Chamberlain 1/2 HP 41A5021-1B
SOURCE: Chamberlain Liftmaster Professional 1/2 HP
Okay...upon further inspection, my left spring has broken in two. Going to call around for some quotes to replace the spring. Thanks for the suggestions.
SOURCE: GARAGE DOOR OPENS BUT WILL NOT CLOSE AUTOMATICALLY
is bulb on motor flashing 10 times. then you have electric eye problem. otherwise, sounds like you need to increase down force a hair. adjustement is on logic board, right knob.
SOURCE: Chamberlain Power Drive 1/2 HP - motor runs but does not move chain
I have the same problem with the worm gear shaved. I bought the replacement part and replaced the worm gear. The door did not travel to the full distance between the limit switch. It hit the upoer limit, stopped. When I pressed the remote again, it only reverse for a short distance and never hit the other end of the limit switch. Any hints what the problems are?
SOURCE: Have a Chamberlain liftmaster professional 1/2
if you can open door Manually- find the FORCE adjustments-Not Travel. These might be "blue" in color. Increase the UP slightly. this adjustment in the cold weather is due to door hardware dry, lube rollers/hinges with wd-40 while door is down, lube every 30 days, keeps it moving quietly...
