Question about Hotpoint Refrigerators
Have a hotpoint model ctx16bazbrwh. its stuck on auto defrost. runs for 8 hrs. which part do i need to replace?
    Scholar:
  • 117 Answers
You need to replace the defrost timer.It is usaully found next to the thermostat control in frig compartment. You will have to remove cover and two mount screws to replace. Hope this helps
Posted on Jul 29, 2009
Sidebyside kenmore works great for 12 hr. then seems to go into defrost mode and won't cool unless i unplug for 6 to 8 hrs plug it back in and it works fine for 24 hrs then repeats
Larry I tried to write the solution here but it would not send. Click Here=> Kenmore Appliance Model Number Locator and examples Your solution is at top and center of that web page. Let me know if helpful or if you have more questions, Thank You, Sea Breeze
Nov 16, 2011 | Refrigerators
What is best way to defrost hotpoint future rf175b
The model number you gave is not valid. To defrost a fridge you have two options.
Is this a manual defrost? If so boil pot of water and set on rack inside the freezer. You will have to remove big chunks of ice.
Auto defrost fridges. Option 1- Unplug fridge open doors and leave for 24-48 hrs. A bit messy with this so have towels around fridge to soak up water.Option 2- Unplug fridge remove access panel on back wall inside freezer. Take hair dryer and melt all the ice inside on the coils. If you have an ice block you have a problem replace bi metal/efrost thermistat. Heater and/or defrost timer may also be out.
If you have an Ice block on auto defrost models always change the bi metal because they get warped usually inside and ruin them. Test heat with continuity tester and defrost timer by manually advanceing just before shutdown time and letting run through cycle. Should stay in defrost between 8 and 30 minutes.
If you need further assistance or have any questions please comment me back.
Jul 27, 2011 | Refrigerators
I purchased a Sears Counter Craft Crock Watcher crock pot at an Estate Sale, but there is no instruction booklet. It has low, high, and auto shift on the dial. Can you help provide some instructions for...
From a couple of different slow cooker manuals - most I looked at are the same:
When in the AUTO setting, the slow cooker will begin cooking on HIGH and then will shift to LOW after approximately 2 hours of cooking time. AUTO setting does not turn off the unit. Other favorite recipes may be adapted to the slow cooker. All times listed in the following chart are approximate and should serve only as cooking guidelines.
Regular Cooking Slow Cooker Cooking Times
1 (Low) 2 (High) AUTO
30 minutes 6-8 hrs. 3-4 hrs. 5-7 hrs.
35-60 minutes 8-10 hrs. 5-6 hrs. 6-8 hrs.
1-3 hours 10-12 hrs. 7-8 hrs. 8-10 hrs.
Sep 16, 2010 | Vacuums
Does this fridge have auto defrost?
all friges or units like this one are auto defrost . the defrost system on most of todays units are controled by aditive defrost systems . but the do fail . generaly the frig will defrost every 8 hr's of comp run time . . this could be every 8 hrs or every 16 . just depends on how hot it is and how often you get in frig . . mm
Aug 25, 2010 | Kenmore 63222 / 63224 Bottom Freezer...
My Hotpoint ffa40x fridge freezerhas a problem,the freezer gets a build up of ice inside the freezer under the bottom drawer which makes the drawer stuck fast until i cut through the ice to release it.This...
your auto defrost heater is not working or you need to defrost it yourself ... turn unit off for a day with doors open. ***********PUT YOUR FOOD IN SOME ONES ELSES FRIDGE ************
Dec 30, 2009 | Hotpoint Refrigerators
Ge refrigertor side by side,the upper part of both side is not cooling well,and the bottom of both side is very cold,what is causing it,how can u help me fix it ?
TWO THINGS TO CHECK FOR.1ST. IS THE FAN IN FREEZER WORKING?IF NOT MAKE SURE NO ICE HAS BUILT UP AROUND IT.IF NOT REPLACE FAN MOTOR.2ND DO YOU HAVE FROST BUILDING UP ON REAR WALL OF FREEZER ?IF SO AUTO DEFROST IS NOT WORKING AND YOU WILL NEED A HEATER OR DEFROST TSTAT.YOU CAN DEFROST IT MANUALLY 6-8 HRS WITH DOORS OPEN AND UNIT WILL WORK FOR ABOUT A WEEK TILL ICE BUILDS UP AGAIN
Dec 12, 2009 | GE GTS22KBM Top Freezer Refrigerator
Orange glow coming from inside freezer back of freezer warm
HI. that glow will be the defrost element. If that element continues to glow for a long period of time, longer than an hour, this will indicate that there are issues that concern the integrity of the defrost timer, or adaptive defrost control board. I would advise to shut off the power to the unit for five minutes. this will rest all the control boards that exist in the units structure. re-introduce the power to the unit, after the five minutes are up. If the element continues to glow, continuously, this will confirm that the defrost module has failed.(stuck in the defrost position). replace the either the defrost timer, or adaptive defrost control board(depending on the model), if the reset did not correct the issue.
Nov 14, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
Hotpoint refrigerator freezer(top) mod ctx18bacerww not cooling/freezing correctly. removed inside back panel in freezer compartment,found coils partially covered in frost, fan not blowing.. flicked fan...
Hi, fan may have stuck, but you could have a defrost problem, check defrost heater, thermodisc(defrost thermostat) and defrost timer. or excessive moisture, if your days are hot, or if you put hot foods in ref. could result in excessive ice build up. you can manually defrost it, by unpluging ref. for couple of hrs, until all ice melted. then restart. you make get excessive water on floor. be prepared.
Aug 02, 2009 | Refrigerators
Hotpoint soultion
If defrost timer is clockworks type, manually force timer into run mode using flat blade screwdriver. If forcing works, replace defrost timer ($25.00 approx).
Jul 21, 2008 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
