Question about Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed
2005 Poulan , 15.5 hp, has been running rough,
2005 Poulan , 15.5 hp, has been running rough, replaced fuel filter and air cleaner and now today it just sputtered out and died twice. Is there an adjustment on carb?
    Problem Solver:
  • 9 Answers
Water or trash in the gas?
Posted on Jul 29, 2009
Why is my renault wind 1.2 running rough
Clogged air cleaner, needs new fuel filter, water in gas, bad ignition wires or needs tune-up. Try a can of Lucas fuel injection cleaner.
May 01, 2014 | 2005 Renault 181
1992 toyota truck running rough
Could be the injectors. You would need to figure out which cylinder is weak, and then why. Have you replaced the fuel filter in the past 12 months ?
Jul 08, 2013 | Cars & Trucks
2005 gmc envoy runing rough po302 i replace plugs and "2 coil now po300 runs rough
have you replaced the fuel filter. also check the battery new cars use a lot of power and that could cause a random misfire code. if those are all good then check for a vacumm leak. you can do that with carb cleaner by running the vehicle and spraying around the intake manifold or vacumm lines and listen for a change in the motor
Apr 04, 2013 | GMC Cars & Trucks
2010 model 20 hp Briggs motor. Fuel going through fuel line, but not going into carberator. Motor runs good for about 15 min, but after heating up this fuel problem starts. After cooling down for an...
Two things:
1 Is fuel coming out of the fuel line. Older mowers have old fuel lines and they tend to get weak and collapse went they warm up with engine heat. Replace the old fuel line.
2 deposits in the carb. take off the air cleaner, start it up and spray a good carb cleaner in the carb until the engine dies. Put some 'seafoam' in the gas and a little in the oil and put the air cleaner back on and start the mower and mow on FULL THROTTLE. this should claen out the carb. Yes the mower will run rough for awhile.
these two cheap fixes will solve 85 % of carb problems. GOOD LUCK
Jul 17, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
Starts fine but dies when set to run.
You either have a air leak in a fuel line, carb jets are plugged, or carb seals went bad. They sell a rebuild kit for your carb, 10-15 dollars. I would start by removing carb spraying it with carb cleaner and blowing it out with a air gun, put it back on and see if this worked. If not I would replace fuel lines and rebuild carb.
Jul 25, 2010 | Poulan Garden
Poulan Pro 18.5 HP Intek engine trouble
Might be fludding..
If there is a bowl on the carb, pop it off and check the float.. Check for fluid inside the float. If the float is holding any fluid - its bad..
Srpay carb cleaner in there..
Clean the bowl..
Jul 09, 2009 | Garden
I tipped my poulan riding mower up from the right to check belt
If you remove the plug(s) so that the oil all drains back down, and some will drain back out of the muffler, it should start. But give a at least one day, maybe two. You may still have to put new plug(s) in it after it's gone. Check the fuel filter and see if you can see oil in it.
Take off the air cleaner when you get ready to start it and spray just a little starting fluid in the carb, Don't choke it. It will run rough and smoke like crazy, but after it runs a while it should be fine. It make take a few starts before it continues to run. At first it may run just on the starting fluid, but once the plugs fire up enough to burn the oil out it should run on its own.
Be sure and check the oil and if it seems like the slightest amount of gas in it, change the oil and filter.
Let us know how it comes out!
Sirwriter
May 16, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
My lawn mower will not stay started
Since it starts, it doesn't sound like an electrical problem, it sounds like it runs out of air. To test this, remove the air filter, start it and see if it stays running. If so, replace the air filter.
It could also be varnish or sludge in the carb bowl. This is best serviced by a technician if you have little mechanical prowess.
After sitting for 3 years, I would at minimum do all of this before I expected it to run ok:
  1. Change the oil.
  2. Replace the air filter.
  3. Drain the fuel tank by removing the fuel line from the engine end (not the tank end).
  4. Replace the spark plug.
If the above did not work I would drop the carb bowl and clean it, then add one ounce of carb cleaner to a full tank, and let it run (roughly if necessary) through the engine.
After sitting 3 years I would also replace the fuel line itself!
Mar 29, 2009 | Garden
2005 Ford Escape Rough Idle - engine code state lean fuel mixture
I recommend getting a repair manual from an auto store for your vehicle. They run $15 to $20. It will tell you exactly how to do everything you asked and also give you the values that should be expected. Hope this helps.
Feb 08, 2009 | 2005 Ford Escape
Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed Logo
216 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
