When i plug my big screen in u can hear a the power kick in then 3 second later it kicks back out
  • 147 Answers
Replace the convergence ics.change both of them at the same time.
Posted on Jul 29, 2009
I have a 92 mustang lx 2.3 and it won't start. There is no fire at the plugs, and I can't hear the fuel pump kick on. The reset on the fuel pump is not popped out, so it is good. Any help woul
I would check the EEC relay and the fuel pump relay for power and ground signals first. Both circuits are controlled by the ignition key switch. The fuel pump should be powered for 3 seconds when you turn the key on.
Sep 29, 2012 | 1992 Ford Mustang
I have a problem with mq booster pump every 10 seconds kicks back and kicks on i am check the showers no leaks everything is ok please tell what can be a problem
Grundfos said the problem of on off every few seconds was air in the line. Then
later admitted it was the control unit. After replacing two units in 2 yrs I replaced
it with a standerd pump pressure switch.....Runs fine
Nov 17, 2011 | Grundfos MQ3-35 3/4 HP Pressure Booster...
I have a 2007 yz250f and the kick starter locked up if i remove the spark plug boot i can kick the starter over then put boot back on plug then i can kick it over and it will start then die about 20...
Hi, Motoracer05 for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
kickstarter Jammed 05 yz250 Yamaha 2 Stroke
Won start Kick start won even go down it like it stuck Banshee Repairs and...
YAMAHA YZ250 LC Owner Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Aug 24, 2011 | 2007 Yamaha yZ 250
Cannot set up ps3 on older big screen tv - no hdml - when using colored input wires - cannot find on tv using input - WII is on video 2 tried using the same plug ins - did not work - any ideas
You need to reset the video resolution back to standard by doing the following :-
Turn the PS3 off into standby (red light on)
Press and hold the power button. It will beep when you first press it, then beep again 5 seconds later. Release the power button when you hear this second beep.
The display will now reset back to standard definition.
Hope this helps
Oct 25, 2010 | Sony Playstation 3 (PS3) Console
I have a Phillips big screen tv and the front light is flashing red at all times and the picture will not come on the screen. This light is usually green when the set is on. What can I do to get it green...
I have the SAME issue and so far it seems to be an issue with the fan not kicking on.... I turn it on in the morning, as soon as you hear sound the red lights kick on and I shut it off... it takes a few seconds to shut down so stay close to your remote durring this process and as soon as the "red light" kicks in, turn it off, as soon as it's off, turn it back on... I have to go thru this about 30 times now before I can get the picture to stay on, but it eventually kicks in. Hope this helps!
Aug 24, 2010 | Philips GOGEAR SA6045 MP3 Player
Sony KDL-46V3000 Bravia LCD Black screen
It's not to complicated, in the newer TVs as well as other things, when you first turn them on the diagnostic circuits kick in [that the first relay you hear click] it sends a signal (low voltage) to all the circuits to check them and make sure there are no problems. If it gets the proper returns from each circuit it kicks out and the full power relay kicks in and powers your set up. This is done to protect others circuits that might be effected by a flaw in a different circuit. What started as a small flaw in a component has gotten worse with use which is normal. Your set is kicking the diagnostic circuits and they are detecting the problem and shutting it down. You have problems with your power board, if the diagnostics circuits were not in place and full power hit the set the power board could possibly put triple or more voltage to some section of another board, thus burning it out also. That's why they started using the diagnostic circuits on TVs, Computers have had them for years. Late model car - etc. I would take the power board out of it and go to shop Jimmy's and enter the part # which will be on the board and order me another one and pop it in and kick back and watch TV again. I don't know what a power board would cost for it but "shopjimmy's" carries high quality boards at a reasonable price. I do caution you on buying a refurbished board, they are tempting but I have never and I mean never seen one hold up very long. As a matter of fact I will not put one into a TV or anything else for that matter. So there is light at the end of the tunnel and it's not the train this time! I only work on the kind of TV that plug into the wall or run on batteries, therefore, I've seen a bunch of them in14 years. Don't worry about getting the wires mixed up because one thing about TVs is a harness or plug will only fit one place and that is where it belogs you can't cross them up.
Gillight
May 17, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
The fan comes on but the burner won't kick on and then shuts off
Check your fuel line for cracks and also the air line. Most likely is the CAD flame sensor, easy to change and only 3 bucks or so. Might also want to check all of your filters. Mine was doing the same thing and it was the high heat limit control and the flame sensor.
Jan 22, 2009 | Reddy R155D Utility Heater
Rear projection
Bad High voltage power supply. Clicking is the relay kicking to the supply which is no longer functional.
Jun 09, 2007 | Samsung HCN559W 55 in. Rear Projection...
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
