Question about GE Dryers
Dryer doesn't start. circuit breaker is not tripped. dryer is plugged in.
    Scholar:
  • 117 Answers
I bet the thermal fuse is blown. This is a feature most newer dryers have to prevent overheating.It is usaully located in the back of the dryer panel near the heater element or blower and is white in color. Check continuity with an ohm meter to confirm. hope this helps
Posted on Jul 29, 2009
Why does the circuit breaker keep tripping?
Need more information is it dryer,stove,ac ,heat, water heater,bathroom plug, garage plug ,outside plug, other
Lighting circuit with plugs
Oct 19, 2016 | Dryers
No power to the display, dryer will not turn on
First thing you need to do is check the Circuit Breaker for the dryer. If it is tripped unplug the dryer and reset the Circuit Breaker. Now plug in the dryer and try to run it. If it does not work again check the Circuit Breaker again if it is tripped again unplug dryer and call someone that can help you or fix it. If the Circuit Breaker is not tripped check for good power readings on both power lines coming into the dryer. Should have 110V or more on each line to neutral, and 220V or more between each line. If you do not have the correct voltage at each line check Circuit Breaker for good power coming out.
Mar 13, 2014 | Maytag MDE9700AYW Neptune 174 Electric...
My fisher & paykel model ad39 dryer has stopped working
Always unplug the appliance before working on it.
I would suggest checking the circuit breaker in the breaker box for your apartment, to see if it has tripped. You have probably already done this, but try to reset (open all the way and then close) the circuit breaker. Plug the power cord in again and try to operate the dryer.
If it trips the circuit breaker again, there is a short circuit or a ground, and you should unplug the machine and diagnose the problem. 240 volts AC, when shorted or grounded can start fires or kill people.
Many Dryers are equipped with a "non-resettable thermal fuse". When the air being blown through the dryer gets too hot, this thing melts and opens up the entire power circuit.The dyer doesn't do anything, as if it had no power.
This non-resettable thermal fuse can usually be purchased from the manufacturer or a good appliance supply store, and comes in a kit which also includes a new thermostat, to replace the one that probably failed and overheated the machine to start with.
Get a friend who is an Electrician to help you if you are at all unsure of replacing parts in your power circuit. Be sure to unplug the machine / use a VOM to check it dead before you touch anything electrical. BE SAFE. 240 Volts AC is not just playing around.
Oct 06, 2012 | Dryers
Dryer wont heat up
Hi
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. You can't re-set it.
Also a common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
There are various reasons for a dryer not to heat up. Please check this link to get the probable reasons for this malfunction in the dryer:-
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
http://wiki.answers.com/Q/Why_wont_my_whirlpool_electric_dryer_heat_up
Please get back to us if you have further query or else please accept the solution.
Sep 02, 2011 | Whirlpool LER4634J Electric Dryer
Dryer runs but there is not heat, heating coil has been checked and it is fine. What is the next troubleshooting step to check it out?
hello zack... Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. I know you indicated that the Heating element was checked but here is how you do it. Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Apr 24, 2011 | Whirlpool TEDX640PQ Dryer
Electric problem in this dryer
There is too many appliances on the same circuit. Try plugging it in on a circuit that has less items running on it or try running it on a circuit that the breaker can allow more power(amps)
Dec 07, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Circuit breaker trips after 10 minutes
could be a weak breaker,or poor high resistance connection from panel to dryer plug, then have someone check the current draw on the dryer while operating and see if it's within specs of the machine tag, if it's higher than that you may have a defective motor or heating element to case causing a higher than normal current draw
Nov 09, 2009 | Maytag PYE2300AY Electric Dryer
Blows circuit breaker
sounds as if there is a short in the starting switch but there is a short somewhere in the controls good luck
Dave
Sep 15, 2009 | Amana ALE331RAW Gas Dryer
Hoover HDC7FM condensor dryer starts then cuts out
Open the dryer door (right after the breaker trips) and check for a burned smell. If it smells in the dryer, you probably have a direct short in the dryer wiring. Check for a burn smell at the wall socket. There may be a short in the socket itself, but not likely unless a mouse is lying across the contacts in the wall.
If everything checks ok replace the circuit breaker if this is an older home. Circuit breakers weaken after years of use. A 30 amp circuit breaker will trip at a much lower amperage after a period of years especially if it has tripped often.
Mar 12, 2009 | Hoover HDC7FM Dryer
Dryers Logo
53 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
