Question about Emerson Microwave Ovens
My model MW8991SB, serial# 6072922MM has quit on me. The light went out when I pushed the #1 button. I moved the plug and the light came back on and again the light went out when I pushed #1 button. HELP Sharon Wilber 508-951-7893
  • ymcakid Jul 29, 2009
    Let's hear a second opinion please
    Thank you for trying to help me.
    I did move the microwave to another counter and used a different socket. I tried other buttons but it never came back on
    Sharon
    President:
  • 2,559 Answers
The control board is faulty
Posted on Jul 29, 2009
  • 3,037 Answers
Most like a bad control panel/board with the symptoms that you are describing. Unfortunately the cost of replacing this part is about the cost of a new microwave, so you would actually be better off replacing it rather than fixing it but then again if you feel the need to replace the part, you can find it on the following website link http://www.repairclinic.com/Emerson-Parts?s=t-MW8991SB-%3d%3db162&z=100
If replacing the part wouldn't fix the problem, you can return the part within 30 days. Let me know how this turns out.
  • Benjamin Patri
    Benjamin Patri Jul 29, 2009
    The control board is almost always the problem in this case unless you find a burnt fuse which is what you should also check, they will be blackened if you have a bad one or will read infinite resistance if you use an ohm meter to test the fuses.
Replacement glass turntable
Go to www.ebay.com Type make and model of microwave oven, refine search to plate.
Jul 11, 2012 | Emerson MW8991SB Microwave Oven
On the Emerson MW 8992 SB microwave oven how does one change power settings,e.g., from 100% to 50%?
Emerson MW8991SB 0.9Cu.Ft. 900 Watt Touch-Control Microwave Oven, Stainless Steel has the same face as your microwave. I own one of them Look at the bottom three uo to the left it says (POWER) push the Power button it starts at 10 and goes to 1. 10 being the highest and 5 being half power and 1 being the least. then select the amount of time you will cook by punching in the numbers.
Jan 17, 2011 | Emerson Microwave Ovens
My turn table doesn't turn on my microwave (Emerson MW8991SB)
Replacement of the turntable motor should be carried out by a qualified appliance repair service.
But here is a basic methos if you are mechanically minded and have electrical safety knowledge.
The motor assembly is fixed to the base of the oven usually with two screws and access is obtained usually by removing the inspection plate directly beneath the motor. It is usally a plug in synchronus motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate, sometimes it must be cut out with sharp cutters, and disconnect the motor. Remove the motor and go and get a new one. Fit the new motor and fit the inspection cover back on the base by turning it to fit and using an extra screw fix it then put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Jan 04, 2011 | Emerson MW8991SB Microwave Oven
The microwave seems to be stuck on delay
thats what the express does its a one button start it
there s nothing wrong with the unit it is doing exactly what is programmed for what you are pushing
Oct 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Need a manual for MW8991SB
Hi
Thanks for using FixYa. You can view/download the manual for your Emerson MW8991SB Microwave from this link--
Emerson MW8991SB Microwave Manual
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 06, 2009 | Emerson Microwave Ovens
Whirlpool MH7140XFQ-1 microwave no longer heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
kggk
Apr 24, 2009 | Whirlpool MH7140XF Microwave Oven
JMV8208 BAW Model 30" Jenn-Air Convection/Micro combo
have a good look at front to see reset??.press it once it comes back on unplug from the wall and & open it up and go to the part and give it a good clean with wd40, check the push pad for ware & tare dirt gathers and builds up
Mar 09, 2009 | Jenn-Air JMV8208A Microwave Oven
I have a recently purchased microwave since CHristmas. It was working wonderfully. Recently, I moved and plugged the microwave back in. THe light is on but will not program anything. I tried to plug into...
We have the same model. It's a piece of garbage. I loved the retro oval window and all and the size was perfect for our space. Then, the paint started chipping off the inside front, the timer started working intermittently, and the oven would just quit in the middle of the cooking cycle! Today, it finally just up and died. I unplugged and replugged it. No go. Finished cooking on stove top. My suggestion? Do like we're going to do and go buy another microwave...not another GE!
Good luck! Peacenikkie@charter.net
Jul 06, 2008 | Microwave Ovens
Microwave Ovens Logo
29 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
