remove the sim card from the phone and clean the sim card slot with a cotton wool dabbed in methylated spirit and insert the sim back into the slot,put it on and test it.
If this does not work then you should replace the sim card holder.a repairer can help you with that.
Turn off the phone. Take the battery and sim card out. Make sure there is no dust or dirt of where the sim card goes. Blow air (from your mouth) of where the sim card goes. Then place the sim card back in the phone. Make sure it is in the right position. Copper contacts facing downward. Put the battery back in your phone. Turn it on. See if the smartchip rejected goes away.
If not you may need to contact your Phone Provider Tech Support to troubleshoot and confirm that you may need a PUK Code to register or you may need a new SIM Card, as they do fail from time to time.
Solution for your case is cleaning the simcard connector. If the phone says :phone restricted or simcard not valid ,you have to unlock the simlock with nokia box flasher.
Turn off the phone.Take the battery and Sim Card out.Make sure there is no dust or dirt of where the Sim Card goes.Blow air (from your mouth) of where the Sim Card goes.Sometimes rubbing a soft pencil eraser on the Sim Card contact points can help. Then place the Sim Card back in the phone.Make sure it is in the right position; copper contacts facing downward.Put the battery back in your phone.Turn it on, and see if the smartchip rejected goes away. If not you may need to contact your Phone Provider’s Tech Support to troubleshoot and confirm that you may need a PUK reset code to register or you may need a new Sim Card, as they do fail from time to time.
Warning: Do not enter any wrong unlock unlock codes on your Nokia 2610 mobile phones. If you enter over a certain amount of wrong unlock codes on your mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 2610 mobile phone without any sim card. 2 - Don't bother as to what is displayed on your Nokia 2610 mobile phone. 3 - Compose #pw+CODE+1#. 4 - The Nokia 2610 mobile phone would then display the message "SIM Restriction Off" and will be unlocked!
The letter p appears if you press the button star(*) three times quickly The letter w appears if you press the button star(*) four times quickly The symbol + appears if you press the button star(*) two times quickly The CODE you need to enter is the unique unlock code for your Nokia 2610 mobile phone
Each Nokia 2610 mobile phone has an unique unlock code. You can buy the unique unlock code for your Nokia 2610 mobile phone at www.mobileunlocksolutions.com.hope you doplease rate methank you...
