Question about Kitchen Ranges
My gas Kenmore electronic oven is 25 degrees low. Which 2 buttons do i press at the same time, to get me into calibrate mode ?
  • 3 more comments
  • keylargodeer Jul 29, 2009
    I had a sears service man come out before and he pushed 2 buttons at the same time, to get it into cal mode. I just can't remember which ones.
    I finally found some info on the oven. sorry it took so long. The model # is 911.30465792
  • keylargodeer Jul 30, 2009
    Your solution did not work. I have seen a Sears technician push two buttons at once to get to the calibration mode. I just can't remember which two.
    This does not work. I have seen a technician from Sears push the two buttons at once to calibrate my 911 model, but i can't remember which two.
    Thank you very much for your time.
  • 15,935 Answers
Press bake & set the oven temp to the highest possible temperature. Press & hold “bake” for 10-15 seconds or until it beeps & the display shows 00. Use the temp arrows to adjust the temperature up or down to the desired level. Press start to log the new temp into the control.
Please accept this answer to remove it from the work queue.
Posted on Jul 30, 2009
  • 1 more comment
  • blueextc3221
    blueextc3221 Jul 30, 2009
    For some Whirlpool/KitchenAid/Kenmore ranges and ovens
    1. Press BAKE button for 5 seconds. The default or a previously entered
      temperature offset will show.
    2. Press the TEMP 'up' arrow to increase the temperature in 10°F or 5°C
      increments*.
    3. Press the TEMP 'down' arrow to decrease the temperature in 10°F or 5°C
      increments*.
    4. Press START to save the temp. adjustment.
    *A maximum offset
    adjustment of ±30°F or ±15°C is possible.
    (To switch between Fahrenheit
    to Celsius, try pressing and holding the "broil" button for 5 seconds.)
  • blueextc3221
    NOTE: 278 and 911 models that are Non Self Clean-Cannot be calibrated.
  • blueextc3221
    CLICK HERE for your manual in PDF format.
    See page 27 for adjusting the thermostat.
    BAKE + BROIL for 3 seconds.... until SF appears.
    Then press BAKE
    A factory set number will appear (usually 00)
    Use up or down temp buttons to adjust to desired differential.
    Then press start.
    Thanks
    :D
    Please accept once you get it
  • 3,037 Answers
Electronic controls can usually only be adjusted a maximum of +/-35°F. If the oven temperature is out more than that, some part of the range is usually defective and needs to be replaced to correct the condition. The oven sensor is the most likely cause of incorrect temperature readings, the control itself is only rarely the problem if this is the case or if the calibration doesn't seem to help.
General Calibration Directions for Kenmore Gas Ovens
  1. Press BAKE
  2. Select a temperature of 550
  3. Quickly (within 5-seconds of setting 550) press and hold the BAKE button approximately 5-15 seconds until "00" or the previously entered temperature adjustment is displayed.
    Pressing longer could cause an F0, F1 or F7 error to be displayed.
  4. Press the UP/DOWN arrow button or turn the set knob to change the oven temperature in 5° increments to a maximum of +/- 35°
  5. Press the CLEAR or OFF button to return to normal operation.
If the oven directions above don't seem to apply, please post the model of the oven in question so I can further look into any calibration method that may be different for this specific oven. Let me know how this turns out.
Benjamin
Posted on Jul 29, 2009
  • Benjamin Patri
    Benjamin Patri Jul 29, 2009
    Please post the model number then so I can find the right buttons then to push on this machine
Why doesn't it heat to set temperature?
Hello. In most ovens with an electronic control, the temperature is regulated by 2 things--the sensor and the oven control board. The sensor is simply an electrically resistive device that changes resistance as the temperature increases or decreases. It is connected to the main control board by 2 wires(just a "pigtail") and the main board is supposed to be calibrated to adjust properly. Most control boards have a built-in program by which you can adjust the calibration +/- 35 degrees. If your oven is outside that range, and you're sure that the sensor is good, the connections are good, etc., then the oven control board temp control circuit has gone bad. Keep in mind, when you turn on an electronically controlled oven, the first time it heats up is USUALLY hotter by about 50 degrees--this allows the floor, walls, and ceiling to reach proper temperature. This is called the initial spike. In gas ovens, the user must wait approximately 8-10 minutes AFTER the oven beeps to cook anything. In an exposed-element electric oven, the user waits approximately 10-15 minutes after the beep. In the hidden bake element models, waiting 20-25 minutes after the beep is normal!
Also, keep in mind, ovens can have 60 degree temp swings higher and lower(as long as the midpoint is close to the chosen temp) I hope I've helped you!
