Question about kawasaki Audio Players & Recorders
Kawasaki HT1210 Home Theatre System
My sound does not work properly, all speakers are connected but sound is very low. After 5 mins of playing sound goes away, power has to be turned off and stay off for a few minutes b4 it starts again. What could be the problem and what can i do? Help!!
5 Suggested Answers
  • 93 Answers
SOURCE: home theatre problems sound
Did you try to connect AUDIO OUT from your TV to AUDIO IN on your package?
Posted on Oct 04, 2007
SOURCE: Please help with getting 5.1 sound from my TV!
You must run a Digital Optical cable from your PS3 to your reciever. Then press your function button on your recievers remote until you see SAT/CABLE on your recievers display. Next go to your PS3 settings and go to Sound settings, then Audio Output settings, and select Digital out (OPTICAL) then your done. This is the only way to get true digital sound from your PS3 to your reciever.
Posted on Oct 18, 2007
SOURCE: Home theatre but TV without audio outlet
I would suggest that you smash
Philips HTS w/a hammer!
I had better sound from TV alone! Only 2 speakers put out sound from TV. Recordings from DVR can not be heard very well w/all volumes at max. System sucks! You get what you pay for! $2500 LCD TV sounds worse w/Philips HTS than my son's $300 TV! ALL cables hooked up as instucted!!!!
Posted on Jul 09, 2008
SOURCE: Just bought a Philips home theatre system HTS3544 low sound?
You may also need to change the speaker set up. Go to DISC setting (one of the top selections on the remote) make sure you have no Disc in the DVD player. When in this mode press setup on the remote. On this menu you will have a option to adjust the speaker volume.
I had to increase my speaker volumes to get better sound. This setting is not accessible if you try to do the set up in other than DISC setting. Be sure to check the SURROUND setting. The SURROUND button on the remote will toggle between stereo and surround as stated in a previous post.
ST
Posted on Mar 27, 2009
How do I make my TV play in Telefunken 5.1 Home Theatre THT-6000HDMIA speakers?
Does the TV and system have either a coaxil or optical sockets? If it does then I would connect them by one of these. That should trigger the sound. However it might work via the HDMI if you have selected the system to pass digital signals via that connection.
Oct 23, 2015 | home Audio Players & Recorders
I have got Philips Home Theatre 5.1 (DSP 25000) , but it is not giving expected sound. Right Rear speaker and Left Fornt Speaker are not giving any sound . Please let me know the solution. I have connected...
Firstly make sure you have connected the speakers to the main system in an proper order. Certain system's have the name of the speaker's mentioned at every output line which is at the rear of the system. If you would connect the wrong wires then it eventually would not play the sound. once this is done make sure that the wires of each speakers are split into two at both the ends. They are normally coded in red and black colours at the tip of the wire. Check if the red of the wire is connected to the red of the system and so on for all the speakers. So try removing all your connections and do it all over in a proper way.
Sep 12, 2010 | Philips HTS3450 System
No human sounds when playing dvds.
sound like the center channel is out
either bad connection at speaker or receiver is not putting out sound on center. A quick swap of speakers at receiver end will tell you if it is the latter
Apr 13, 2009 | Audio Players & Recorders
Sony Model DAV ? SB 500W Home Theatre System
Please check at rear of TV for Digital Optical IN port as home theater should have optical out port at rear. If you got any optical in port in TV, just connect optical wire between TV and home theater.
2nd option is check Line Out pins at rear of home theater system, if found, hook red-white RCA cable there and put it to same input in TV where you hooked Video (composite or component) cable.
Let me know the results to help you more.
Jan 07, 2009 | Sony DAV-SB500W System
Panasonic 50? Plazma TV TH 50PZ 800A + Sony Model DAV ? SB 500W
that is possible
the home theater has so many in puts on your dvd and out puts.
there is a way
1 you can buy a vedio/audio converted to rf signals, this will mean both signals entering tv using rf.
2 get your vedio out from dvd and audio out, feed that to a converter, vedio in and audio in okey
How do you get DVD player SOUND to play through the TV speakers
plug the stereo headphone jack to your dvd headphone output then connect it to your tv audio/video in and press the tv/video switch in your tv remote control.
LG dvd player connected to 5.1 home theatre
Dont now your sytem but check Home theatre sytem must be switch to 5.1 display and not dvd display. if stil no sound check in setup off dvd for soundsetting like PCM, RAW , 5.1etc and select each one till you get desired sound.
Presume your conections from dvd to hometheater is conected 5.1 cables or 1 digital cable and not stereo(2cables)
Jan 05, 2009 | LG RH177 DVD Recorder/HDD Recorder
I have a 50 inch viera plasma tv and just got a 1200 watt home theatre system product number SC-PT960 and have absolutely no idea how to hook it up properly. The instructions in the book are confusing me...
Assuming the TV is up and working on its own, here's the simplest approach:
Find the the Audio Out from the TV - either an optical connection or a dual RCA Cable (probably came with the TV) and connect that to an Input on the home theatre receiver. You'll need the right cable depending on whether RCA or Optical. That gets you Surround Sound into the Receiver.
Then, connect a cable from each speaker to the marked terminals on the back of the receiver -- Front L/R, Rear L/R, Center, Subwoofer, etc.
Check out your speaker connections by trying a radio station - should play through the front speakers OK. Then switch to the input you connected the TV into. Once you get the TV Audio playing through the receiver, you can go to your TV setup screen and turn off the internal speakers on the TV.
Hope this is enough to get you going.
Feb 18, 2018 | Panasonic 1200W 5.1-Channel XM-Ready Home...
5.1 Home Theatre - PC
Its due to 2.1 channel sound input from your PC. Your Laptop supports only 2.1 channel sound so all the 5 speakers cant be played at a time! You need 5.1 channel input to work all 5 speakers
Dec 07, 2007 | Bose 701 Main / Stereo Speaker
172 people viewed this question
Top kawasaki Audio Players & Recorders Experts
Tom Chichester
Are you a kawasaki Audio Player and Recorder Expert? Answer questions, earn points and help others
