Question about HTC Shadow Smartphone
My right soft key and my camera function buttons will not work.It started recently for no apparent reason at all! Please let me know what I can do to fix this!
  • 135 Answers
Check the settings for the Buttons
Posted on Aug 03, 2009
Buttons won't work. Just returned from a 6 day golf trip where the SkyCaddie SG4 worked perfectly for the first 5 days. I recharged it in a wll outlet overnight, then on the next day the buttons...
Power On/Off and Key Lock/Unlock - Press the Power button located at the top right
of the Sky Caddie to power on/off or to lock/unlock the keypad. Upon pressing
the Power button you are prompted to choose either "Off" (Left Soft Key) to power
off the device or "Lock" (Right Soft Key) to lock the keypad. To unlock the keypad,
select 'Unlock" by pressing the Right Soft Key, then choose "Yes".
Jul 02, 2011 | SkyCaddie SG 4 Handheld GPS Receiver
How to delecte recent logs
These steps should be more or less similar.
  • Press the OK button for Menu
  • Select Recent Calls, using the navigation keys
  • Select All (4)
  • Select the Recent Call type, using the navigation keys, from the following:
  • Missed Calls
  • Received Calls
  • Dialed Calls
  • All Calls
  • Highlight desired Recent Call, using the navigation keys
  • Press the right soft for Options
  • Select either Erase (2) or Erase All (4), using the navigation keys
  • Highlight Yes, using the navigation keys
  • Press the OK button to confirm call log deletion
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Feb 22, 2011 | Samsung SGH-T309 Cellular Phone
Nikon d80 buttons malfunction
Is there any chance that the symptoms are different when you are in Auto, M, S, or P?
Jan 08, 2010 | Nikon D80 Digital Camera with 18-135mm...
The keypad 3, 6 and 9 of my sonyericcson k750i are not functioning....
If you feel confident and competent enough, try taking your phone apart and giving the internals a good clean, take the white keypad PCB out and clean both it's contacts and the contacts on the phone's mainboard, and clear out any dust. Put the phone back together and see if that's solved the problem. It could also simply be that the keypad connector has worked loose
Key Pressed : Key presses phone appears to see
3 : 3 then left soft key
6 : 6 then right soft key
9 : 9 then back
c : c then #
left soft key : 3 then left soft key
right soft key : 6 then right soft key
(All the other keys worked correctly)
As I didn’t know what was causing this I attempted to move all data stored on the phone to the memorystick so I could master reset and possibly reflash, although after this I returned to the homescreen to find all keys had started functioning correctly again,
9 : 9 then back
c : c then #
Jun 25, 2009 | Sony Ericsson K750i Cellular Phone
Windows XP task manager is gone
Right click your start button, then left click properties. Left-click the Start Menu tab, then left-click the Customize button. Scroll down in the area near the center to find the radio button near My Pictures. You can choose to display as a link, as a menu, or not at all.
I would scan for viruses if this happened for no apparent reason.
Mar 16, 2009 | Dell Computers & Internet
Touchpad Not Working
If you has been installed the right drivers, it is hardware problem.
Try to use the factory touchpad program for your sony touchpad and see what happen (not only the driver, also the program touchpad software)
Oct 06, 2008 | Computers & Internet
Go to Device Manager, right click on yellow !, use windows update to update driver
If that doesn't work, do a complete wipe out and do a clean install of new Operating System.
Jun 23, 2008 | Gateway MT3705 Notebook
Deleted camera from dash
I would back up any crucial information you have on your Dash and do a hard reset and when your Dash re-boots it should have all the original programs your phone came preinstalled with. it Dash Hard Reset
1. Select Start
2. Accessories
3. Clear Storage
4. Type 1234 in the box
5. Select YES. OR
- with the phone powered off
- press the two soft keys, yes the left and right soft keys which are the two dash keys labeled - -
- while keeping it pressed, press the power button down
- keep the power button pressed down for 1 - 2 seconds and then release the power button while still holding down the two soft keys. Keep holding down the soft keys until a black screen appears and prompts appear
- now release the soft keys and follow prompts
Apr 09, 2008 | T-Mobile Dash Smartphone
The Print key is not working
it depends what system you are running cetain programs and windows operating systems dont accept this shortcut
try going into controll panel clik keyboard and make sure hot keys are on
the only other reason is if you have eny other wireless functions running these can disrupt the signal from the keyboard to the computer turn off all wireless items and try agen
if none of these work try replacing the keyboard as it should work as long as hotkeys are on and the operating system you have accepts this function
Oct 18, 2007 | Microsoft Wireless Optical Desktop Pro...
is there a touch pad 'switch' off function with this particular model? Some Acer machines have an F number plus another key to de-activate/reactivate touch pad. Check your Manual
Jun 19, 2007 | Sony 4-660-223-01 Touchpad Keyboard
HTC Shadow Smartphone Logo
109 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
