Question about Goldstar MV-1526 Microwave Oven
Microwave died Goldstar microwave over heated and died. Is there a reset switch anywhere?
  • 1 more comment
  • merck Dec 09, 2007
    My Goldstar mv-1515 Microwave oven also died. Not sure why. It just suddenly stopped working after a power outage.
    I've checked the main breakers in the house and they've all been reset. Where are the fuses or circuit switches for the microwave. Also the microwave was installed before we moved in, and we can't tell where it plugs into the wall.
  • LouisG Dec 07, 2008
    My MV1502B died, also after a power outage. I took the outside covers and control panel off of the microwave and found the fuse inside above the control panel. The fuse was good, so I took the wiring schematic out from hole in the back of the control panel and checked the circuits with a multimeter (and gave each electrical component a visual check) and found that the turntable motor has to work for the rest of the microwave to function, and that circuit is funky. Off to a repair shop it goes, I don't have the equipment to check IC chips or motors....I'll let you know how it turns out.
  • CrazeeLadee Dec 22, 2008
    Our power went out and now the turn table barely turns and there is smoke or steam in the oven when used. this microwave is just over a year old. I would not recommend to any one.
  • 225 Answers
Check control circuit and thermal protectors and check mains supply,
Posted on Nov 23, 2007
Goldstar GMV1540TB Microwave is not heating. Timer works but the tray is not rotating. If pushing the door up the oven can heat but easy to stop heating.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
Jul 14, 2010 | Goldstar MV-1526 Microwave Oven
Goldstar microwave
Open the cover and look for a fuse. If it's not blown then the power tube (klystron?) is probably fried.
Mar 27, 2009 | Goldstar MV-1526 Microwave Oven
My goldstar mv1501B won't heat anything. What' wrong?
everything works except the heating system what shell i do?
Mar 25, 2009 | Goldstar MV-1501 Microwave Oven
Cubic size of Goldstar MA-1160MW
You can figure the cubic feet with this handy calculator.
Jan 28, 2009 | Goldstar MV-1526 Microwave Oven
Goldstar microwave oven stop heating
microwave ovens have a special Magntron fuse that is inside the body of the microwave its much bigger than a normal fuse, if its blown the microwave wont work.
Jul 30, 2017 | Goldstar Microwave Ovens
I have a over the range microwave and I need the support bracket the holds the unit up. where can I get one. model number is goldstar MV161OWW is there anywhere where i can order? and it there a...
That model should be MV1610WW.
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
Goldstar owner's manuals can be downloaded here.
Sep 25, 2008 | Goldstar Microwave Ovens
GoldStar MH-1357M microwave
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa:
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 17, 2008 | Goldstar MH-1355M Microwave Oven
Goldstar 1500m
The most common causes for this (in order) are a defective door switch, door switch mount, or a bad connection or relay on the control panel. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa:
May 25, 2007 | Goldstar MV-1501 Microwave Oven
Goldstar MV-1526 Microwave Oven Logo
118 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
