Question about Danby (DAR604BLS) Refrigerator
GE GSS22WGPH WW won't defrost
I have a 5 yr old GE GSS22WGPH WW that will not defrost. About every two weeks you have unplug the unit for a day or so, or remove the interior back panel from the freezer and thaw the evaporator coils with a hair dryer, they will be completely encrusted in ice completely blocking any air flow. I have cleaned the condenser coil and fan of dust, fuzz, etc.
Defrost timer or heater perhaps? What is the test procedure for these components, or other areas that might be the cause of trouble? I live about a 2-hour drive from the closest big city so finding competent repair services is a challenge.
Thanks,
Jeff
  • colville86 Jul 29, 2009
    The defrost heater element was bad... THX!
    President:
  • 1,136 Answers
Hi, You can test the defrost heater for coninuity. Unplug the refrigerator and remove the heater. If the heater shows an open circuit, it wil need replaced. The defrost heater is the most common problem with this model. If the heater shows ok, you can test the bi-metal switch for continuity. This switch must be tested while it is cold.
This model has a mother board system rather then a defrost timer. The mother board cost is in the area of $160.00. Make sure the defrost heater or the bi-metal switch are ok before changing the mother board
Please let me know if this helps you at all or if I can assist you further.
Vic
Posted on Jul 29, 2009
  • Victor
    Victor Jul 29, 2009
    Jeff,
    You are very welcome. Thanks for using Fixya.com
    Vic
    Scholar:
  • 117 Answers
I am sure you can do this yourself, Jeff. The test procedure is as follows. Bypass the defrost thermostat (round thingy strapped to evaporater ) place the frig into defrost by manually turning the timer with a screwdriver clockwise untill you hear a loud click. You should be in defrost mode now. If the heater element comes on then you have a bad defrost thermostat. If they do not come on then the element is bad. You can check element for continuity with an ohm meter. The defrost timer rarely goes out but they occasionally do. Wait to see if the timer comes back out of defrost on its own. Takes about five to ten minutes .If it does not, then you can visually inspect timer. There is a sight window on the back of timer that should be spinning if motor is good. Hope this helps
Fridge isn't cold
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
May 28, 2009 | Refrigerators
GE GSS22WGPH WW won't defrost. Already changed heater.
Replace the thermisters located one at bottom of freezer in back which is the most viewable the other is in the top of the freezer by the fan motor they cost about 15.00 apiece.
Mar 29, 2009 | Danby (DAR604BLS) Refrigerator
GE side by Side - dead, again
check defrost timer . plug in and turn timer manualy and see if unit starts running. This means it was in a defrost mode which occurs twice daily.
Feb 21, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Refrigerator model GSS22WGPH whines loudly!
Sounds like the evap fan motor has a bearing going bad. Best to replace. Easy to for anyone who can use a screw or nut driver to do.
Jan 26, 2009 | GE GSH25JFR Side by Side Refrigerator
GE Model GSS22JEMB WW - Defrost heater Bad
yes, remove the freezer panel and defrost with blow dryer. will work for about 5 to 7 days.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
FRESH FOOD COMPARTMENT TOO WARM
it could be a defrost heater problem . the heating cycle is not defrosting the ice that is why your having frost build up. the heater could be damaged, thermosdisc damaged, electronic timer module damaged.try thawing it up by unpluging it for a day or two until there is no more water dripping at the back then try it again, im sure the refrigerator section would cool again for a week or two before it wouyld go back to the same problem. dont forget to bring back the setting to 5 for freezer and 35 for refrigerator in order for the thermostat to work.
Feb 04, 2008 | GE GSS20IEM Side by Side Refrigerator
GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Dec 15, 2007 | GE GSH25JFR Side by Side Refrigerator
Danby (DAR604BLS) Refrigerator Logo
519 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
