Question about Mitsubishi WS-65511 65" Rear Projection Television
Flashing green light
Can you help
Re: Flashing green light
Try hitting the reset button its right next to the power button you need to use a pin or paperclip to get at it
Posted on Jan 02, 2008
0 characters
3 Points
My hitachi 1999 tv turns on but off right away has flashing green lights in back
If the flashing green lights are on the circuit board each is tied to a voltage from the power supply----likely damage is there but a 99 may not be economical to fix in 2012.
Nov 04, 2012 | Hitachi Projection Televisions
Sony Grand WEGA KDF-60XBR950 60 green orange green red flashing light
3 blinks is a lamp cover error, did you make sure that the lamp cover is screwed in tight? Also check the lamp cover for deformity, there is a problem with your model where the set over heats and melts the lamp cover a little causing it not to make connection with the lamp cover switch. Let me know if you find either of these problems? If not we can troubleshoot a little further.
Tim Nolan
Sep 14, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Is this a Mitsubishi set? Let me know the model number -
Sep 07, 2009 | Projection Televisions
My new TV keeps turning off and then on again with flashing red and green lights in front.
Check your warranty for the unit. Then call Samsung to see I they can help.
800-243-0000 Customer Support
If no help there repost with model # of the unit.
May 15, 2009 | Projection Televisions
Constant green blinking light Mitsubishi tv WS-65513
Unplugged my Sony for 36 hours from wall and it solved the problem
Oct 20, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Tv won't come on. It has a flashing green light on by the power button.
the tv is not come has a flashing green light model hd 1080.
Oct 19, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Grenn light keeps flashing
HERE is green light flashing problem and its solution provided by premtech one of best experts at :)
Aug 21, 2008 | Mitsubishi WS-55513 55" Rear Projection...
I just replaced my lamp
which light is flashing?? there are two green lights. the timer light and the lamp light.if the lamp light is flashing you have a bad lamp or a bad HV-Starter.Could be a bad DMD-Board as well
Jan 11, 2008 | LG RU-52SZ51D 52" Rear Projection...
Please study the procedure at the following address..... .....
use 1000mf 25v or 35v 105 degree capacitors to replace
original four 1000mf 16v..............if new ones are a little
too high,just lay them over on board........
Look it over..........let me know......................T.
Jan 07, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi flashing light replaced capasitors that were blown tv still has flashing light
The four cap replacement in DM module repair is simplistic
and incomplete, as you found out. ALL defective DM modules
have bad SMC's ( small "top hat" caps) AKA surface-mount
capacitors that can be changed only by the most highly skilled
bench techs. We used to change out hundreds years ago in
camcorder circuit board repair.DM board repair is a much more
accessible,thus more "do-able". For more info.............T.
Sep 26, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Open Questions:
See all Mitsubishi WS-65511 65" Rear Projection Television Questions
Mitsubishi WS-65511 65" Rear Projection Television Logo
55 people viewed this question
Top Mitsubishi Projection Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Projection Television Expert? Answer questions, earn points and help others
