Question about General Electric GE SmartWater Household Water Filtration System - GNWH38F
My GE smartwater hot water heater has no pressure. what are some troubleshooting thing i can try?
  • snap101
    snap101 May 11, 2010
    is it at all your fixtures or only one?
  • 297 Answers
Try to open and close the valve at the unit,this shut off valve may have gone bad,replace it this may help.
Posted on Jul 29, 2009
Not enough hot water ge smartwater water heater gas
1) Copy following links:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
2) Low temperature setting, extremely cold incoming water, Water leak or broken pipe running hot out of tank, crossover caused by bad faucet cartridge or bad recircirculation check valve,, bad gas control valve thermostat.
Feb 19, 2013 | General Electric GE SmartWater Household...
GE SmartWater Hot water tank. Water heater will not stop heating.
Hello Anita:
1) For gas water heater: Turn off gas to heater:
http://waterheatertimer.org/images/Gas-water-heater-89-valve-2.jpg
2) For electric water heater: Turn off circuit breaker.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#veryhot
3) For gas: Copy following link to identify gas control valve thermostat, and troubleshoot by type of gas control.
4) For gas: Gas control valve thermostat has probably gone bad.
5) Add comment and give clear description of water heater.
6) Call plumber.
Feb 17, 2013 | Water Heaters
GE Smart Water Hot water heater 40 gal will not stop heating water.
1) For gas: Turn off gas to heater:
2) For electric: Turn off circuit breaker.
6) Call plumber.
Feb 17, 2013 | General Electric GE SmartWater Household...
I have a ge smartwater filter system #GXWHO4F. My problem is that since system was installed the water pressure and the water volume drops alot when more than one faucet is turned on.The filter system...
Filters always reduce pressure.
You can add a pressure tank between filter and tankless.
Tankless are sometimes like bowling on a ship.
Add a comment saying how you fixed problem.
Fix most tankless problems yourself, same day, all brands for $330.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Absolutely feel obligated to upvote the free help.
Or take advantage of fixya paid help.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 03, 2011 | General Electric GE SmartWater Household...
My hot water heater is whistleing when i turn my hot water on it stops
make sure yor temp is set at 120 and make sure your water pressure is at 75lbs
Jun 08, 2009 | General Electric GE SmartWater Household...
This is a new whirlpool hot water heater.Pilot lights, burner fires, water heats up to temp. burner and pilot both shut down. Unit has to be started manually each time
LP OR NAT GAS , IF IT IS LP CHECK GAS PRESSURE @ TANK AND MAKE SURE NOT TO HIGH , IF NAT STILL COULD BE THE PROBLEM HAVE THE GAS COMPANY CK PRESSURE
Feb 22, 2009 | General Electric GE SmartWater Household...
General Electric GE SmartWater Household Water Filtration System - GNWH38F Logo
287 people viewed this question
Top General Electric Water Heaters Experts
Paul Carew
Donni Steen
Are you a General Electric Water Heater Expert? Answer questions, earn points and help others
