SOURCE: Radio shack Pro-433
Look at www.radioreference.com This is the most complete scanner site on the web. Just register and then search the forums for what you need.
SOURCE: I have a radio shack
You can initialize the scanner to delete all information that you've programmed into it and return it to its original factory settings. To do this:
1. Turn the scanner OFF, then turn it ON again.
2. Press and hold down the CLEAR key and insert a pointed object, such as a paperclip or the point of a pen, into the RESET opening in the back of the scanner, and press the button inside the opening.
3. Release RESET. When information reappears on the scanner's display, release the CLEAR key.
NOTE: You must release the RESET button before releasing the CLEAR key.
Also note that this procedure may not be necessary. Programming a new frequency into a channel automatically deletes the frequency previously stored in that channel.
Bill B
Listening in since the 60's
Testimonial: "Perfect solution for what I want to do. Thank You"
SOURCE: how do i program a radio shack realistic pro 2021
go to bettybearcat .com and you can get frequencys for your area
Linda, for scanner questions go to the appropriate FORUM at the site: "Radio Reference dOt cOm" (no spaces, etc). Register for a free account and go the Radio Shack scanner forum. Some Uniden based are as simple as holding down the number "2" & "9" keys while turning the unit on, but ask your question there for a good answer. Thanks, John
