Question about Kodak EasyShare Printer Dock Series 3
Paper will not feed itself into printer, i have to push it in
  • 295 Answers
Jst have to push the stack of paper first in the beginning and then align the paper alignments with the paper edges,printer will automatically take paper in.
Posted on Jul 29, 2009
My printer keeps showing the message "Clear paper jam, then press (check mark), there is no jammed paper in the printer.
If I load my paper at the 'proper' height, it will not feed. If I push the paper down too far, I get a 'paper jam' message. What works for me (even though it's a royal pain) is to feed 1 sheet of paper at a time. Put 1 sheet in so it's level with the top of the feed tray, then gently push it down 3/4 of an inch. That works for me. Good luck.
Sep 19, 2010 | Lexmark X5470 All-In-One InkJet Printer
Paper doesn't feed from inside on XD 100 work center (10 years old, lightly used). Despite a full paper drawer, I get the "out of paper" error message.  I can copy by feeding through the back.
On this machine, the feed rollers might be worn down.
Not seeing the machine and by the description. there can also be other possible problem areas, deep in the machine itself.
Does the paper feed partially out?
If it does not, are there paper black scuff marks where the rollers were trying to feed the paper.
Can you hear the solenoids feed the paper?
If the paper does feed and seems crooked, it is possible the paper tray springs need to be stretched out just a little to push the paper tray plate more on the feed rollers.
Make sure the tray is completely up in the latched position so the feed wheels will touch the paper stack itself.
If you have a two paper tray, make sure you tell the machine what size paper you have for each tray.
Run paper in each tray.
Good luck.
Jan 15, 2010 | Xerox Office Equipment & Supplies
My HP Phototsmart C3180 will not print because it tells me that there is no paper in the feed. There is paper there. It tells me to push the "OK" button once paper is there. I can't locate an "OK" button.
You can see the OK button in the window which says "push the "OK" button once paper is there" , This is not on the printer, its on the Windows dialog box itself..
Rate this solution
RNJ VINOD KUMAR
Sep 15, 2009 | HP Photosmart C3180 All-In-One InkJet...
Dell 3000cn keep getting load mpf when i try to print but there is paper in the tray. how do I get it to recognize the paper. I've changed nothing on the computer but this just started to happen! please...
I have a Dell 3010n myself, and a few times I did run into that "Load MPF" issue.
1.) Before printing a document, please check and see the properties. i.e. Kind/type of paper, which tray, or if printing envelopes or any other document than a regular 8 x11 paper. Putting all the tray and paper type selection on "Auto" can be very helpful.
2.) On the printer itself, there is a menu button where you can configure the type of paper, i.e. regular 20 llb. copy/print paper, glossy photopaper, thicker paper - after you place a fresh load on the paper tray and slide it in, usually it will ask you which type of paper you just loaded. Make sure it is the same settings as the document that you are trying to print: i.e. if document settings on computer was set to print on photopaper and you have regular paper on the tray, the printer will do a "Load MPF".
The paper sensor on it is amazingly (for a Dell, that is) sensitive and it can differentiate across a lot of paper types/thickness. If you have several computers and user across a network, and there are several paper-type settings done on the printer itself, this "Load MPF" issue will present itself more often.
In my case, it's simply because the person who recently changed the paper-type to glossy cover paper from some user who previously printed to a transparency forgot to revert MPF/Tray 1 to regular copy/print paper. Most cases, the printer setting on the PC has been left to print on to a transparency by default, so even if I stack the tray with copy paper to the hilt, it still will do "Load MPF".
Jul 25, 2009 | Dell 3010cn Laser Printer
Epson cx11nf paper jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 03, 2009 | Epson ACULASER CX11NF All-In-One Printer
Paper jam is in top but can not see it.the paper feeds thru the tray then pushes itself out the top.
Dec 29, 2008 | Brother DCP-8060 All-In-One Laser Printer
Paper won't feed
My CX4800 developed the same problem. It was an excellent machine until then. I tried everything I could think of, and finally decided it must be the rather large feed in rollers at the right of the paper bin (one below and one above the paper) that had worn too smooth to pull the paper in. It works fine if I will give the sheet a "push" when it starts to go down - but who has time to stand there and push each piece in! It would really be nice if Epson would provide us with inexpensive replacement rollers and instructions for installing them. Guess they had rather we just buy a new printer - which I did, a CX7800, only to find that it will not take the heavy weight photo paper. :-(
Sorry I couldn't help more.
Jun 15, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Epson DX6000 paper jam problem.
Shake the printer and turn it upside down.....Be carefull in doing so...
Apr 09, 2008 | Lexmark All-in-One Printer with PictBridge
Hp LaserJet 1100: Runs louder than normal and continuously, BUT will not grab paper and print
Fred shine a flashlight down the paper feed throat and see if the feer roller is rotating when the printer tries to print.
I have had to replace many of the feed rolls and separation pads in this series of printer.
the tires get dirty or worn and feed multiple sheets or none at all. check for obstructions as well-sometimes the black mylar sheet which sits in front of the feed roll gets in the way of the paper path and has to be pushed in place. I have also seen paper pieces stuck next to the paper path switch which is visible after removing the toner cartridge. hope this helps.
Mar 28, 2008 | HP LaserJet 1100 Printer
Kodak EasyShare Printer Dock Series 3 Logo
194 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
