Question about Danby Compact Refrigerator DCR-101W
It won't cool. The motor is running. I have the temp set mid-range
  • 27 Answers
If the compressor is running and both pipes on the compressor are warm or hot then it sounds like its out of gas u need to find the leak look for oil residue on the pipe joins if none more than likely the evaporator is leaking
Posted on Jul 29, 2009
Installed new cylinder head temp sensor,why is temp gauge still going all the way to hot?
Is this a ford ? Don't know of any other car maker using cylinder head temp sensor ! Is the cooling system full an no air ? probably a gauge problem !
Sep 29, 2015 | Cars & Trucks
2000 pontiac bonneville blows hot and cold at the same time
Sounds like the blend door motor isn't working.
Jan 20, 2013 | 2000 Pontiac Bonneville
Radiator cooling fans won't work
Just a thought, some makes and models, if you unplug the coolant temp sensor, the fan/s may run? I believe it to be a default setting incase the pcm doesn't see the signal from coolant temp sensor. Any applicable trouble codes? Do you want a wiring diagram for radiator fan?
Jan 27, 2018 | 2007 Pontiac Torrent AWD
Why won't my cooling fan turn on?ive checked the
ive been told that the cooling fan wont come until it gets hotter then mid range
May 09, 2012 | Honda Civic Cars & Trucks
The air conditioner stopped blowing air. It is still too hot for it to have shut off automatically, When I power it down & turn it back on it makes a noise but won't start blowing the cool air. The...
Your going ot have to shut it down and let it deice. remove the filter and replace it or wash it out . this might take a few hours so leave the indoor fan on it will speed thing up a bit. also set the temp to mid range and close all unused rooms off it has to cycle a bit but really my money is a dirty filter and ice.
Jul 19, 2011 | Heating & Cooling
UNIT KEEPS FREEZING UP. WE HAVE THAWED IT OUT MANY TIMES AND SAME THING HAPPENS. IS THERE A RESET BUTTON?
have you checked the filter ? do you have the temp set to low? are you trying to cool to big an area? shut it down again and let it thaw out. set the stat to mid range and trun it back on. close all unused rooms. when the unit cycles of and its still not cool enough turn the tstat down unilt it comes back on and leave it there.. unil the rom temp reaches 72-74 degree. thats the best set point .. you might be about to get it down to 70. but my bet is 1 dirty filter. and set temp to low.
Jul 16, 2011 | Heating & Cooling
What is the operating tempreture at mid range setting & coldest setting
There is no certain temp at mid range . If there was , I'd say 40 degrees . If there was a certain temp , at any setting , then there would be no need for a thermostat , only an on/off switch . The mid-range , is set by the factory , as a normal operating temp , to keep food safe . However , some people like their milk colder , so , they turn the thermostat higher . Like milk warmer , turn down the thermostat . Basically , the settings are a personal preference of the temperature you like your food .
Sep 27, 2009 | KitchenAid Refrigerators
Stops cooling after a few mins
Check the condenser fan motor It probley has bad bearings and over heats and shuts down
after 15 or 20 min of run time
Jul 25, 2009 | Heating & Cooling
The ref/freezer temp control goes from 1 to 5. Is one or 5 the coldest?
Yes, the highest number would be the highest level of cooling. Normally you would set the controls to mid-range and adjust from that point to your satisfaction.
Jun 29, 2008 | LG Refrigerators
Danby Compact Refrigerator DCR-101W Logo
295 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
