Question about Behringer Audio Players & Recorders
I have a Behringer 2642a mixer and a Roland 201 Space echo. How do I connect the echo into the mixer? There are so many input and outputs on the back of the mixer! Pete
  • 29 Answers
This is relatively easy. All you need are two stereo RCA cables and RCA to 1/4" adapters. Plug the 1/4" adapters in to the FX1 send jacks on your mixer ( 1 only if you want mono echo, 1 & 2 if you want stereo ), and the other 1/4" adapters into your echo units in and output jacks - of course if you have 1/4" cables, you won't need the adapters.
The output of your echo unit then plugs into the FX return jacks on your mixer. Set your FX1 and FX2 send controls on the channels you want echo up to the 12 o'clock position and turn up the FX send masters also. You should see some level indication on your echo unit. The turn up the FX return controls on your mixer to the extent you want echo.
You may have to do some adjusting of all controls on the mixer and echo unit to get just the right amount of "dry" and "wet" sound.
Posted on Aug 06, 2009
Can i use karaoke mic in harman avr 245 ?
No. The 245 doesn't have a microphone input. Besides, the speakers for a home surround sound system are a bit too delicate for the distortion levels generated by karaoke.
Here's a $300 speaker (yes, $300 for a single speaker) wrecked from teens doing karaoke. They then bust it more messing around trying to push the tweeter cone together so the crack wouldn't be so noticeable
If you still want to go ahead with the idea then you'll need some other bits of gear. For simplicity sake I'd recommend a karaoke CD+G player. It will have mic inputs, vocal echo, and take care of putting the works up on screen.
The alternative is a mixer with effects (echo, reverb) - Cheap is Behringer Xenyx 1202FX
and a source device for music and graphics. This could be your PC, but you'll then need to go trawling for karaoke files and you'll need some software to play them and do the words. Sax & Dotty is pretty good software.
The PC sound needs to be connected to the mixer in a stereo channel. The mic goes in mono on a mic channel. The output of the mixer goes to the AVR on an AUX input.
Behringer XENYX 1202FX
Sep 07, 2014 | Harman Kardon Audio Players & Recorders
How dso I connect a seperate mixer to a Behringer B215D powered speaker
Use the two balanced outputs, intot he inputs on the back of the speaker, 1/4 inch jack should fit.
Alternativly you can do the same via xlr, for a balanced connection.
Jul 28, 2014 | Behringer Xenyx 1202 12-input 2-bus Mixer...
Where are the Amplifier inputs on a Behringer usb 2222 mixer
If you need a better answer post again with more details. You can connect an amplifier to any of the inputs assuming it has compatible output levels. In your case I am assuming you want to connect to a power amplifier, so connect to the Main Outputs.
This mixer does not drive speakers!
Nov 10, 2012 | Behringer Xenyx 2222FX 22 Input Mixer
I don't know how to use behringer feedback destroyer DSP1124p
Determine where in the mixer's signal path to connect the unit. Your options are:
1. One or two individual microphone channels via the mixer's CHANNEL INSERT in/out jacks.
2. The monitor mix output via the mixer's MONITOR OUT jacks.
3. The main mix output via the mixer's MAIN OUT jacks.
  • 2 Connect a balanced cable with the appropriate connectors from CHANNEL INSERT OUT jacks on the desired mixer channel to INPUT RIGHT or LEFT on the Feedback Destroyer's back panel for individual microphone channels. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to that mixer channel's CHANNEL INSERT IN jack.
  • 3 Connect a balanced cable with the appropriate connectors from the mixer's MONITOR OUT jacks to the INPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel for the monitor signal path. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to the monitor amplifier INPUT jack or amplified monitor speaker INPUT jacks.
  • 4 Connect a balanced cable with the appropriate connectors from the mixer's MAIN OUT jacks to the INPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel for the main mix (FOH) signal path. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to the main amplifier INPUT jack or amplified house speaker INPUT jacks.
  • Oct 17, 2011 | Behringer Audio Players & Recorders
    I have the Behringer Eurorack MX 2642A. Over 6 years old. The right main mix output sometimes works great and sometimes gets very quiet and distorted. Is it time for a new mixer or is there possibly a...
    It sounds like one of the output devices is going bad, ie., output transistor, capacitor, resistor or maybe just a bad connection on one of the above menitoned items. One other problem which causes this would be the main or sub volume slider or pot is wearing out and needs to be replaced.It would definately be worth your while to have a technician trace down and fix the problem on this board. Hope this helps.
    Feb 10, 2011 | Behringer DJx700 5-Channel Pro DJ Mixer...
    How to connect mixer to a crown power base 2 amp and speakers
    just use the main left and right outputs of the behringer to run xlr (3 prong balanced) to 1/4 inch (looks like a big headphone plug) cables into the inputs of the crown amp. the mixer has the xlr outputs and the amp has 1/4 inch inputrs, sop the cables will have to reflect that on both ends. run the outputs of the amp (rca outputs, i believe, you may have to get a rca plug to 1/4 inch jack adapter, and then use a 1/4 inch speaker cable) to the inputs of the speakers, again, the amp has rca outputs and the speakers will likely have 1/4 inputs, so you will have to address that wil an adapter. have each speaker in its own channel.
    Nov 22, 2010 | Behringer *new* Behringer X1222 16-input...
    Iam trying to make my behringerXENYX 1204fx mixer, / connect
    I have trouble my new behringer xenyx 1204FX VU led dead , like new VU it must play , how to repair this unit VU light
    Mar 13, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
    How would you connect a Roland Space Echo direct into a Behringer 2642a mixing desk? Have tryed all inputs/outputs with nothing. Could this be because the mixing desk has ballanced ins/outs and the Roland...
    In order for this to work, you need what is called an "insert" cable. This will have a balanced 1/4" connector on one end and 2 1/4" mono-connectors on the other. The balanced connector is also known as a TRS connector (Tip,Ring,Sleeve). You should have "insert" jacks on the mixer. Place the balanced connector into whatever insert you wish to use (usually this is inserted into the main insert). One of the 1/4 plugs is for input, one for output. I don't know which is which for your specific unit, you will have to experiment. Keep us posted. Dan
    Jun 12, 2009 | Behringer Audio Players & Recorders
    Echo into mixer
    I think the Echo's output goes into the mixer's input.You should be using one's output into other's input...that's how things work.If you r talking about both the system's input then they won't work with each other. Other thing is that if it's mono then there r cable available for the use which transfers mono to stereo input and vice-versa.
    Jun 07, 2009 | Audio Players & Recorders
    163 people viewed this question
    Top Behringer Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Alvan Dawkins
    Alvan Dawkins
    Level 1 Expert
    Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