Sep 15, 2015 | Kitchen Ranges
We have a 2-year old Viking gas range (model VGCC5304BCC) and lately the oven temperature has beeen running about 25-40 degrees higher than the selected temperature. I cannot find a way to calibrate or...
use a digital thermometer with a probe inside the cavity, normal preheat is 30 mins to 350, wait until the 3rd cycle to see what temps are in the cycle, record high , low temps add and divide. plus or minus 10 are in scope. ex 350 on at 340 off at 360 will avg 350. depending on the serial and age, there is no calibration unless your Electronic thermostat would be suspect. Hope this helps.
Sep 29, 2013 | Kitchen Ranges
Blomberg BEP 906. After power went out a couple
Hello.
When baking or cooking common foods in your oven, it is important that the oven heats to the proper temperature. Otherwise, the food in your oven could become over- or undercooked. The electric ovens are able to be calibrated if only slightly off, however, if the temperature is 25 degrees off or more, you should replace the oven sensor. The oven sensor is the device in the oven the detects the temperature. The control board increases or decreases the oven temperature, depending on the oven sensor reading. Before calling a repair technician, attempt to calibrate your oven or change the oven sensor.
Instruction
1 Turn on the oven and set the temperature to a medium-heat setting, such as 350 degrees.
2 Allow the oven to preheat and then open the door and insert the oven thermometer.
3 Allow the oven thermometer to remain in the oven for a few minutes and the look at the temperature reading, comparing it to the oven temperature setting.
4 Recalibrate the oven if the temperature is only slightly off, or replace the oven sensor if the temperature is greatly off, such as 25 degrees or more.
Calibrating the Oven
1 Turn off the oven to prior to calibrating.
2 Press and hold the "Bake" button until the calibration settings are displayed on the display.
3 Use the arrow buttons or "+" and "-" buttons to adjust the temperature the number of degrees that the oven is out of calibration.
4 Press the "Start" button to save the calibration settings.
Replacing the Oven Sensor
1 Unplug the oven from the wall or cut the power to the oven in your breaker panel.
2 Open the oven door and remove the oven racks.
3 Locate the oven sensor, located at the top-center of the rear oven wall.
4 Remove the mounting screw securing the oven sensor to the wall and then pull the oven sensor away from the wall.
5 Remove the cable connected to the terminal on the rear of the oven sensor and then discard the oven sensor.
6 Connect the cable to the terminal on the new oven sensor and then reposition the oven sensor and secure it using the mounting screw.
7 Replace the oven racks and then restore power to the oven.
Thanks.
Dec 23, 2011 | Ovens
CANNOT FIGURE OUT HOW TO CALIBRATE THE OVEN. OVEN TEMPERATURE IS OFF 50 DEGREES. INSTALLED A NEW THERMACOUPLE. THIS DID NOT HELP THE PEOBLEM. OVEN WAS PURCHASED IN 1992. THANK YOU FOR YOUR HELP.
Without the Model Number I can only give you Basic instruction.
If your machine is Digital the best way to calibrate if find the manuel of your machine useing your Model number.
Some of the digital models : select bake and press and hold the up or down Temp button for 5 Sec to enter the calibration mode.
Some models require you do get the temp to over 400 deg befor you can enter the Calibration mode.
If your machine has a turn knob ... Take the knob off and see if there is a small screw in the center... This is the calibration screw.
Oct 05, 2010 | Magic Chef 9122 Gas Single Oven
I have a frigidaire stove that heats to 50 degrees hotter than the know setting. Can it be adjusted to read correctly?
There is a calibration method to adjust the oven thermostat plus/minus 35 degrees if it is a digital display. The method varies depending on the model range. This calibration method is used to adjust the thermostat if it is not keeping proper tempature. For example if you are setting the oven to 350 and the actual temp it is keeping is 325 then you could use the calibration method to adjust it plus 25 degrees to correct the temp. Just so you know electric ovens will keep a pretty even temp but gas ovens will vary by 40 or more degrees to keep an "average" temp. For example the burner will come on when the oven is 330 degrees and turn off at 370. 330+370 then divide by 2=350. So a oven thermometer may not show you the temp you set it at in a gas oven but does not mean the oven temp is off.
Jan 14, 2010 | Ovens
OVEN WILL NOT COME UP TO TEMPERATURE
You can calibrate the oven on this model. Press the bake button, adjust the bake temperature up to 550 degrees and then press and hold the bake button until a 0 displays. Now you can adjust the oven temperature up or down to match the display.
Here is a repair manual link that you can use to download frigidaire repair manuals. The one for 30 inch freestanding ranges will have the section on calibrating the oven's electronic control.
Thanks
Jan 09, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
Nov 27, 2008 | Amana AOCS3040SS Electric Single Oven
Oven doesn't reach temperature
Page 6 of the owner's manual:
Adjust the temperature calibration.
Jun 26, 2008 | Whirlpool RBD305PD Electric Double Oven
Kitchen Ranges Logo
59 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
