Question about Panasonic PT-61DLX76 Television
Lamp my picture turned black and the lamp light cam on???
  • 28 Answers
You have a problem with the lamp on the tv
is easy to replace only take cover off two phillips screws and inside two more screws
take off lamp and buy new one
Posted on Jul 29, 2009
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
I have Sony Wega and the picture just cut out and went to black. The sound wont come on and the TV wont even turn on. The light at the bottom of the TV flashes lamp light. We took the lamp light out and...
if u take out the lamp the green light will flash ,its not detecting a lamp at all.a bad lamp is being detected before you took it out.u will have to replace the lamp before u get a picture again
Sep 30, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Green light blinks and eventually turns solid green but only black screen no picture
When did you replaced lamp last time in tv?
If lamp has not been replaced in last 2-3 years then its time to change lamp.
Buy Sony original lamp for good picture in tv.
Aug 27, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
When i on web cam it show black picture when i provide additional table lamp light then the picture arew clear
Your Cam does not have the ability to deal with low lite hence the black screen. This happens alot with webcams from the Lower end of the market. Webcam like the logitec ons have an option to deal with low light situations.
Jul 07, 2010 | Computers & Internet
Watching tv when the picture went black and now the green on light flashes for 30 times and turns off
A green flashing light for this model of TV indicates that the lamp cover is open on the TV.
  1. Unplug the power cable to the TV.
  2. Remove the 2 retaining screws on the lamp cover with a Phillips type screwdriver.
  3. Remove the lamp door completely from the TV.
  4. Remove the two retaining screws on the lamp case.
  5. Lift up the fixed wire handle of the lamp.
  6. Pull out the handle slowly and remove the lamp case.
  7. Insert the new lamp gently into the correct position. Make sure it is inserted correctly.
  8. Using a manual Phillips screwdriver (Do Not use an electric screwdiver), tighten the screws you removed in
    step 3.
  9. Replace the lamp cover and tighten the cover screws.
  10. Plug in the power cord and turn on the TV. After the initial warmup period (which may take up to several
    seconds for full picture brightness), the TV should operate normally.
If any of the following conditions exist, turn off the TV, unplug the power cord, and repeat steps 1–9 to ensure that the lamp unit and lamp unit
door are installed correctly:
  • The lamp indicator flashes green.
  • No picture
  • Dark picture
  • TV will not turn on
If, after repeating steps 1–10, the problem still exists, call Customer Service at 1-800-631-3811.
Source
Aug 31, 2009 | Toshiba 44NHM84 44" TV
Sony KDS50A2020 Blackout
Replace the lamp, clean the fans, seen it a hundred times, I know "the lamp light isn`t blinking" replace your lamp and you`ll be back up & running, gl, video-tek
May 29, 2009 | Sony KDS-50A2020 Television
No picture or sound mitsubishi 62525
Capacitor failure is the most likely scenario the FMT ans Signal PWB would cause the picture interference and the power pwb would cause the lamp light to turn red and give a 34 code when the device/ input and menu buttons are pressed in together and held for five seconds. That chassis has issues with every board in the chassis having failed capacitors you can get repair kits for the V26 chassis at the follwing link that come with instructions. Your model is the V26 chassis. Heres the link.
http://servicemanuals.vstore.ca/
Jan 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Pictures goes black while power light blinks green
I have a 40 but i was having the same problem. It turned out to be my lamp. I got a brand new lamp from Projector Lamp Services (relampit.com) and my tv works fine now. Im pretty sure that the 40 and the 60 take the same lamp. You might want to give them a call.
Jan 05, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Panasonic PT-61DLX76 Television Logo
61 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
