a
alib Posted on Oct 09, 2017
Follow instructions in right cover to remove/ after open and close the door this massage claening but dont copy. then this massage seen again
5 Related Answers
A
Anonymous
  • Posted on Jul 30, 2008
SOURCE: CD player cover/door won't stay closed
The intermittent version of this seems to be related to the cable that goes to the subwoofer portion. Have seen this behavior when the cable got loose. Unfortunately, I believe that this behavior may get worse in the long run and cause CDs to not play at all.
Anonymous
  • Posted on Feb 03, 2009
SOURCE: back cover open message on brother mfc 7820n
Had same problem. Closer inspection revealed bit of paper out of sight. Removed the toner cartridge and worked to free torn paper. Then restart. Hope it helps.
Anonymous
  • 38 Answers
  • Posted on May 17, 2009
SOURCE: A follow instructions in right cover to remove
U JUST FOLLOW THAT INSTRUCTION TO REMOVE THE MISSFEED
quennie732
  • 422 Answers
  • Posted on Jul 12, 2009
SOURCE: Follow instructions in right cover to remove
open the right door right in front of your PCU are 2 long rolls a black and silver turn these by hand so the torn paper between them comes "up" -Carl
Anonymous
  • Posted on Sep 18, 2009
SOURCE: paper jam --samsung SCX-4828FN
i found that paper jam was in the middle of the mechine. i opened the front door and removed papers.
Red light on printer button on and message reading follow instructions in right cover to remove. I follewd the instructions and the message is still displayed what do i do to fix? it wont allow me to copy...
Hi! If there is a printer with door problems, this is one! Lets presume you have a paper jam, even if you dont see it. The bit of paper can be stuck in this three points: paper cassete, register sensor and fusion sensor.paper sensor gets damaged very often in this machine but the message will be " out of paper". The register sensor ( it tells the machine the paper arrived to the register roller and it can start cordinate paper movement with scanner movement, a question of syncronous efforts),lyes in the right cover, it looks like two small eyes, they must be cleaned. The fuser sensor, tells the machine the paper arrived there without problems but also says it already got out, once the paper comes out. the fusion must be opened to check this.
Now, this machine have problems in the door switch, you will see a square hole at the left side of the machine (presuming your facing it with the right door open turned to you) somewhere at half way.theres a switch inside that is actuated by a proeminence in the right door, once closed. If this actuator is broken the machine will keep telling you "close right door".If you see its broken, insert a small screw diver and press in, the machine will start to work and the message disapears, If the case, you have to "Reconstruct " the actuator, in order to touch and actuate the inner switch. Sometimes i do this just puting a screw through the plastic. Other choice is to order a new cover, these actuactors are very fragil. Also the latch that keeps door well shut.you wanna try to push the right door in, sometimes is enought. Hope i been helpfull, sorry my (bad) english. Come to me again if you got no improvement.
How to remove casing
To make sure there is a clear understanding here's a complete diagram
Overall Parts Diagram
To Remove the Outside Plastics on the HP Color LaserJet CP5220 Series Printer
1) Remove Right-front cover and control-panel assembly
a) Open the front door and the right door.
b) Remove two screws (callout 1).
c) Release 3 tabs (callout 1) on the right side of the assembly.
d) While holding the assembly up, pull the cable holder (callout1)
disconnect one connector (callout 2).
2) Remove Left cover
a) Remove Tray 2 from the product.
b) Open the front door.
c) Remove three screws (callout 1). Starting from the left side
tabs (callout 2),and then remove the cover from the product.
TIP: Opening the toner-collection door might make it easier to release the tabs on the left side of the cover.
Reinstallation TIP: If the front door will not close after the left cover has been reinstalled, verify that the two tabs on the right side of the cover have been aligned correctly with the product chassis.
3) Remove Rear cover
a) Remove six screws (callout 1), and then remove the cover
from the product.
4) Remove Toner collection unit access door
a) Open the toner collection unit access door (callout 1), remove the toner collection unit, and then release the link arm (callout 2) on the left side of the door. 18798043-wfiifre4chsxw5xgazxianfb-1-48.jpg
b) Partially close the door, and then disconnect the right-hand link arm (callout 1) from the door.
CAUTION: Do not disconnect the right-hand link arm when the door is completely open. Doing so can disconnect the link arm spring. 18798043-wfiifre4chsxw5xgazxianfb-1-63.jpg
c) Rotate the access door down 90 degrees, and then pull on the left side of the door to remove the access door.
5) Remove Right-rear cover
a) Remove the rear cover. See Rear cover on page 93.
b) Open the right-door assembly.
c) Remove two screws (callout 1), release one tab (callout 2),
and then remove the cover.
CAUTION: The grounding spring on the back of the cover falls off easily. Be careful not to lose it.
6) Remove Top cover
a) Remove four screws (callout 1).
b) Open the toner-collection door.
c) Release two tabs (callout 1), and then remove the cover.
7) To Reassemble Follow Instructions in Reverse
After restarting the machine shows the ready to copy massage it later bring a red indicator without any massage on the screen but the lower massages remain such as copy ratio, density among others what...
did you check jam indicator that glows red left from LCD panel?
Try to reopen the paper drawer and put it back strongly.
If you have dadf it can show jam if its lift up all the way.
On leftsideway, beneath the left door is paper pick up door reopen them and close more strongly.Also check the sensor flapper in the middle, wich is seen when paper pass door are opened.
For service manual you can contact me on [email protected]
Hope that helps!
6helpful
Follow instrctns in right cover to remove
is it a miss feed problem? open the cover on the right cover of the machine then remove the jammed paper. then close the covers
MACHINE DO NOT COPY AND GIVE THE FOLLOWING MESSAGE: (A ZIGZAG SYMBOL) WITH "FOLLOW THE INSTRUCTION"
Sounds like the 'Clear misfeed' symbol. Open the front cover and follow the pictorial diagram instructions to check your paper feed path for jammed paper. Remove misfeed, and close covers. This should reset your machine.
1st side cover is open
Hello sir; Are you using duplex unit, check your duplex unit.
16helpful
2answers
Back door open
Inside the back door is a black plastic guide, in the center there's a lever that moves when paper goes thru, on the right is a flag that needs to be in between the horseshoe shaped sensor on the right. Make sure the lever moves freely...
2helpful
2answers
Message on brother MFC7420 "back door open" when it's not
Actually, you need to double check the back cover and front cover, open them all to check all paper jam.
Besure to check the back cover, normally all paper jam is from the back.
be sure to close the front cover at the last cover to close.
1helpful
2answers
No bottons are working
This means the developer unit is not installed . Check and instal.
Top The Office Equipment & Supplies Experts
vince
littlewheel
Jean Thiebaux
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
