Question about Twinhead DURABOOK D14RY
My durabook seems to get very hot to touch. I hear the fan running. Is there more than one fan..or is that even the problem?
    Problem Solver:
  • 10 Answers
They tend to get hot, its not a problem unless it starts to cause problems such as random crashes or shut downs, If its an old notebook then try using a can of compressed air to get rid of some dust. Either way what surface are you using it on? because id only use it on a flat hard surface like a table if not already and use something to raise the back of it by an inch or two more then what the rubber feet already do. Most people will assume laptops will run fine on your lap or bed etc how ever this is not the case, this will cause more heat and premature problems. I've made something for mine so i can use it on my lap when im in bed, its a piece of flat thin plywood around 22inchW/15inchL for my 17' lappy with halve inch rubber door stops glued in place where my laptops rubber feet would go, this reduced my overall heat from hot to touch to barely warm in fact i think the heat im feeling now is from where my hands have rested on the laptop :) laptops will run hot strait from the box if not well ventilated.
Posted on Jul 29, 2009
Why are the high side and low side press the same
There could be a couple of answers:
1.If the compressor is running, the internal valves may be broken. No valves, no compression = no pressure change. 2. If the compressor is running and you hear a hissing sound, it's in 'by-pass' because of an overheating situation. Will be very, extremely hot to the touch. 3. Is the compressor even running ? Just because the fan is spinning, doesn't mean the compressor is running.
Jul 10, 2014 | Goodman CKL30AR30 Air Conditioner
Twinhead durabook n15r notebook
I would not put the money into a new motherboard, it would be expensive and in my view better to replace with new laptop especially when you consider the 1 year warranty that is provided ready to go.
Mar 21, 2012 | Twinhead DURABOOK N15RB Notebook
Top of dryer is too hot to even touch!!
Hi crhaun79...
If your dryer is running that hot then:
Check and clean if necessary your vent hose.
If you vent hose "seems" to be clean then,try running the dryer with the vent hose off and see if the dryer is not running hot anymore.
Make sure your lint screen is in place and has no tears or holes in it and is still firmly attached to the frame.
If you are running too hot you are not moving enough air thru the system.
It could be that the fan blade is plugged up.
The problem could be a large lint ball build up in the center of the fan or a sock,thin pants,a pen,etc. that has gotten into the fan by falling down the hole where the lint screen is normally inserted.
You have to find the air restriction to solve the problem.
It also can be a loose or worn out blower wheel/fan.
Please take time to rate me.
Aug 14, 2011 | Frigidaire Dryers
Is not making ice and is very warm from middle to top on both sides of my side by side kenmore 106.56932600
Greetings,
is there any ice frozen on back wall of freezer panel..if not, check to see if all the fans are operating..does the divider between the refrig and freezer doors seem real hot? if so, look for a stopped condenser fan motor....now, does the compressor run? sometimes you hear the condensor fan running and think the compressor is running...these things will click every fives minutes if not running..So, listen carefully, touch the compressor..is it hot? is it hot and clicking? if clicking, UNPLUG and remove the relay off compressor..shake it and if bad..it will rattle. Replace the relay if bad. The compressor could be bad and be clicking as well..anyway, let me know if it isn't it
Bruce Denton
Jan 24, 2011 | Refrigerators
New dehumidifier runs very hot...back of unit is extremely hot to the touch, and the space around it becomes uncomfortable to live in. With hot summers like this one (and maybe future ones?) we don't need...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Sounds like the compressor is toast...
There can be many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Aug 23, 2010 | Haier 45-Pint Dehumidifier
The doors are scorching hot to touch on my Maytag 2454. It's always been warm to touch, but all of a sudden it is too hot to even touch. It is in the center part of both doors, along the door seal area and...
It's usually caused by the condenser fan which is underneath around back. If it's not running when the compressor runs it will cause the problem you describe. You will need to remove the cardboard backing on the back of the fridge to access the fan.
Apr 22, 2010 | Maytag MSD2454G Side by Side Refrigerator
My fan is running constantly computer seems
Yes, the fan should run continuously else the processor will get toasted. It get very hot without the fan even when the PC is not doing anything visibly.
Dec 15, 2009 | Acer Aspire M1201 Athlon X2 320 Gb PC...
On third compressor. Had the temperature sensor
With the AC on, the fan will come on to help the ac codensor. Why your compressor keeps crapping out is definately something to look into. If your AC is overcharged the head pressures can get pretty high and if the oil is low, that would not help either.. Good Luck.
Aug 03, 2009 | 2006 Chevrolet Equinox
Overheating
When you mention the radiator having a hot upper in pipe and a cool bottom out pipe tells me that the coolant is not moving around the engine. This could be down to a water pump not working, blocked radiator, thermostat not opening. The bottom hose should be cooler than the top hose but once the engine is up to working temp which is around 85/90 degrees c for an audi the bottom still should be farly hot to touch. Hope this helps
Jun 01, 2009 | 1996 Audi A4
Twinhead DURABOOK D14RY Logo
158 people viewed this question
Top Twinhead Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Lee Durbin
Lee Durbin
Carl Rick
Are you a Twinhead Computer and Internet Expert? Answer questions, earn points and help others
