Question about Beckett Corporation Beckett Professional Pond Pump, 5000 gph
Where can i buy a impeller for a beckett w1800 pond pump?
5 Suggested Answers
gotgeek2
  • 565 Answers
SOURCE: Laguna 7000 pond pumps stopped pumping
No, once this inside of the cylinder cavity is scored it's toast, the only hope is that it is still under warranty.
Posted on Feb 05, 2009
dragonsthatk
  • 547 Answers
SOURCE: GFI for pump keeps tripping...
no you need to put 60amp breaker in house panel box
Posted on Feb 12, 2009
pondking
  • 21 Answers
SOURCE: beckett large pond pump
if by large you mean one that likes the photo you have picture it is a lost cause as it it epoxy encased and unrepairable. If thats the case buy a pondmaster or atlantic pump. proven performers that are repairable and very good warranties
Posted on Mar 23, 2009
  • 10865 Answers
SOURCE: Pond pump trips circuit breaker
The circuit breaker trips because there is an electrical short in the pump itself or in the wire feeding the pump. A cause of this could be a bare wire, or a crack in a wire. Remove the pump and put it in a five gallon pail of water and test it. If it still trips the breaker you will know the problem is in the pump or the cord to the pump.
Posted on May 02, 2009
How to remove a pressed on impeller
Is it pressed on using a keyway on the impeller shaft or is it simply a pressed interference fit?
Jul 21, 2014 | Beckett Corporation Beckett Professional...
Where sale a impeler for beckett w3500.
http://www.homedepot.com/p/Beckett-3500-GPH-Submersible-Waterfall-Pump-W3500HD/100024869
Or if Home Depot can't help you in ordering an impeller for a pump they carry, try sending an email directly to Beckett and ask for assistance on where to get one...
customerservice@beckettpumps.com
Good Luck
May 09, 2014 | Beckett Corporation Beckett W3500 7114310...
Beckett waterfall / fountain pump W1800 pops breaker everytime you plug it in, consequently it won't run.
Sounds like there are too many things running on the same breaker. Try unplugging some of the other things on that breaker.
Oct 09, 2012 | RTO Beckett W1800 Waterfall Pump
We have a Beckett W5000 a rock got in the systems and broke the plastic puppelor. Where can we buy trhe part to fix it???
Email Beckett at: customerservice@beckettpumps.com
Call Beckett at:
972-871-8000 or Toll Free at 1-888-BECKETT (232-5388)
Fax Beckett at:
972-871-8888
Write to Beckett at:
Beckett Corporation
c/o Customer Service
3250 N Skyway Circle Dr
Irving, TX 75038
Warranty & Technical Assistance:
The NEW toll free number for warranty information, replacement parts, and technical assistance with water gardening and fountain products is 866-466-4319 or email Beckett atCustomerCare@beckettpumps.com
For information on CE, VDE, or DENAN (PSE mark) certified pumps:
Please email Beckett at: customerservice@beckettpumps.com
Or write to them at the address above.
Aug 28, 2011 | Beckett Water Gardening Beckett Statuary...
Beckett # W1150 WTRFall/Str Pump: Our pump will run for an hour or so, and then it s...
This same symptom happened to me.Check the impeller, if you can pull it out or it just sloshes around in the well housing, then the impeller lock has come out of it's place. Simply pull off the outer intake grill, then twist off the outlet housing. Now you can see that white notched washer and how it must be seated and aligned. Once seated in place use a small screwdriver to turn and lock it in. Now you will see your impeller shaft is no longer loose.
May 17, 2010 | RTO Beckett # W1150 WTRFall/Str Pump
Model W1800 stop pumping after less than 6mos makes lots of noise and just a little discharge
I have had the same problem everyone else has had with these pumps. I did serious research on these pumps and came up with a rebuild kit some parts bought some I make. I did mine 2 years ago and still working like a champ and have done over 20 locally with no problems. If your pump is noisy or the impeller has fallen off (typical) due to water getting in the unit and causing the bearings to fail email me and I can rebuild your pump. The process is simple send me the pump I will look at it and see if it can be rebuilt at NO CHARGE if it can be rebuilt you will save over 60% of a new one. Don't spend $349 - $599 on a new one let me look at it for free if I can rebuild it great if not you will have to buy a new one. I am not a dealer for any pumps so you will not have to worry about me selling you a pump and if you want the old one back pay the shipping and it it all yours.
Mar 09, 2010 | Beckett Water Gardening Garden
Where can I find a replacement impeller for a 10 year old beckett water pump? The only model information I have is "798" stamped on the out side of the casing.
I'll bet you need to buy a new pump.Most pond pumps from Beckett are sealed and the impeller can't be or should not be changed.
Sep 27, 2009 | RTO Beckett # W1150 WTRFall/Str Pump
I need an impeller housing (part no. CX1777) for a Beckett Versa Gold G325AG20 pump.
The web site for "Otimus home" will get you in touch with more parts than most sites. This site is for pool parts they also have a site for spa and smaller pond equiptment.
Aug 20, 2009 | Garden
Beckett Corporation Beckett Professional Pond Pump, 5000 gph Logo
248 people viewed this question
Top Beckett Corporation Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Beckett Corporation Garden Expert? Answer questions, earn points and help others
