Question about NEC INTER WHITEBOARD/WT610E BDL W/WT WALL MOUNT
I need some directions to show me how to use my new whiteboard. right now, I have the board and it is assembled - that is it.
  • 1,305 Answers
Nec has whiteboard tutorial videos on their web...a great place to get up and running.
K
Posted on Jul 29, 2009
What's the feature of an interactive whiteboard
Interactive whiteboards are mainly used to improve quality of the education in classrooms. The use of interactive whiteboard allows instructor to alter the different information present in the board which can even be copied and transferred to the next slide. The data that is present in the board can be clicked on, moved, copied and analyzed. The interactive whiteboard also allows the teacher to write like the any other whiteboard but it also turns the handwritten notes into texts which can be later referred to at any moment of urgency.
Please read the following tutorial to know some features of interactive whiteboards.
https://www.eztalks.com/whiteboard/features-of-interactive-whiteboard.html
Jun 07, 2017 | The Computers & Internet
Tip
Clean difficult marks off your whiteboard
When a message or any marks are left on a whiteboard for longer than 24 hours it becomes very difficult to clean off the board. These marks are difficult but not impossible to get off.
You will need rubbing alcohol and a soft clean cloth. There will be fumes given off by the rubbing alcohol therefore if you are going to be cleaning up a large whiteboard you will want to open a window.
Taking the cloth, apply some rubbing alcohol and rub it on the ink. It is important that you not use a soft cloth because using a brush or abrasive sponge will cause damage to the board.
You might need to apply a little pressure to get really old stains off. If you find that a stain isn't coming off it is possible that it is permanent marker, to get these off you can draw over the marks with a dry erase marker and then wipe it off using a clean cloth that has rubbing alcohol on it.
To avoid getting in these situations, only use dry erase markers and clean the board as soon as you are done with it. Leaving marks on the board will make them harder to get off.
If you are worried about ruining the whiteboard you can always use a whiteboard cleaning solution. For this you just spray the solution on the board, let it sit for five seconds and then wipe it off. The solution will also get rid of any residue left behind by other cleaners that you may have tried to use.
on Feb 10, 2014 | Office Equipment & Supplies
Who invented the whiteboard?
Albert Stallion invented the whiteboard while working for Alliance in the 60's.
Feb 20, 2013 | Office Equipment & Supplies
What is a whiteboard?
A whiteboard is a non-electronic variation of the traditional "rewriteable" schoolroom blackboard, but is white instead of black and of a material that can be written on with colored markers (known as dry erase markers). Dry erase markers are easier to erase than the chalk used on a blackboard (which sometimes requires a wet rag for thorough erasing).
Jan 24, 2013 | Office Equipment & Supplies
Panasonic interactive whiteboard won't project computer
If you'd like to email me at bruce.brassington@n-vest.co.uk I'll be able to help you in more detail. There's a fundamental error to the question here. That is the board in itself will not show the image - your boards is effectively a large flat mouse. A pointing device infact. The peice of equipment that "shows" your PC image is actually the projector. There could be several reasons why your projector isn't showing the image.
1 - is there either a VGA or HDMI cable connected from your laptop/PC to the projector (Sometimes via a wall plate).
2 If 1 is true and the projector is turned on does it show any sort of image? Now there are two thongs you can do from here. a) If you have a laptop check to see if your Video settings are set to clone across to a secondary monitor on most laptops you should hold down Function key and F8 this will toggle through three options Onboard screen remote screen and then both. there could be some lag between the two so hold down fucntio at the same time press F8 then wait a few seconds then go again.
Finally on you projector remote there may be an auto search buttion which will hunt for your PC image by checking each of the Projector inputs in turn. Generally speaking however you should select "Computer 1" or sometimes named as RGB 1
Hope that helps email me if your still having problems.
Aug 21, 2012 | Panasonic Panaboard Ub-T880 Interactive...
Printing Problem
Check sensor (behind panel on the left hand side of the whiteboard screen), to ensure there is nothing there blocking it eg: post-it notes, dust etc. Once cleared, turn the power off and on again and the flashing L should disappear, and you should be able to print again.
Jan 18, 2010 | Panasonic UB-5315 Whiteboard Motherboard
Can not print "L" flaching
"L" is not one of the usual error codes for that whiteboard. you might have a sensor error behind the board. usually dirt and dust are blocking the sensors from reading the board.
Jun 23, 2009 | Panasonic UB-5315 Whiteboard Motherboard
Panasonic PT-LC56E projector
that projector has not been made for some time (7-9 years I believe) so there are probably several thousand hours on the projector, and at about 2500 to 3000 hours your panels start to fail,, sounds like the LCD panels are warping, and you are loosing convergence.
that projector would cost about $500.00 to replace with a newer brighter unit, with a new warranty.
but the "E" means this unit is for europe only, so your prices may vary
Jan 16, 2008 | Panasonic PT-LB10VU Multimedia Projector
NEC INTER WHITEBOARD/WT610E BDL W/WT WALL MOUNT   Logo
74 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
