SIZE, TONAGE tonage of a condenser unit WESTINGHOUSE ( old ) M/N CD030BAY S/N DE01166W & SYYLE 357A782G21.
  • 334 Answers
Hey there, you hace a 2 and a half ton unit there.
seth
Posted on Jul 29, 2009
LRA how to convert in tonage so 10 LRA How many ton and 145 LRA Copland scroll compressor tonage value pleas give me answer
LRA on the data tag stands for "locked rotor amps" and has nothing to do with tonnage. In the model # there should be a number to use. And divide that # by 12 (12,000 btu/ton). So if I had a PFG24H200 it would be the "24"and a 2 ton unit
Jul 06, 2015 | Heating & Cooling
I have a luxaire condenser and its so old that model # is gone but i have the serial# efrm155233 can anyone tell me the tonage?
It is not measured in tons. measured in BTU'S British Thermal units. there is a plate on it telling all this info.
May 15, 2015 | Heating & Cooling
What is the tonage looking for the tonage
It will usually be in the model number on the unit. You will have to supply the model number and possibly the serial number for us to see. Thanks!
Sep 01, 2014 | Heating & Cooling
Whats the tonage of this condenser
Tons of cooling or heating are done by btus.
So 6000 btus is 1/2 a ton,12000 btus is 1 ton.And so on.
You need to get the total btu rating off the unit then figure it out.
Dec 29, 2010 | Heating & Cooling
What is the tonage on a 10aja3601
Hi, the tonnage of your unit is a 3 Ton unit. There are 12,000 btu's per ton of cooling, so your model number has a a36, so 3 x 12 = 36 which is 36 = 3 tons of cooling.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration, Contractor
May 15, 2010 | Weather King 10AJA3601AH Air Conditioner
Age and tonage of carrier 38CKC036350 S/N 2005E40526
its a 3 ton unit manufactured in 2005
the 36 in the model number indicates tonnage 12,000 btu's to a ton times 3 equals 36
the 2005 in the serial indicates year made not sure what month but if i had to guess i'd say May of '05
Thanks Peyton
Mar 13, 2009 | Carrier 38CKC042 Air Conditioner
Central air unit
Make sure you let the blower run for a while after it freezes to make sure there is no more ice. Then run the unit. Check the refrigerant lines the large copper line that has insulation on it should be cold to the touch. If it runs for 10 minuits and is barely cold or warm you are low on refrigerant. If its starts out nice and clod then check your filter and retun ductwork for blockage you should not have noisy return air vents or that can indicate you have too small a return.
Also are the outdoor unit and indoor coil a match? Same tonage?
Is the furnace big enough to handle the tonage? (fan size)
Aug 17, 2008 | Coleman Propane Forced Air Heater...
A\c unit
it cold be different problems.
1-check for any air leaks around the house.
2-check the return box and see if have any opening and seal the holes.
3-check the insulation on the attic or any motor that takes the heat out the attic.
4-check if the unit is under tonage each tonage mean a 400 sf per ton.
5-check if the air handler coil is not dirty and enought air going thru the coil.
6-check the pressure of the condenser unit if have the rigth presures.
7-check thermostat if is set-up right.
Jul 22, 2008 | Heating & Cooling
Air conditon units
the higher the seer the more efficent it is no matter the tonage of the unit
make sure that the tonage is correctly sized for the home rule of thumb is if the home is insulsted properly 600 sq feeet per ton
oversizing creates shot cycles real cool then warm real cool then warm, under size unit runs all the time
May 19, 2008 | Heating & Cooling
Heating & Cooling Logo
174 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
