Question about SanDisk Sansa e250 MP3 Player
The music cuts in and out...I have already changed the headphones
I think it must be the connection as I can jiggle it and it will come back on but it won't stay on.
  • 55 Answers
As i understand what you are saying is the fact that you wiggle your headphone connection so that the sound will come on there are a few answers to this problem
  1. your headphone jack in your mp3 could be the problem and to solve that you could
  • one go to a tech specialist and have them fix it
  • two - you could put a peice of aluminum foil in the slot on the subjugated side and slide your headphone into the slot wile holding onto part of the aluinum foil
2. the headphones could be the problem and you will need to get a new pair of headphones ]
hope this helps you have a nice day
Posted on Jul 29, 2009
Audio static
That's pretty normal with built in connectors. For a workaround grab a cheap USB sound card from eBay or somewhere else. It worked for me.
High Quality External USB 2 0 3D Virtual 7 1 Channel Audio Sound Card...
Apr 08, 2017 | Lenovo IdeaPad Yoga 11S Touch - 59370514 -...
I WHICH TO PURCHASE SOME HEADPHONES FOR SRF 59
follow this steps and fix it. God bless you
    • 1
Locate the faulty connection along your cord. Plug in your headphones and play sound through them as you jiggle the cord at various points to locate what part of the cord is cutting in and out.
    • 2
Cut the cord using wire cutters an inch or so past where the fault in the cord is. If this is at the connector, cut the entire connector piece off. If it is near the headphones, cut off enough to eliminate the faulty section and still allow the cord to be reconnected.
    • 3
Strip the end of the cut cord. There are three wires in the cord: the left channel, the right channel and the ground. The left and right normally are colored, and the ground is bare.
    • 4
To repair a poor connection where the cord meets the headphones, match the wires with the correct leads coming from the earpieces and twist them together. Wrap the wires with electrical tape.
    • 5
To repair a bad connection at the connector jack, acquire a new 1/8-inch connector and attach the cord's inner wires to the appropriate points on the connector. Connect the left channel wire to the tip, the right channel wire to the ring, and the ground wire to the sleeve. Solder all the wires in place.
    • 6
Connect the headphones to a sound source and test for proper function. Jiggle the cord at the new connection to make sure it is secure and does not cut in and out.
Oct 27, 2013 | Sony Audio Players & Recorders
One of my ear phones is not working
Check the cable at both ends, at the connection to the headphones and the jack. Try jiggling it around a bit while you have music playing to see if you have a loose connection. If this is the problem a temporary fix is to tape the cable up in the position where the wires inside are connected.
Mar 28, 2011 | Sony Audio Players & Recorders
The right side of my BOse over ear headphones has stopped working. Is there any solution to the problem or do I have to buy another set? Thanks for your assistance.
If twisting and jiggling the connection to your music player produces no results, then you're probably going to have to replace them.
CHECK FOR A WARRANTY even if you didn't buy an extra one, they came with one from the manufacturer.
However, assuming your warranty is expired and you don't mind cutting the cords, you CAN check to see if there's a short in the wire somewhere. You would need a multi-meter to test connectivity, a pair of wire strippers (or a sharp knife and steady hand), and electrical tape just in case you get lucky.
You would basically cut the wire connecting the right ear to the 1/8" jack, leaving at least a good 6-8 inches between your cut and the ends of the wire (so you have something you can splice back later). Then you use the multi-meter (set to test resistance) to check the section you cut out for connectivity: place the red terminal at one end of the wire and the black at the other. If the needle moves, the wire is fine. If not, then you've found the problem.
If you have enough wire left after cutting out the damaged part, then you can just splice it back together and tape it up. (It won't be pretty no matter what.) If not, the easiest thing to do would be cannibalize part of a cord from another pair of cruddy headphones.
BUT, let me say again: There is very little chance of this working. You may just end up cutting them to pieces and wasting time. Only attempt this if you are sure they are trash otherwise.
Mar 21, 2011 | Bose On-Ear Headphones
I have a Roland FP 1 digital piano, serial #AL21141N. It has gradually quit putting out sound through the speakers. At the onset of the problem, I could fit it by jiggling the 1/4" speaker plugs,...
I first would suspect the switches on the eadphone jack. Normally these cut off the speakers when headphones are plugged in. These jacks and the switches are really weak, poorly made, and easily broken, especially if headphone cord gets yanked.
Jan 14, 2011 | Roland Digital Piano FP4 Black With Stand...
My earphones suddenly stopped working all of a sudden. The sound in the left ear cut out and when I jiggled the wire and the connection a bit, the sound cut out completely. Now when I jiggle the...
Cutt the 3.5mm ********. You will need to cutt the cable about 10cm from the plug end to make certain you clear the damaged area. Buy a new Jack. You will need to solder the wires on. You will find when you have baired back the cable two coloured wires and two earths. The earths fit together on the metal flange that comes out of the main body of the plug. The coloured wires go on the the two smaller flanges (left and right channels). If you get them wrong way round reverse them you won't do any damage. Make certain the earths don't come into contact with the R & L channels wires or terminals and the left or right don't touch each other. The T shaped end on the large flange is to grip the cable body, bend the tabs to grip the cable.
Mar 20, 2010 | Skull Candy Lowrider Headphones
No sound from speakers
Believe it or not, not all speaker plugs, even if they are of the same size are NOT made the same.Some times the "male" PLUG pushes into the "female" socket in such a way that it makes NO connection or does not make the right connection causing the headphones not to work.
TEST: play music that u can hear through the internal laptop speakers, and while the music is playing, plug in the headphones.
The internal speakers SHOULD cut out, and under normal conditions the music should pass through the headphones.
If the speakers cut out and the headphones don't work, your plug is damaged.
If the speakers DON'T cut out after u plug in the headphones, your plug is open.
Depending on the audio circuit, your audio amp. inside the laptop is going to get damaged.
It depends on the WAY the audio circuit was made.
May 15, 2008 | Audio Players & Recorders
Headphone jack
I had the same problem on my e200 series after maybe 8 months of use. If you apply some pressure from the side of the plug, the sound should come back. Wiggle it even. If this is the case, there is a connection problem. If under a year old, RMA it with the company, I just got mine back from the same issue. I have also read that if not under warrenty, you can take aprt the player and apply a shim (piece of cardboard the thinkness of a matchbook cover) inside to fix. There are other posting on the web that describe this in detail from people who claim to have done this sucessfully. Cheers
Sep 13, 2007 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
189 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
