Question about Gateway 450ROG Notebook
Overheating i have a gateway w340a that over heats, is there pictures of how to take it apart to replace the cooling fan or hard drive
  • dbarber54 Jul 29, 2009
    i have searched for days on how to take the laptop apart and cant seem to find anything that even resembles the lap, got any other suggestions, i hate taking computers in for repair,
  • 748 Answers
Hello
There are documents all over the internet that show you either specifically or marginally what to do. The bigger problem is whether or not this is actually the problem. Is the fan not working - the easiest test is to hold a flame about 6 inches from the fan exit to see if the fan is actually blowing. Now, if the fan is not working you can remove it and get the part number off it. However, has the bad fan allowed more damage to occur. In my shop I've found that a bad fan usually cases the CPU or video chip to also go bad. Support chips can also be the problem along with the hard drive. Good luck
Posted on Jul 29, 2009
For a week now my laptop has been overheating,then will shut itself down,the overheating happens rapidly,all internet connections have slowed exponentiallyy as a result,is it fan related?the laptop is
The laptop will need to be dismantled down to the motherboard level, use a can of compressed air attach straw and blow out all ports, heatsink and fan. It might be a good idea to remove both for closer inspection and several good blast of air for good measure, and check the thermal paste between the heatsink and processor ic has not dried out.
Apr 09, 2012 | Compaq Presario CQ62-112TU
I bouhgt this computer gateway DX4720-03 about 1 year ago. Ever since it keeps locking up evry 15 minutes or so and had to be rebooted. I have updated the BIOs but no difference. I have changed the...
It sounds like CPU is overheating, but other components such as the video card or motherboard chipset can also be overheating. It could be that the cooling fan either has failed or is starting to fail too. Make sure all the fans are spinning and the computer is several inches from wall and that the fan ports are unobstructed. This helps keep the CPU cool. Also try removing and reseating the processor; then reinstall the CPU heatsink with new thermal interface material.
I hope this help you.
Sep 10, 2011 | Gateway DX4720-03 PC Desktop
Overheating issues
Most likely the cause of the overheating is the fan its not running properly though you may hear the fan is running but its not working as it used to, also I suggest try to check where is heat coming out from if its on the Hard drive bay, Memory bay or the CPU area, try to fell also the air vent if you feel coming out from it.
You can try this steps and see if it fix your issue.
1. Follow this link to download Speedfan: http://www.almico.com/speedfan443.exe
2. Open and install Speedfan.
3. Launch Speedfan (this usually takes at least a minute to start).
4. Observe the temperature readings you receive. If your temperature readings are above 60 degrees Celsius or higher, especially when the computer is idling, then your laptop is running too hot. If your laptop temperature is below 60 Celsius, then leave Speedfan running and check on it periodically to see if the laptop is heating up (whether idling or in use).
If you are sure your laptop is overheating, then there are a few stopgap measures that you can employ:
1. Place the laptop on top of a cookie sheet.
2. Place laptop on edge of table so that the air vents on the bottom of the laptop are not being blocked.
3. Use a standing fan and turn it directly on the laptop.
Ways to fix laptop from overheating:
Follow this link for pictures and text explaining the next several steps. http://www.insidemylaptop.com/disassemble-acer-aspire-5610z-laptop/
(The laptop model used in these pictures isn't exactly the same as yours but it should be close. Don't worry, this process isn't that difficult, and you won't have to go any farther than removing the cooling fan.)
1. Turn off laptop, unplug laptop, and remove the battery.
2. Unscrew all panels on the back of the laptop.
3. Remove RAM, Hard drive, and cooling fan by following steps 1-8 on the linked website. Skip removing the DVD drive (step 6).
4. Using compressed air, a vacuum cleaner, or an air pump, blow air into the now open compartments in the back of the laptop.
5. Blow out the dust and dirt in the cooling fan.
6. Reassemble and turn on laptop.
7. Run Speedfan and monitor your temperature.
If your laptop is still running hot, then either employ the stopgap measures or take the laptop to a laptop technician. The laptop technician can take your laptop completely apart, reapply thermal grease to the CPU heatsink, and blow out more dust and dirt.
Good luck, thanks for using FixYa, and please post back to this solution if you have any difficulties.
Apr 25, 2011 | Acer Aspire 4530-5889 Notebook PC
Model: Toshiba Satellite Pro U400-S1001V. The Problem: The touch pad seems to be getting overheated after 30 to 40 minutes of use. Sooner if I play a movie. Please advise.
Most laptops have the hard drive under that area and it could be your hard drive overheating i would get a usb laptop cooler or replace the drive with a 5400 rpm drive so it runs cooler.
Mar 18, 2011 | Toshiba Satellite Pro U400-S1001V Notebook...
My pavilion dv7 is saying "boot device not found". It is saying there is "no hard disk". Any suggestions appreciated.
I would want you to tell me if your Laptop feels hotter than usual.
If so... this in combination with the Boot device not found message means you may have two problems.
1: The hard disc is failing
2: Your cooling fan isn't working
Either one could cause the other to fail. If the hard drive is overheating the cooling fan may not be able to keep it cool enough to function properly,
If the cooling fan isn't working properly or the cooling vents are clogged the hard drive and/or the intergrated circuitry could be overheating
If you do not sense any over heating.
You hard drive may have crashed, if you have another one you can put in the laptop to see if it is recognized.
Would help to have some sort of disc you can boot off of that would recognize a hard drive such as a Linux live CD or Hiren's boot CD or some sort of PE disc. Maybe a Windows install disc. to try and find out the cause.
Good Luck
Jun 26, 2010 | HP Pavilion dv9000z Notebook
Gateway laptop - whirring, buzzing sound
if it's a continuous whirring sound it is most likely the cooling fan. this is normal. as the computer gets older this will get noticably louder as the fan has to run faster to prevent overheating.
Aug 14, 2009 | Gateway Computers & Internet
Gateway FX400S Desktop overheats after about 10 min.
the processor is overheating because the heat sink is bad.
Jun 08, 2009 | Gateway FX400S PC Desktop
Gateway m 1625 operating system not found and its overheating
This means either the operating system on your hard drive has become corrupt and you will need to reinstall your operating system or, more likely, your hard drive has failed and you will need to replace the hard drive and the operating system.
As for your heat issue, use a can of compressed air and blow out all the vents on your laptop. This should help the heat issue; note that it is common for the laptop to feel hot as it is dissipating the heat from inside.
Thanks and please take a moment to give this solution a thumbs up rating with a solved solution as I answered your questions. Thanks.!
Apr 05, 2009 | Gateway T-1625 Notebook
Fan starts runnung fast and everything is frozen
Overheating. Try using canned air and blowing out vents. If you are comfortable with it, take the laptop apart and clean it out. If not, contact a local computer shop that can do it for you. If cleaning doesn't do it, the CPU heatsink will need reseated or the CPU will need replaced.
Jan 15, 2009 | HP (344872-001) Laptop Cooler, Cooling Fan
Overheating
The overheating fan is not controlled by a software, there are three reasons why your fan overheats. First in the hard drive, your fan is not connected properly. Second you need thermal paste to keep the metal part of the fan to stick to the CPU to cool it down. The last thing is that the fan could be dusty and not running as usual.
Sep 08, 2008 | Gateway GX7022E (RBGX7022E) PC Desktop
Gateway 450ROG Notebook Logo
209 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
