Question about Maytag MAH2400A Front Load Washer
After wash has finished water will accumulate in drum. i turned water faucet off and then there is no water. if water is left on there will be water in drum when ready to run a wash load. this is in a small maytag that is in my rv
    President:
  • 1,273 Answers
You have already analyzed the cause of the problem. That makes the fix much easier. Trace the hose that leaked by to your machine. There you will find that the hose is connected to a plastic solenoid valve. (A solenoid valve is merely an electrically powered diaphragm valve that is either open or closed). Disconnect the power to the washing machine. You can remove and disassemble the valve, getting down to the diaphragm and clean it, but for the time and cost, it will be probably easier and more effecient to replace the solenoid, and repair the other at your leisure. Any appliance parts supply house should be able to provide the part you need, at a low price.
Best regards, --W/D-- Please feel free to rate this solution!
Posted on Jul 29, 2009
Clothes washer does not fill.
How to Fix Washer That Won't Fill With Water ' Washing ...
www.partselect.com/Repair/Washer/Not-Filling-With-Water/
If not, then remove the hose from the faucet and inspect the screens for dirt accumulation or damage and clean or replace as necessary. If your washer still doestake water then you should next look at the water inlet valve located on the back of the machine.
Washing machine not filling with water - YouTube
? 7:28
https://www.youtube.com/watch?v=SwQe7--htAw
Aug 25, 2010 - Uploaded by how-2-repair.com
If your Washing machine is not filling with water this video willhelp you. ... *The spin cycle and drain WORKS
Nov 28, 2015 | Washing Machines
Indesit wd1030 washing machine drum not working
Your drive belt may be damaged and needs replacing
Nov 06, 2009 | Washing Machines
Water accumulated in drum while machine off and door open.
The water valve may not have closed completely or may be leaking. You can copy and paste this link in your address bar for more great repair info and feel free to ask any other quesitons:
http://home.howstuffworks.com/how-to-repair-a-washing-machine3.htm
Oct 14, 2009 | Kenmore Elite 45986 Front Load Washer
No water level in new Kenmore HE3T Steam front loader
high effeciency washes use very little water , the water is at the bottom of the drum (not visible )
Jun 07, 2009 | Kenmore Elite 45986 Front Load Washer
Drum not filling
Make sure that there is water available by turning the wall faucets all the way on. if the wall faucets are on and the water inlet hoses are clear and the screens are not clogged, this will confirm water inlet valve assembly failure. you will need to replace this device in this case.
You can test the valve assembly for voltage, if the voltage is not sufficient, replace the control and, if the voltage is 120 vac, replace the water valve assembly.
May 30, 2009 | Whirlpool Washing Machines
Washing machine begins the wash cycle going immediately to the agitate cycle, without filling up with water first.
water will not stop running into drum unless shut off at faucet does not happen all the time and wife can't find her rubber boots
Apr 26, 2009 | Washing Machines
HOT AND COLD WATER LINES ONLY IN KITCHEN VIBRATE VERY LOUD !
There is air in your lines.
You'll have to bleed out the air.
Turn off your water main.
open the faucet lowest in your house and then go open all the other faucets.
let the water drain completely.
close all the faucets except the lowest one - and turn on your water main.
once no air is escaping from the faucet (no burping or gurgling) close it and move on to the next - highest faucet.
Do this until all faucets are done.
Now - turn off the water feeds to your washer - and disconnect from the machine.
Open each valve one at a time into a sink or bucket until air is purged.
Reconnect hoses, and re-try.
This is called AIR HAMMER and if this still doesn't do the trick - there are tiny accumulators called air hammer arrestors that will eliminate most of the hammering.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 19, 2009 | Kenmore Elite 45986 Front Load Washer
Maytag Neptune washer MAH3000AWW seems to backfill after cycle
It could be a leaking water valve. The MAH3000 has two flavors, the earlier model had (2) extra wax motors in the soap dispenser for the bleach and softener controls and the newer ones have the bleach and softener valves integrated into the water valve assembly.
Contact me via the www.neptunehelp.com site and let me know which serial number you have and I can detemrine which water valve you will need.
See www.neptunehelpsong.com for a funny new song dedicated to Maytag Neptune owners explaining the door latch wax motor issue.
Feb 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
4E code keeps apearing
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Jan 29, 2009 | Washing Machines
Front loader washer
after you finish cycle all water out?? and completely spun clothing??? then upon returning you see water accumulating after the fact??? if so you have a faulty water valve not seating properly after closing , you will need to replace the valve the valve to correct, in mean time turning off the water between loads will work as well(which is a practice you should do anyway)
Mar 16, 2008 | Washing Machines
Maytag MAH2400A Front Load Washer Logo
184 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
