Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Whirlpool gold side by side refrigerator. Light does not come on in refrigerator side. Changed light bulb, still did not work. Pulled door switch and checked continuity on switch - appears OK. Check voltage on wires to switch, read about 36 volts ac.
  • bradatteberr Jul 29, 2009
    I don't think that's it. One other thing I forgot to mention is that the lights on the controls inside the refrigerator do not work either. Cooling in both refrigerator and freezer seems to be normal.
  • bradatteberr Jul 30, 2009
    I need a more definitive solution please.
    President:
  • 1,714 Answers
Nice job on the voltage checks! Now, are you checking 'across' the switch, or one side to ground?
If you go across, or one end then the other end to ground, you should see 120 volts to ground. If you measure one end to the other end it should be '0' volts if the switch is closed. 36 volts does not compute.
Posted on Jul 30, 2009
  • 11,896 Answers
The socket will need to be replaced. You can get them at repairclinic.com and wire them in.
Posted on Jul 29, 2009
  • 296 Answers
This looks like the problem is in the control board. A diode is shorting the relay, also has burned off trace. Look for diode to replace.
Thanks!
mannu_rakesh
Changed light bulb still not working. Top bulb refrig side
There is a switch for the door that is depressed when the door closes. If the switch has failed the light will not work at all. You can unplug the unit and gently pop the switch out usually with a knife blade by depressing the plastic release tab (If you can find them) and then pull it out. Remove the two wires from the switch and mate them as best you can so they make contact and will not ground to anything. Plug in the unit and see if the light works. If the light comes on the switch is bad. Unplug the unit and reinstall the slight switch.
If you still don't have a light there is a possibility of the light socket being defective or a wiring problem in the chassis.
Feb 05, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Light won't work even tho changed bulb whirlpool fridge
Have you checked the door switch, might be stuck in or defective.
Apr 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Lights is refrigerator side stopped working. Seems to be cooling, but no lights. Freezer light is okay. Changed out bulbs, still not working. Is there a fuse for lights?
may be the light switch or try this unplug refrigerator on screw bulb look in the socket there is a flat side in it the center get a flat screw deiver pull it up a little put back bulb plug unit if it dont light change switch
Mar 29, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Light not working!
you sure is not the door switch making noise when open
Mar 11, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Fridge Light - you posted
Your bulb is shorted out internally. Try another bulb. Please post as as helpful if so.TY
Jan 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Mod #GD5RHAXNQOO
Possible that the door switch is the reason.Check for powerat the door switch
May 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
35 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
