Question about Samsung SyncMaster 940B Monitor
Error message on Syncmaster- check signal cable
Ages ago my syncmaster 940 b suddenly stopped working, the screen says check the signal cable, then when I plugged it in today it suddenly worked this morning, but i had to unplug it for something, and now it has gone back to check signal cable error message. Problem is - not sure what that is!
    Problem Solver:
  • 11 Answers
Sounds like it might be a graphics card. if u have an old graphics or vidio card, open the case and remove your card then install the old one. if it works now youll know your card is bad. If u have an old video card and an open pci slot install it and move the monitor cable to the old video card plugin. if it works now same thing your graphics card is bad. to know which card to remove just remember which one the monitor is plugged into.
Posted on Jul 29, 2009
Why do I have no signal on the Samsung syncmaster 940 mw tv
Check your cable connection on both ends. Try to change the cable.
Oct 06, 2014 | Samsung SyncMaster 940MW 19" LCD Monitor
My SyncMaster 940BW Samsung monitor does not respond to any Laptop/computer connection. The on/off blue botton is blinking. It worked well a while ago. ANy suggestions?
You can try to disconnect VGA cable to see will the notification "no VGA signal" appear on screen. If so the problem could be with PC graphics, else it is power board problem bad caps.Thanks
Sep 29, 2013 | Samsung Syncmaster 940BW LCD Monitor
Samsung Syncmaster 2333
Check signal cables means there's no signal on input. If your PC still shows up on a different monitor then it's a time to replace a mainboard in your monitor.
Jun 03, 2017 | Samsung SyncMaster 2233BW 22" LCD Monitor
Hi I have a syncmaster b2430 which has been great for a few months. All of a sudden it seems to be unable to get the signal from my CPU. It goes from hdmi to analog to digital and just flashes a screen...
First check to make sure that your cable is connected securely to both your monitor and your PC. IF it is, then try and boot your computer into safe mode with networking to see if you can get the monitor to work in that mode. This will only load the most basic VGA driver and should work. If it does then go to your graphics card manufacturers site to see if you have the latest driver for your card. If you do not then following the instructions on their website download and install their latest driver. If that doesn't resolve the issue then you will have to take your PC and monitor into your local repair shop as one of those components has stopped working.
Mar 25, 2011 | Samsung SyncMaster 152N (Black) 15 in....
After startup on Sammsung SyncMaster 940 N I do not see
Sounds like system software needs to be replaced... re-installed. It probably got corrupted somehow since it is not rebooting properly. Use the original discs that came with the computer. Thnx
Jul 24, 2010 | Samsung SyncMaster 940N (Silver) LCD...
Screen says check signal cable - have check my cables....
Not really...
First check if the cable connected from the monitor is secured and properly connected to the video card of the CPU.
"Check signal cable" will only be display if there is no signal coming from the CPU.. that signal Passes through the video card..
Check the status of your video card.....and see also if the CPU is working and not dead set.
Hope this help...
Much appreciated if you rate this help.. thanks
May 21, 2010 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Tried installing samsung syncmaster monitor and get and error message check signal cable dialgoue and can't do anything, previous monitor works fine
Does the new monitor work correctly when installed to some other computer (notebook or desktop) ? If it, you have a "dud" that should be replaced, under warranty.
Try changing the data-cable between the monitor and your computer.
Oct 10, 2009 | Samsung SyncMaster 713BM 17" LCD Monitor
Same problem- SyncMaster goes on/off, bad TV image, needs reset
try to update the monitor driver tehn check the same with the cables from cpu detached if no signal comes for long then the monitor is fine also try to check the monitor on bios screen
Sep 15, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
Smeared image
Try removing signal cable and refitting at both ends.
Signal cable also could be faulty.
Samir
Aug 06, 2008 | Samsung SyncMaster 731B 17" LCD Monitor
Samsung SyncMaster 940B Monitor Logo
907 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
