1999 Cadillac DeVille Logo
Berney Scharen Posted on Oct 11, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1999 CAD DEVILL COOLING FANS NOT WORKING WHERE ARE THE RELAYS LOCATED?
Jeff Armer
Level 3:
  • Cadillac Master 15,575 Answers
  • Posted on Oct 11, 2017
Jeff Armer
Cadillac Master
Level 3:
Answers
15575
Questions
Helped
7100455
Points
73899
Engine Cooling Fan Relay 1
In the center front of the engine compartment, on the lower radiator support, near the cooling fans
Engine Cooling Fan Relay 2
Engine Cooling Fan Relay 3
5 Related Answers
alicantecoli
Colin Stickland
  • 22516 Answers
  • Posted on Nov 18, 2008
SOURCE: 1995 ford escort lx fan relay locations
right hand side under bonnet on the wing or at the back by the battery depending on model build
Anonymous
  • 323 Answers
  • Posted on Apr 26, 2009
SOURCE: LOCATION FAN RELAY
The relay is under the right front headlamp assembly and bracket. You can access it two ways. Remove the front bumper facia, headlights, and bracket assembly. The grill is part of the facia and the headlight bracket runs all the way across the front. Or you can remove the right headlamp and use a hole saw to cut through the bracket, it is a plastic material.
GM Elec
Bruce Bracey
  • 1000 Answers
  • Posted on May 02, 2009
SOURCE: Where is location of cooling fan relay?
Under the hood on the drivers side, just forward of the shock tower, you will see what is called an "under hood fuse center". On the cover you can see the various fuses and relays that are located in the fuse center.
One of those relays is the coolant fan relay. Remove the top cover of the fuse center to gain access to the relay.
Hope this answers your question, good luck.
Regards,
ZJLimited
ZJ Limited
  • 17989 Answers
  • Posted on Nov 04, 2009
SOURCE: location for radiator fan control relay circuit
This relay is a common problem for Chrysler vehicles. Located in the passenger side bumper area (Jeeps). Test the fan first.
Hope helped (remember rated ths help) Good luck.
Kravcar
Mark Carrington
  • 192 Answers
  • Posted on Apr 26, 2010
SOURCE: locate fan relay
There are three cooling fan relays in the fuse block under the hood.
The fan relays above are numbered 37,39 and 40
Relay 37 is RH fan
Relays 39 and 40 are LH fan.
You can check if your fans are working by switching on the air con.
Are you having overheating problems?
Regards.
2answers
Where is the fan relay on 1999 aurora located
Cooling Fan Relay No. 1
Center rear of engine compartment, left of the windshield wiper motor
7 - COOLING FAN #2 Relay
8 - COOLING FAN #3 Relay High Speed Cooling Fan Relay #3
9 - COOLING FAN Fuse
60A
Cooling Fan Relay #1, Cooling Fan Relay #2
2answers
Where is the cooling fan relay located
In the engine compartment fuse block. Look at positions 7 and 8. There should be a diagram under the lid.
Where is fan motor relay located?
Search Results
    Chrysler Cooling Fan Relay - YouTube
    ? 5:00
    https://www.youtube.com/watch?v=AdIYm9kM5E0
    Jan 9, 2010 - Uploaded by realfixesrealfast
    Review the electrical diagram before you begin and this should help ... ... How To Solve An Engine Overheat Condition - EricTheCarGuy - Duration: 26:09. by ... 1999 Dodge Caravan AWD 3.8L Radiator Fan Relay Replacement for ... Terms · Privacy · Policy & Safety · Send feedback · Try something new!
    Need to find location of cooling fan motor relay - Fixya
    www.fixya.com/cars/t26003541-need_find_location_cooling_fan_motor
    4 hours ago - need to find location of cooling fan motor relay - Chrysler 1996 New Yorker question.
    Guess no-one knows where the fan motor relay is. Not ...
    images for 1996 chrysler new yorker wiring
2helpful
Radiator fan motor does not run
1. check the cooling fan fuses
2. supply battery voltage directly to the fan assembly plug
a. if fan is good
locate and test/replace cooling fan relay
b. if bad
replace cooling fan assembly
if still is not working check continuity cooling fan system circuit/wiring
3helpful
2answers
I have a 1999 chevy cavalier and the cooling fan will not start
CHECK COOLING FAN FUSE AND RELAY.IF BOTH GOOD SCAN CAR TO CHECK COOLANT TEMPERATURE SENSOR FAULT CODE.THE PCM AND COOLANT TEMP. SENSOR IS WHAT CAUSE FAN TO RUN AT CERTAIN TEMPERATURE.IF ALL IS GOOD.HOT WIRE COOLING FAN USING JUMPER WIRES TO BATTERY.IF FAN DONT RUN REPLACE FAN MOTOR.IF FAN RUNS YOU HAVE SHORT OR BROKE WIRE IN THE COOLING FAN ELECTRICAL CONNECTOR.
2answers
1999 dodge grand caravan 3.8l engine cooling fan won't turn on
dont think so,seem to remember a reostat somewhere at the bottom of the rad right hand side ,check for earth problems as well ,sorry if vague but i seem to be forgetting things as i get old .
1helpful
Cooling fan relay
its not an actual relay is like a relay assembly
Constant Control Relay Module (CCRM)
The Constant Control Relay Module is located at the LH front of the engine.
6helpful
2answers
Cooling fan not coming on
HI ,check, fuses, fan relay , temperature suitch located at cilinder head ,fan motor,( those are the most comon causes ) Good Luck
2helpful
2answers
Overheating
Electrical cooling fans not coming on due to bad sensor, fan relay, or bad fans. Check thermostat and coolant temperature, too....accordianman
Top Cadillac Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Cadillac Expert? Answer questions, earn points and help others
