Question about Car Audio & Video
Vizio sound bar remote buttons
What does TSHD MEAN HOW DO YOU CONTROL TREBLE & bass buttons seem to do nothing
    Habit-Forming:
    New Friend:
  • 62 Answers
Https://www.google.ca/url?sa=t&source=web&rct=j&url=http://cdn.vizio.com/documents/downloads/accessories/S3821W-C0/QSG_S3821wC0.pdf&ved=0ahUKEwjav96JzufWAhWp3YMKHVUyCr0QFghHMAo&usg=AOvVaw1tG0BTeyfXoyKxQuyJpRDI
Posted on Oct 11, 2017
Testimonial: "Very helpful thanks so much"
SOURCE:
mana666
  • 38 Answers
SOURCE: MX5021- Remote pod station w/volume, bass and treble control
yes
Posted on Dec 04, 2007
dontdodubya
SOURCE: Vizio L42HDTV10A sound problems
In my case, turning the surround sound OFF is what fixed the problem. The bass contibutes most to the perception of the location of a sound. If surround is ON without surround speakers connected, the internal TV speakers can only take the place of what would be the front speakers in a surround system. So turn surround OFF and set your bass preference wherever you want it. That worked for me.
Posted on Dec 16, 2007
danbusa
  • 185 Answers
SOURCE: I HAVE A VIZIO SOUND
Hello, Daniel Busa with Dish Network's customer service try these steps if the remote will program this will do it
Posted on Dec 29, 2010
  • 38 Answers
SOURCE: I recently bought a Logitech Harmony One universal
Great remote but not always easy to find right category for device.
Had a look for you and sure enough the device IS listed in data base under AMPLIFIER- then select amplifier again and input vizio for make and soundbar for model and click next.Problem solved!
Posted on Mar 02, 2011
rokksa12
SOURCE: Why is my Vizio VSB200 sound bar not having
my soundbar vsb200 no sound at all what im i doing wrong
Posted on Mar 24, 2011
How to adjust bass and treble and surround sound
On the Remote Control
Press
1 TONE
ToneControl•OFF-
2 Use selection button to select "ON".
ON : Allow tone adjustment (bass, treble).
OFF : Playback without tone adjustment.
NOTE
The tone cannot be adjusted in the direct
mode.
3 Press
to select an item to be set, and use
TONE
to select a setting value.
Bass : Adjust low frequency range (bass).
• -6dB - +6dB (0dB)
Treble : Adjust high frequency range (treble).
• -6dB - +6dB (0dB)
"Bass" or "Treble" can be set when "Tone Control" is set to
"ON
Oct 24, 2014 | Denon Avr 391 5.1 Channel 110 Watt...
Vizio sound bar 2.0 remote control not working
After only three days I would take it back, or at least take the remote back and try it on a different sound bar.
Jun 14, 2014 | Vizio VO47L 47 in. LCD TV
Bass treble
Tone control circuitry is not working. Also check to see if there is a switch on the receiver that renders those controls useless.
Nov 23, 2013 | Bose Lifestyle 25 System
Hi, what is philips mcd908 remote control code?
try 31266 31990 32311 32341 32459 (if it's a home theater system), or 12434 12205 12084 12056 11506 11389 11354 11340 11267 10675 10646 10539 10503 (if it's a DVD system) ...
assuming your universal remote has the equivalent (button) functionality to adjust bass and treble.
Nov 15, 2013 | Audio Players & Recorders
How do I use the remote to cont bass & treble for rxv-657 reeiver
No, Tone controls are on the front of the unit only. If your passing video thru the unit you can go into the setup menu from the harmony and adjust all the sound parameters that way "on screen" The only "EQ" capabilities are for the Center channel only. You can adjust "speaker size". "Large" setting will give you a little lower response. "Small" will crossover the speaker at "100hz" That's about as far as tone adjustment goes on this unit. Hope this helps
Jun 30, 2009 | Yamaha RX-V657 Receiver
Having Trouble Accessing Bass and Treble Controls
Only parametric EQ OR Bass/Treble can be active at a time. There is a option to set which one you want, refer to manual. Follow this- Adjusting Sound Setting Mode (long press "sound-mode" button) -> EQ SELECT-> select either P. EQ or B/T
Feb 18, 2009 | Clarion DXZ785USB Car CD/ MP3 Player
Having Trouble Assessing Bass and Treble Controls
Bass and treble can be adjusted via the sound menu only when the z-enhancer is set to off.
To change them while the Z-enhancer is on (B-Boost, Excite, Impact) choose the enhancer mode, then press the play/ent button. You can then use the up/down arrows to adjust bass and treble to -3 to +3
Feb 18, 2009 | Clarion DXZ375MP CD Player
Onkyo TX-SR606 bass treble settings seem to make no difference
I ran into the same issue and was stumped at first. Then I noticed somehow I had changed the sound processing to "Direct" which meant the signal coming from the source was bypassing all of the control in the receiver. All I had to do is select another option (press stereo for example on the remote) and kick it out of the direct mode.
Dec 21, 2008 | Onkyo TX-SR606 Receiver
Panasonic Projection TV
6.1. How to enter SERVICE 1
1. In sound menu, set BASS to MAX, and set TREBLE to MINIMUM.
2. Simultaneously press INDEX button on remote control and
VOLUME DOWN button [ - ] on the TV set.
6.2. How to enter SERVICE 2
1. Set the channel to CH99.
2. Press HOLD button on remote control.
Jul 24, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Car Audio & Video Logo
522 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
