Question about Maytag Neptune FAV6800AW Top Load Washer
How do i take the top off?
Ive been reading and reading but i cant find my answer.
my washer keeps flashing the OP code whenever i try to start it.
i read some posts on this site and i think i should check the locks, magnets, and the wiring to the various switches because of corrosion and whatnot.
what i cant figure out is how to get the top off.
do i take the front panel off the washer to get to the latches? i figure i must- but i dont want to go flipping the washer upside down before i know what im getting into.
any help would be great, thanks!
  • 1 more comment
  • johncbins Nov 26, 2007
    The lid locks are not workihg properly, they may or may not lock/unlock when needed. How do I safely remove the top in order to replace the locks. ALso I see the hinge is causing rust. can the hinges be replaced as well without purchasing a new lid?
  • bellcurve Dec 01, 2007
    I can get the top off but not the front panel.
    I can get the top off. how do you take off the front panel?????
You can take the top panel off by sliding a butter knife or putty knife and run it along the crack in the front. There are two catches that will release when the knife pushes against them. You just raise the lid.
Posted on Dec 01, 2007
The op code keep coming on
The "OP" code indicates the lid is open. It needs to be fully closed before starting the cycle.
The "reed switch", is actually a term that is used because the lock or switch is reading off of a magnet.
For your appliance, you have two locks. One on the right hand side(part number 25001037) and one on the left hand side(part number 25001048).
Aug 15, 2011 | Maytag Neptune FAV6800AW Top Load Washer
When I press the start botton the OP botton continue to flash, and the machine wont start.
Google "Sticky: Neptune TL Washer FAV6800AWW"
You can get the Service Manual from that site 5 post down. I have some post in the sticky for troubleshooting the OP error code along with some pics of the left hand lid lock. Post in that forum and I will help you get the machine back in service.
Mar 01, 2011 | Maytag Neptune FAV6800AW Top Load Washer
It is flashing "op" wont start
See if this link will get you started.
http://www.fixya.com/support/t5155274-maytag_neptune_model_fav6800awq
http://www.fixya.com/support/t5958665-od_error_message_when_try_start_wash
You troubleshoot "OP" and "OD" similar. You can place a magnet over the left gray lid bumper with the lid raised and see if that will clear the OP error code with the lid open.
If it does then the lid magnet may be out of position in the inner lid.
You can't pull the Service Manual from Servicematters any more they have placed a coin slot on the site.
Oct 04, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag top load washer op error code, washer wont start. Checked and magnet is in place, what else can it be?
If you place a couple magnets over the left gray bumper and the "OP" error code doesn't clear then I feel you have a problem with the Left Hand Lid Lock.
See if this post will help; Left Hand Lid Lock Troubleshooting
Sep 29, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Code op flashes with a beeping sound
I feel you have lost signaling thru the Left Hand Lid Lock.
See this post to get you started; Left Hand Lid Lock Troubleshooting
You could also have a Lid Magnet out of posistion. Try placing a couple of ring magnets over the left hand bumper with the lid open and see if the OP error code clears.
See photo;
FAV6800A/FAV9800A Service Manual for reference.
Sep 11, 2010 | Maytag Neptune FAV6800AW Top Load Washer
The washer is stuck locked. When turned on it shows OP where the minutes are!! PLEASE HELP !!
Don’t force the lid open and break the lid locks.
Here is the Service Manual and parts look up;
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Use this procedure for releasing the washer top from the base;
Un plug the 120VAC power cord to the washer.
To raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. See page 33 of the SM for putty knife insertion point.
This will get the clothes out.
With the washer top raised gently push to Left and Right lid lock latches to outside of the lid the unlock position.
You can now lower the washer top to the base.
Do you want to DIY the OP error code?
The OP error code could be caused by a Lid Magnet out of position. To do a quick check with the lid open power up the washer. Do you have the OP error code showing? If so take a large magnet and place it over the grey left lid bumper and see if the OP error code will clear the LED display. A Pic for reference;
If that doesn’t clear the OP error code we would need to do deeper troubleshooting. Are you up for that? Let me know……Rich
e830e40.jpg If that doesn’t clear the OP error code we would need to do deeper troubleshooting. Are you up for that? Let me know……Rich
Apr 12, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Cannot start washer. Display flashes OP
See if this post will get you started for troubleshooting the Left Lid Lock related to OP alarm. Post back if you have questions.
Sep 30, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Hi my washing machine bosch exxcel is not working ive checked filter the code f04 keeps flashing and i cant find my hand book to check code do you know what it means
The F4 error code on your washer indicates a problem in the electrical circuits of the washer... and not end-user repairable.
This problem requires a technician to test the wiring circuits to diagnose the problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 03, 2009 | Washing Machines
Power on/off problem
format ur phone by using code * + 3 + Call key + On/Off key till formatting appears, if this does not work u have to flash ur phone
Dec 14, 2007 | Nokia 7610
Maytag Neptune FAV6800AW Top Load Washer Logo
70 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
