Question about GPS
My GPS case is falling apart and the suction cup that holds it to the windshield does not have a good suction. I think this is from the heat, but my wife's GPS handles the heat. The voice isn't clear at times. What should I do? I bought it Nov. 07. Can it be sent in for repair and would it still be under warranty? The unit serial # is 107433761. Thanks for your help, Chris
    Brigadier General:
  • 4,090 Answers
Cheaper to update than to repair
Posted on Jul 29, 2009
I need instructions on how to mount the nuvi 200w to my windshield
To secure the nuvi 200w to your windshield with the included suction cup mount (pictured below),
center the GPS on the clip, and tip the bottom edge on the bracket. Push the top of the GPS against the top clip until it clicks into place. Hold the bracket and GPS near the windshield where you like it best. Note where the suction cup is on the windshield in relation to the mirror, etc. Remove the GPS from the mount's clip by pushing the top tab back from the top of the GPS.
Clean the windshield (or portion that the suction cup will be stuck against) with a paper towel or newspaper and ammonia solution like Windex, etc. Clean the suction cup with the paper towel and Windex, too.
Lift the lever at the base of the mount - is shown in the picture above - if it isn't already. With the mount oriented as shown in the picture above, press the suction cup against the windshield where desired with one hand. Hold the mount firmly against the glass and use your other hand to press the lever on the base back toward the suction cup and glass. Press until it lays flat against the base / suction cup. Plug the power cord into the GPS and reinstall the GPS in the mount clips as done earlier.
To remove from the windshield, release the GPS from the mount clips, and lift the lever away from the base / suction cup. Locate the tab that is connected to the suction cup edge near the lever. Pull on the tab away from the glass to break the suction seal and remove from the windshield.
If this was helpful, please rate it 4 thumbs up. Thanks & good luck!
Sep 20, 2011 | Garmin GPS
WIll not adhere to the windshield... suction cup does not hold GPS
Tomtom GPS devices come with a variety of windshield suction mounts. All have in common that the windshield and the suction cup both must be clean; use a mild soap dispersed in some warm water to remove any dirt. Rinse properly. Sometimes it helps to keep the cup a little moist.
Make sure the cup is not warped due to previous exposure to heat, and check for any nicks in the rubber. Small damage may easily make the mount unusable and you'd need to get a replacement.
Models with a lever mechanic: open the lever (cup becomes flat), press the cup against the windshield and while keeping pressure, close the lever. It will lift the middle of the cup away from the windshield, causing a vacuum.
Models with a ring around the cup base: Turn the ring all the way counter-clockwise (cup becomes flat), press cup against windshield and while keeping pressure, turn the ring clockwise 90 degrees. This requires some force, but in my experience these mounts stick more reliable,
Dec 31, 2010 | Tomtom GPS
I have purchased three of these products from this company. I am sick and tired of this navigation system falling out of the window while I am driving. I am a salesman that purchased this product in good...
Brian - you should contact Garmin directly at www.garmin.com - this site is not affiliated with Garmin in any way. I'd suggest that you secure the GPS to the center of the windshield or use the semi-permanent dash mount instead of suction cup mounting to the windshield near the driver window.
Jun 30, 2010 | Garmin Nuvi 760 Car GPS Receiver
Suction cup does not stick to the base of the tom tom..Everytime I try to attach the suction cup, it just falls over. Help
  1. If you will stick the suction cup to your windshield make sure to clean it first use dry clothe and put pressure while rubbing it to the windshield.
  2. After cleaning it before you stick the suction cup to the windshield make sure the lock is release and then put a pressure and then while pressing it then that's the time you will lock it.
Feb 06, 2010 | Tomtom ONE GPS Receiver
Plastic pholder for my Garmin 255W will not stick to windshield
The glass and attachment suction cup should be clean and free of oils, dust hair etc. Try cleaning both surfaces. If this doesn't workyou can order a new holder from Garmin.
Aug 02, 2009 | Garmin Nuvi 255 GPS Receiver
Sticking my nuvi 260W to windshield - after a few days often in sun [winter/spring Mass.] thesuction cup mount falls of to dashboard- risking damage to nuvi. advice? without having to use permanent...
Here is what I do. I clean the spot on the windshield very good with Windex or another good window cleaner. I also clean the suction cup surface while I am doing the windshield. Next I place the GPS next to the Rearview Mirror. and connect the suction cup. Then I take the power cord and use it to tie a knot around the suction cup mount and then I loop it around the Rearview mirrow twice leaving no slack between the GPS and the Mirror. Be sure to not block you view in the mirror. If the GPS come loose from the windshield it will just fall far enough for the power cable to catch it and will just be swiing there instead of falling to the dashboard or floor. This is kind of a Mickey Mouse way to do things but it works.
Apr 08, 2009 | Garmin nuvi 250W GPS Receiver
LG GPS not suctioning to windhield
You must clean the window area using windex, or other cleaner, and wipe until dry. A clean winshield area provides the best suction, from the mounting bracket.
Slide the mounting bracket switch to Off & On a few times, make sure the suction cup is able to move(slightly) and that the small tap is facing the area with the notch in the metal.
After putting the switch to the middle, moisten the suction cup slightly
(saliva works bestter than water for some reason)
press it to the window with a slight amount of pressure
then move the switch, (Which should be set to Center!)
to lock it on firmly.
If this doesn't work, then there is a good chance the suction cup has become hardened by the sun. If that is the situation, you'll have to contact LG
(or a place that sells "knock off" brackets to get a replacement.)
I never leave my LG GPS in the car, when not in use. Even the bracket comes out, as I've seen what the sun can do to damage those plastic suction cups, fortunately, I learned it on a $5 replacement set for a Radar detector/Emergency Vehicle Alert device, and not a more expensive bracket.
Dec 07, 2008 | LG LN740 GPS
Suction cup problem
Make sure your windshield and the bottom of the suction cup is clean. Clean it with some warter & detergent and wipe dry. Try wetting the bottom of the suction cup before applying it to the window.
I recommend not using the window mount. I recommend using the dash friction mount. You take the risk of cracking your LCD screen when it falls.
1. The dash friction mount will not fall.
2. It's easily removable/
3. It's legal in all 50 states (window mount is not).
- Jim
Nov 05, 2008 | Garmin nuvi 350 GPS Receiver
Suction not holding on window
wet the back of suction cup. it will hold alot better
Jan 14, 2008 | Garmin StreetPilot c340 GPS Receiver
GPS Logo
35 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
