Question about Timex T5G341 Watch for Women
I need to remove a link from a solid link bracelet on a Timex Chronograph Expedition watch. The directions say to remove screws but there are no significant screw heads on the bracelet that a very small screwdriver can grasp on to. Any ideas?
  • 2,334 Answers
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have the pins instead of screws.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Jul 29, 2009
How do I remove a link from SNDD51P1 bracelet
On the back of the bracelet you will see arrows. This is the direction to push out the pins between the links. This is best done on a folded towel to prevent slipping.
You need a fine watchmakers screwdriver to gently push out the pins. Remove the excess links, reconnect and push the pins back in the same direction as they come out. If you need more than one link out then do it evenly at each side of the clasp.
Take care in case any tiny spring collars fall out of the centre or side of the link. make sure these are put back as they hold the pin in tightly.
www.yorkshirewatches.co.uk
Dec 28, 2012 | Seiko SNDD51P1 SNDD51 Gents Chronograph...
How to remove links from invicta sea spider polyurethane bracelet
You should use two extremely small flat head screw drivers to remove links on Invicta polyurethane watch bands. The smaller pens on the polyurethane watch bands have a notched cap (tiny screws) on each end .You must use one screw driver to hold the pen cap (screw) steady and the other screw driver to turn the cap (screw) counter clockwise. You only have to remove one notched cap (screw). These caps (screws) are very small and you should be careful not to lose them. Once you removed the cap (screws) you can use a small screw driver or paper clip to push the pens through the links. You should repeat this til you remove the desired links.
Nov 24, 2011 | Invicta Sea Spider Chronograph...
I WANT OPERATING MANUAL FOR Timex Expedition Chronograph T49742 Watch for Men
There are two ways to find the user manual for your Timex watch.
  1. Find your watch on the list below and click on the language link for your manual.
  2. Find the 3-digit module number located on the caseback of most Timex products and click on the corresponding language link for that number in the Module Table.
If you are still unable to locate your user manual, you may emailTimex Customer Service or call us toll-free at 1-800-448-4639.
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Nov 24, 2010 | Timex Expedition Chronograph T49742 Watch...
How do I release the links to remove them - there is a screw head on each side - they seem to revolve together without releasing
Watchmakers are using special tool to release double sided bracelet screws. As you do not have it, the only option is to use two screwdrivers at once - each on other end of the screw.
It will be quite tricky, but you will definetely sucseed after a few attempts.
Rate, please.
Jul 19, 2009 | Timex Expedition Adventure Tech Compass...
How to replace battery for Timex expedition
Remove the four screws that hold the battery cover on the back of the watch. Remove the 3 very small screws that hold the battery in place. Remove the battery from the battery holder. The piece that the 3 small screws were removed from seperates from the 3 volt 2016 energizer battery. Replace the battery with a new one. Re-install the battery holder to the watch. There is a small tab on the lower left part of the battery holder that needs to be depressed to activate the watch. Depress it and look at the face of the watch to make sure it is activated. The watch will need to have the time, date etc reset but you should now be able to see that the battery is working. Replace the battery cover and reset the time and date as needed.
May 12, 2009 | Timex Expedition 84601 Wristwatch
Timex expedition
HI
HERE IS SOME STEPS FOR YOUR DOUGHTS......
Set the chronograph. Push the bottom left button until you see the word "CHRONO" on your watch. Press the top right button to pick "Lap" or "Split." Press the top right button to start or stop the timer.
Press the bottom left button to see your lap or split time. Press the bottom left button to pause the timer. Press the top right button to start again. When you're finished, press the bottom left button to stop timing. Push it again to reset it your chronograph to zero.
THANK YOU
Dec 12, 2007 | Timex Digital Expedition watch
Timex T5G341 Watch for Women Logo
143 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Mark Schmit
Mark Schmit
Carol
Level 1 Expert
Are you a Timex Watch Expert? Answer questions, earn points and help others
