Question about Kenmore HE2 Plus Front Load Washer
F01 appears when starting. We have uplugged it to reset but the f01 still appears. What should we do?
  • 15,935 Answers
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question!!!!
Posted on Sep 11, 2010
My Maytag 3000 series dryer will not start, it turns on, says time remaining 40 then changes to F01 but wont start?
F01 means the main control board or "micro computer" has detected an internal short. The only way to fix this is replace the control board. God-Bless! You can do this yourself if your handy with different jobs.
Jun 02, 2016 | Maytag Dryers
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
Reset innov-is 350 from f01 error
Copied from the user manual:
If error message "F01" through "F09" appears in the LCD while the
sewing machine is being used, the machine may be malfunctioning.
Contact your nearest authorized service center
Mar 07, 2015 | Brother Sewing Machines
Wt960
  • F01 - Short circuit motor triac
Nov 04, 2012 | Hotpoint Washing Machines
Hotpoint WMD washing machineFault Code F01 machine will not start
Fault code F01 indicates a problem with the motor triac.
Check all connections to and from the motor, the control module, and the motor plug
Jan 09, 2010 | Washing Machines
HOW TO FIX A F01 ERROR ON MY DUET HLT WIRLPOOL WASHER
hi my name is joyce
Did you try to unplug the unit for 60 secounds and replug it back up?
do this and see if this works. then reset the machine's cycle, you are in the middle of cycle I usually push pause cancel and wait till the door beeps and then I can open it. but if this does not open the machine do the unplug and reset method. if this does not work please let me know.
thanks,
joyce
Feb 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 05, 2009 | Washing Machines
I have a maytag EpicZ, model # MHW2600TW00 with an error code of F01. Do you know how to clear this code?
I just had this problem and I kept the washing machine on and flashing f01 and I pulled the power cord out of the outlet while it was still on and it reset it and I could start washing immediately.
May 27, 2008 | Maytag Washing Machines
Maytag EpicZ has a F01 code. The machine will not start!
I have had the same problem and I just fixed it. The f01 code was flashing and I left the machine on and pulled the cord out of the outlet and it restarted. Mine would not start, it would power on and you could select the type of wash and make any selection, but once you pressed start it would start flashing f01. I left if flashing and pulled the plug and it started working immediately.
Apr 15, 2008 | Washing Machines
Kenmore HE2 Plus Front Load Washer Logo
73 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
