Question about Bosch 24 in. SHY56A05 Stainless Steel Built-In Dishwasher
Bosch SHY56A05 Dishwasher was running even with door open
My first problem was the on/off switch was stuck in on position. Washer wouldn't work at all. Had switch replaced and all was fine for two or so months. Then one day I opened the dishwasher in the middle of the dry cycle. The whole dishwasher shut down - dead. We switched the circuit braker off and then back on. Then dishwasher all power was out on control panel of dishwasher except the delayed wash button. When I pressed start the dishwasher started running even when the door was open. Now am told the "mother board" is dead due to water damage and the latch is broken. Do I have a "lemon" or is this worth repairing? Will cost A LOT of $$ to replace electronics.
  • 457 Answers
Find out first from boschwhats covered and whats not. i think bosch has a 2year iw on electrionics, and some models has a recall, go to thermador .com and you will be able toget the # to bosch which is the same company and give them your model # and serial # they will tell you whats is covered and whats not.
Posted on Mar 03, 2010
How do you check for error codes on a Bosch SHY56A05UC/23 Dishwasher? My dishwasher runs continuously in the drain mode and the "cancel drain" feature does not work.
what is happenig i believe and has happened to me 2 times is that the water level float that is on the left side of dishwasher is stuck.
Either remove side panel and flick lever or pull dishwasher out and tap lower portion of panel and this will cause the level to move and then see hat happens
Jan 29, 2011 | Bosch 24 in. SHY56A05 Stainless Steel...
Hi i have a Bosch electronic management dishwasher its about 5 yrs old. it washes but the water does not drain out. can you help
It is either the waste water pump has stopped working, whichis accessible from below the dishwasher (lay dishwasher on back and remove 2screws from bottom plate) or alternately the float (open dishwasher door, removebottom basket and lift dome shaped float up and down a few times).
Jan 13, 2011 | Bosch 24 in. SHY56A05 Stainless Steel...
How do I tighten the door handle on my Bosch dishwasher model SHY56A 05UC/14?
Remove front panel then you can access the handle screws. Open the door and remove the 'torx' screws surrounding the perimeter of the door.
Oct 06, 2010 | Bosch 24 in. SHY56A05 Stainless Steel...
My Bosch SHV46C dishwasher keeps running, even when the door is open, unless you turn the control switch off. Then, when you turn the switch on, it starts running again.
I have a Bosch that was stuck in pump down mode even when the door was open.
The problem ended up being too much water in the drip pan below the unit. There is a float in the drip pan that actuates the same limit switch as the internal overfilled float.
I had recently cleaned the incoming water filter and must have loosened the water line tube.
Nov 20, 2009 | Bosch SHV46C03 Built-in Dishwasher
No washing action through washing arms even after
Many times the washing arms of the bosch and few other models will clog up with old soap or debris.
Try removing arms and clean out any debris by blowing air through unit and if need be a toothpick or dental tool to remove any solid debris that is stuck. Reattach arms and run through cycle. Hopefully this works otherwise it could very well be the pump.
Sep 07, 2009 | Bosch 24 in. SHY56A05 Stainless Steel...
Dishwasher started, released soap, then nothing
Turns out the motor died. The good news is that it only cost $225 for the part and another $175 to install it. Aaah yes, the next machine will not be a Bosch.
Jan 15, 2009 | Bosch 24 in. SHY56A05 Stainless Steel...
Water Leak at bottom of unit
hi there,
leaks a quite frustrating once they happen but there aren't that many places that you can have a leak. i would recommend looking at the drain pump and ensuring all seals are ok. after that focus on the door itself. are the seals okay, the door liner, etc?
Nov 11, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch SHY56A Dishwasher
if the door doesn't shut, the push buttons should not work. that way you are not running your d/w with the door open. check the door latch, as it seems to be malfunctioning. if the d/w still does not work, replace the door latch.
Aug 15, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch dishwasher regularly floods
fault is with dishwasher. even if drain blocked, would not cause overfill.
possibly the pipe to sump from fill mechanism partially blocked
Jul 18, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch 24 in. SHY56A05 Stainless Steel Built-In Dishwasher Logo
377 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
