Question about HP LaserJet 1300 Printer
We have a problem in my HP Laserjet 1300 printer, in monitor always that my printer is out of paper but thers a papers in the printer
  • Lars-Eirik May 11, 2010
    What kind of driver do you use ?
    Scholar:
  • 118 Answers
The is a paper sensor ( black plastic ) at the end of the paper tray against the wall of the printer. Laft hand side of the middle. It may be jammed or stuck. Check to see that it moves bachwards and forwards freely.
Posted on Aug 06, 2009
HP LaserJet 1300 Printer: black vertical lines on both side of paper
for this model.. first check if your toner cart is good.. if it's good.. then the cause of your problem is your printer fuser sleeve.. fuser is where the paper is heated up.. and when you start having dirty line print out.. it show that the fuser sleeve(top part of the fuser) is torn..
if you send to HP.. they will probably charge you the whole fuser.. which is expensive.. you can always replace the fuser sleeve only..and it cost not much.. you can always replace it by yourself if you are able to remove the fuser unit..other thing.when you switch on the printer, can you hear sound like paper been crumble at the exit of the printer?
May 23, 2010 | HP LaserJet 1300 Printer
Paper Jam HP LaserJet 1300
I hope this will be of Help for the HP LaserJet 1300 Paper Jam Trouble Shooting:
  1. See the product user guide for information about clearing jams from the printer.
  2. Make sure that the paper guides are adjusted properly. Slide the guides against the sides of the stack in the main input tray or the priority input tray to center the page. Make sure that the guides are not adjusted too tightly.
  3. The media input tray might be too full. Remove some of the sheets.
  4. Make sure that the media being used meets specifications. Click here to refer to "Media specifications" for more information .
  5. Make sure that the media being used is not wrinkled, folded, or damaged.
  6. Make sure that the printer is clean. See the product user guide for information about cleaning the printer.
  7. If printing to the straight-through output path, close and open the door again to make sure that the green release levers are closed.
  8. The paper might not have been removed from the main input tray before the tray was refilled. Always remove paper form the main input tray before refilling it.
  9. Output capacity might have been exceeded in the paper output bin. Do not allow more than 125 sheets of 20-lb (75 g/m2) bond weight paper to fill the paper output bin (less for heavier paper).
  10. The pickup roller or printer separation pad might be dirty or damaged. Clean or replace the part. (See the product user guide for information about cleaning and replacing the pickup roller and printer separation pad.)
Apr 03, 2010 | HP LaserJet 1300 Printer
Printer printed paper with crushing sounds, but
You need to continually press the paper feed button (next to power) while applying gentle pulling pressure to manually feed the paper all the way through the printer. Hope this helped
May 09, 2009 | HP LaserJet 1300 Printer
LaserJet 1300 jams the paper
Hi there
Use standard paper.
try to shake and bend the papers quote before placed in tray.
thanks
Hamedo
Nov 15, 2008 | HP LaserJet 1300 Printer
HP Laserjet 1300 will not feed paper
You may need a new roller, or pad.
Aug 11, 2008 | HP LaserJet 1300 Printer
HP LaserJet 1300 Printer - Won't feed paper
firistly try to find out the printer is ready or not then find out when we powearing on the printer then it is warming up or not if it is warning up and not come to ready position then open front cover pull the toner cartage and send back it propely
then give print if the problem is not solved then ckeck the printer cables and drivers
Jun 28, 2008 | HP LaserJet 1300 Printer
HP LaserJet 1300 Printer Logo
175 people viewed this question
Seeker5211
Seeker5211
