Question about Refrigerators
How do you shut off the refridgerator side of the model 561 Sub Zero leaving the freezer side operating
    New Friend:
  • 63 Answers
No can do! Both need to be on since they use only 1 compressor.
Posted on Jul 29, 2009
My sub zero model 561 refrigerator side is not working
The fridge side or the freezer side? not cooling, or just no lights? Nothing is cooling or lighting?
Sep 18, 2013 | Sub-Zero 561 / F
No cooling
Look at the back wall on the left hand side. "near the middle shelf"
If you find a wet spot or ice ball odd are you will need a Evaporator coil.
See if the fan is running when you open the door. By pushing the fan and light switch closed. "light will go out, Fan should come on" easy way to see if thermostat is telling the compressor to run"
Sep 03, 2012 | Sub-Zero 561 / F
I have a sub zero 561. The freezer works properly but the refrigerator is not cold enough. I turned temperature from 5 to 7 but no change
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 05, 2011 | Sub-Zero 561 / F
Refridgerator does not get cool enough
Buttom freezer Sub Zero. Replacing evaporator for fresh food section.
Mar 31, 2010 | Sub-Zero Bottom Freezer Refrigerator
Sub Zero 561 Refrigerator side is not cooling." the freezer side is working perfect.."
pop the top panel and clean your condenser,this is the most common problem,other than that it could be your compressor or refrigerant leak.this model i believe is two separate systems so one will not effect the other/. good luck!
Jan 17, 2010 | Sub-Zero 561 / F
I have a 20 yr old Sub Zero 561 side by side. The
If it were not a Sub Zero i would say its time for new. It sounds like it needs a service call and shot of gas and all will be well for many more years.
Sep 01, 2009 | Refrigerators
My 561 refridgerator door gasket is torn and needs replacing. How do I remove the old one?
I sure look carefully for solutions - some clown just replaced mine for a mear - get this $750 dollars. I assume I've been ripped off, my bride handled the call - don't use REO appliance -
Jul 14, 2009 | Sub-Zero 561 / F
NEED ORIGINAL DOORS ON MY 561 SUB ZERO LOOKS LIKE DOORS ON FRONT
Given the model serial number I could get your decorative panels. The door itself is a framed door and designed to take a 1/4" insert. You can have new panels made if you have changed the cabinets, order stainless steel panels or put another material of your choosing. If you would like the more about the panels reply with mod and ser number which is in the freezer door jamb at eye level. Open the door past 90 degrees and look in.
Jan 19, 2009 | Sub-Zero 561 / F
Refridgerator door
a lot of the sub-zero doors are good and heavy duty, but the plastic shim under the hinge wears and can drag when you go to close door, usually a simply repair to find a washer for the door hinge.
May 16, 2008 | Sub-Zero 700TCLH Bottom Freezer...
Refrigerators Logo
57 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
