The warranty on an iron is usually one year, but that may not cover the cord, which seems to be your trouble. If the cord is intact, both wires, at least one of the lights should come on - even if the iron still refuses to get hot. Remove the rear cover and check for continuity from the socket to the connections in the iron.
If the iron is still in warranty send it back via the shop where you bought it, the inner wire is frayed and needs replacement, if you know an electrician its as simple as shortening the flex by a few inches and reattaching it again. the inner wires twist with time and become frayed or come loose from connection
If it is more than 3 years old (no warranty) then you can get it repaired or replaced. The heating coil is broken. The heating coil in the iron cannot be fixed, but must be replaced.
If the iron is less than 3 years old, you can get it repaired under warranty; however, shipping and other costs may not be worth having it repaired. (More than $30).
If you can get an estimate, you might want to have it repaired.
if the the iron is still in valid warranty time,ask the seller to change a new one or repair it for you i think! Or you can change a vertical type iron to instead !And it won`t leak,iron effect is better than the traditional iron !
