Question about HP OfficeJet 7110 All-In-One Thermal Printer
Scanner will not connect to PC keeps coming up with error
  • 99 Answers
Common problem with these machines,you will need a "SCANNER ASSY. Replacement
need to take to a printer repair shop.
Posted on Aug 04, 2009
The scanner is not available while in use by another application or user i get this darn error. I use this scan multiple times a day and all of a sudden i see this.... why?
The error message could be Twain Driver error or ScandAll pro Application error. Please go through the followings:
SCANDALL-PRO APPLICATION ERROR:
Error Code: [SA01020E] No scanner is found.
There is a possibility that no scanner is connected, the connected scanner is not turned on, or the scanner is currently used by some other application.
Status: [Scan] or [Select Scanner] is specified, but no connected scanner is found. Or, the scanner is currently used by some other application.
Action: Make sure that the scanner is connected and is turned on. If the scanner is currently used by some other application, use the scanner after the application ends. Make sure that the driver selected on the [Scan] tab of [Preferences] in the [Tool] menu is installed correctly.
TWAIN DRIVER ERROR:
-The scanner may be OFF or not connected. Check the power supply of the scanner or connection with PC.
-The scanner may be already in use by other application or the "Scanner and Camera" in [Control Panel].Close other application or "Scanner and Camera" in [Control Panel]
-The connected image scanner is not a model supported by this driver. No image scanner is connected. The cable is disconnected.Check whether the image scanner is connected.
-Another application may already be using the image scanner. Alternatively, the TWAIN driver may have been activated twice.Terminate all applications, and start scanning again.
For more information, please refer to the help contents of Scanner utility/Twain driver and scanning application installed on your PC.Hope the above information is helpful.
Thanks,
ScanCare
Jun 22, 2012 | Office Equipment & Supplies
KV-S2026C not scanning
does this unit show any error?
how old is this unit> is it under warranty?
Oct 02, 2008 | Panasonic KV-S2026C Pass-Through Scanner
Can I keep my scanner connected through the USB connector with my
theres no problem about it...but it is better to plug it out so that the energy consume of your scanner can keep you much gain...right!!!
Nov 08, 2009 | Televison & Video
Canoscan 8800f error as ''cannot connect with scanner''
I had the same problem with a new canoscan 8800f. I found by connecting the scanner USB lead to a USB 1 .1 port instead of a USB 2.0 port the problem seems to have been was solved. I was fortunate to have both. Originally it was just USB 1.1 ports on my PC, but I added USB 2.0. I don't know how you solve the problem if you only have 2.0 ports.
Oct 24, 2009 | Canon CanoScan 4400f MultiFunction Color...
Can anybody tell me whats wrong i keep getting scanner error
try uninstall your software for your scanner and reinstall it after restarting your PC
Oct 08, 2009 | Office Equipment & Supplies
When I try to open the Scanner software the following comes up... Error = 4 Could not confirm scanner connection.Please check scanner connection. When I try to open the easyscan Utility I get the following...
Minolta's crummy software is notorious for this. Most people can't get it to work even by removing and reinstalling the driver software. The best solution is to use a third-party driver software called VueScan. You can download a trial version for free to see if it works before you commit to buying it. If this doesn't solve it, you most likely have some sort of hardware problem.
http://www.hamrick.com
Jul 19, 2009 | Minolta Dimage Scan Elite 5400 Film...
Copying from printer to pc
Do you have the Abbyy Finereader (OCR) software installed ?.
Apr 03, 2009 | Lexmark X6100 Flatbed Scanner
Scanner error 6
my hp 3052 suddenly stops, and there is a display "scanner error 6,turn off then on" Of course i did turn off and on several times but it keeps on coming back.
Apr 27, 2008 | Office Equipment & Supplies
Make sure that the scanner file utility is running on the computer you are scanning to. Go to Start - Programs - Scanner User Software - Scanner File Utility. It will open in the system tray by the clock on the PC. Try to scan again. If still have the same error, go to the webpage of the scanner (just enter the IP address of the scanner NIC in Internet Explorer. Go to the bottom left side of the page and click Scan to PC Destination List. Click on the number to the left of the name you are scanning to. check the IP address listed on the webpage and make sure it matches the IP address of the Computer you are scanning to. One of these should fix it.
Please remember to rate you answers.
Dec 28, 2007 | Kyocera CS-2550 Black and White Copier
Scanner
Usually this is a problem with old (parrallel port ) H.P Scanners. Shut down your PC, remoce power of the scanner, remove the data cable of the scanner both at PC as well as at scanner end. Reboot the PC. reconnect the data cable and then the power cable ofthe scanner. Try using it. If you have win98, it should work now. If Win XP_P, reboot your PC, it should work. If the problem persists, try re-installing the drivers.
Oct 07, 2007 | Office Equipment & Supplies
HP OfficeJet 7110 All-In-One Thermal Printer Logo
57 people viewed this question
Seeker5211
Seeker5211
