Question about Lexmark Office Equipment & Supplies
I have a Lexmark X2600. The black is printing grey. Two new cartridges were put in.
    President:
  • 2,185 Answers
The printing preferences must have been set to print in grayscale. Try checking on the preferences.
Posted on Jul 29, 2009
How do I get my Lexmark X2600 to print? I got a message telling me that I would soon have to replace the black ink cartridge, and it just stopped printing. I put a new cartridge in, and it still will not...
Try to re-seat the cartridges into the printer. Remove both cartridges from the printer > re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds > when the printer printer turns on, firmly re-insert the cartridges into the printer. Try to print a document again to verify that the problem is fixed.
You can also try to manually clean the cartridge nozzles. Wipe the cartridge print nozzles with a slightly moistened soft cloth to clean it from possible dirt and clogs. Re-insert the cartridges and try to print a document again.
Oct 23, 2011 | Lexmark X2600 All-In-One InkJet Printer
Im trying to print a black and white document but it wont let me print because my color cartridge is missing
The Lexmark X2600 requires both cartridges to have ink in them to continue printing, even if your printing in "black and white". To print true black, you actually use some of the color ink. , Leaving the color cartridge empty or dry isn't good for the printer. It can lead to poor print quality issues.
Sep 22, 2011 | Lexmark X2600 InkJet Printer
I want to use a black only cartridge, it prints an alignment page that is black only, obviously. When I put it in then to scan it (and yes i have it placed correctly in the scanner) it gives me an error...
The diagnostic setup program assumes all the parts are loaded, including color ink cartridge.
In normal printing you can set the preferences for black ink only, no color in the Lexmark control panel software.
Apr 15, 2011 | Lexmark X2600 InkJet Printer
I installed new ink cartridges in my Lexmark X2600 printer. Print quality is faded. Cleaned cartridges twice. Print quality is still light. How do I fix this?
Go into printer properties and make sure that you don't have print quality set to draft. Try normal or best and see if that makes any difference.
Feb 20, 2011 | Lexmark X2600 InkJet Printer
What are proceedures for replacing print cartridges for Lexmark X2600 ink jet printer?
Perhaps the Lexmark X2600 User's Guide will be able to help you. To download it, click on this link: http://www.lexmark.com/publications/pdfs/2007/2600/v7649663_en.pdf. Scroll to Removing used print cartridges, Page 45, for instructions on how to replace print cartridges.
In some cases, the ink cartridge carrier won't position itself in the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the white tape in the middle inside the printer. The other end of it is connected to the carrier. Gently slide the carrier to the center. Load the cartridges. Close the cover. Plug the printer back to power source. Hope this helps.
Jun 11, 2010 | Lexmark X2600 InkJet Printer
How to refill a lexmark x2600 black ink cartridge?
Are you using a factory new ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
Don
Nov 05, 2009 | Lexmark X2600 InkJet Printer
Can't print black and white only with Lexmark 2600!
Hi MikeC,
Most of the time this is due to the black cartridge being out of ink. The Lexmark uses all the colors to create black when the black ink cartridge runs out, but won't let you print black because it is essentially saving ink.
Hope that's the reason and it isn't the printer failing. Good luck! :)
Sep 23, 2009 | Lexmark X2600 InkJet Printer
Lexmark X2600 printer will not print in black and white
you may check your only black ink cartridge
longer time less using cause ink chanel(holes) dryer, could not print out even refilled.you may take out the ink cartridge and put it's surface of bottom (just touch ) in the clean water 1 -2 Hrs, then set back and test it. still not fixed, you also need to do same thing if your print head is separated from your ink cartridge
Feb 06, 2009 | Lexmark X2600 InkJet Printer
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
