Question about HP NVIDIA GeForce 8400GS - Graphics adapter - GF 8400 GS - PCI Express x1 - 256 MB DDR2 - TV out PCI Express Video Card
NVIDIA GeForce 8400GS dual monitor problem
I am running an Compaq Presario SR2170NX with a pci GeForce 8400GS that i purchaced new about a year ago. it has been wonderful up until a week or so ago, when the TV i have plugged into the S-vid out card port decided to go blank. the cursor will disappear off the side of the screen just as normal if the dual monitor is activated, but the second monitor is blank. to further confound me, if i reinstall the latest driver (which it is running anyway), the screen will magically work! for a random length of time, at least. the last time, it was about a half hour. the time previous, a few hours. i have read that this card has gpu overheating issues...is the most likely cause of my issue a fried card, or is there a way i can salvage it?
    President:
  • 2,666 Answers
The card is not fried or it would not work at all however as it works "randomly" it is possible there is some damage and it is on it's way out. You have however recognised the problem yourself in overheating. get a fan for the heat sink even if you have to glue it to it put an extra casing fan in.
Make sure there is adequate ventilation around your PC unit if necessary go to the extreme and take the side off the tower.
Any extra load by whatever means, extra HDD extra monitor extra external device etc causes extra heat and that has to be got rid of. Your PC came with enough for what it was supplied with (with a little extra) but bottom line more load = more heat = more ventilation you need..
Posted on Jul 29, 2009
    President:
  • 828 Answers
In this case too much ground on your TV. Going through to your S-Video input. I have encounter with this problem but I fix it. Most likely the another problem is the compatibility with your Motherboard and your New VGAPCI-E Card 8400GS, this VGA Card are likely known or have another connection to another Monitor or TV Devices.
Here's what you do, use your Utility Disk that have INF software programs that support your Motherboard from any plug-in devices like PCI-E Card. That INF program provide assistance to accelerate some resolution or pixel graphics on your System and also use DirectX 9.0C version to test the resolution that can give you satisfaction to use dual view on your PC. hope this might help you. Good luck!
Grafic card driver
http://www.nvidia.com/Download/index.aspx?lang=en-us
Mar 20, 2011 | HP GeForce 8400GS Graphics Card - nVIDIA...
About geforce 8400gs gen2 tc1g 64bit ddr2, it is okey to run in window7 32bit. i already install and run but only read 512mb.
There should be no reason why this card won't work with Windows 7 32bit, it could be as simple as your Graphics drivers are out of date. I recommend downloading the latest Windows 7 drivers for your card at the Nvidia website.
Just remember graphics RAM and SDRAM are two completely different things so they don't add up.
As far as I know the 8400GS is a 256MB card.
Jan 07, 2011 | HP GeForce 8400GS Graphics Card - nVIDIA...
I am running Windows 7 (32 bit) and am seeing ghosting behind the fonts as I scroll them with smooth-scrolling in Firefox and Thunderbird. It is especially visible when viewing on a dark background. I have...
Hello!
First things first!
Usually these problems, its related to monitor or monitor drivers, check the cable conection to the back of monitor, if is HDMI or analog, that is well conected!
other may be bad power cap, or damage, or high freq. static in lines.
hope these hints, helps
Carl
Jan 06, 2011 | HP GeForce 8400GS Graphics Card - nVIDIA...
Installed GEForce NVidia 8400GS graphic card but no video output. Onboard and other video cards will work. The 8400GS will work in other desktops correctly. Any help would be graet!
Assuming that you have installed the drivers for your new board, go into Control Panel, select Device manager and Display Adapters.
Dissable the onboard adapter and enable the NVidia card.
Dec 27, 2010 | HP Compaq Presario SR1820NX (ER919AA) PC...
I have quite a few d530-SFF systems. They have the ''standard PCI'' slot ''carrier'' that plugs into 1 of the 3 PCI slots on the M/B and has 2 full-size PCI slots. I installed a PNY Nvidia GeForce 8400GS...
I checked the specs on the video card thinking it must be PCI-e and not old style PCI but in fact there is an old style PCI meant for just what you are trying to do. The problem is the memory at 512meg plus the GPU put your power requirements at 300w and I bet you have at best 185w in those units so they won't even start and you won't be able to cram the bigger power supply in there. Go with a card that has lower specs and 64 - 128 ram and you should be ok. Just check the power req. JC
Nov 17, 2009 | HP Compaq d530 SFF PC Desktop
2nd monitor doesnt work either
Ensure your are running the monitors in dual mode still. Open your Nvidia Control Panel and click on "setup up multiple displays" Then on right panel you should see where to select your option on how to run the 2nd one. You might need a driver update from Nvidia, especially if you recently took an update from Microsoft.
Hope this helps
ps Here is the link to Nvidia: Click Me
Sep 26, 2009 | Pine Technology XFX GeForce 7950GT, (512...
Video Card issues: fried?
Yes, it sounds like either the video card is bad, or the PCI-e slot on the MB is bad. If you do indeed have a PCI-Express x16 slot on the MB, than yes a 9800 series should do fine provided your power supply is up to the requirments needed for the card.
Jun 19, 2009 | HP GeForce 8400GS Graphics Card - nVIDIA...
HP NVIDIA GeForce 8400GS - Graphics adapter - GF 8400 GS - PCI Express x1 - 256 MB DDR2 - TV out PCI Express Video Card Logo
3,081 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
