer
Kenmore 17373 dihwasher overfills on prewash cycle only. I can turn off the water supply on the prewash, wait for the cycle to complete and drain. Then turn the water back on, and it runs fine for the rest...
Feb 14, 2010 | Kenmore 24 in. 17372 / 17374 / 17379...
Nov 30, 2009 | Maytag Gemini 30" Self-Cleaning...
P801front load washer
put on prewash cycle. note which tray water enters and that is the prewash tray.
put on wash cycle which has no prewash. note which tray water enters and that is main wash tray. remaining tray is rinse
Sep 06, 2008 | Samsung WF337AA Front Load Washer
Prewash always flashing
yes i had a similar problem the prewash light kept coming on mid wash cycle and eventually stopped taking in the water just bypassing it straight to outlet without filling machine. i found if you remove the pump at the rear of machine and disconnect hoses there was a build of lets say deposits leading to a sensor through a opaque plastic connector to the top of machine . after cleaning the hoses thoroughly and removing all the crud machine worked as it should do, hope this helps
Jun 06, 2006 | Hotpoint Aquarius WF210 Front Load Washer
Washing Machines Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
