Question about HP Compaq WF1907 Monitor
I cant get the monitors resolutin at 1440x900-60Hz and the monitor keeps going to sleep
I need help i have tryed to do everything i can and i cant fix it
  • Anonymous Feb 28, 2008
    Can't get my monitor at 1440X900 either....I've installed the driver from the website already (used the disk that it came with too to install driver)
  • Martinho_25 Aug 08, 2008
    i have system broard intel D945 GVSR P 4 i formated it but cannt set my resolution above 4 bits
    can anyone tel me wat i should do
Your graphics card doesnt support the resolution that your monitors native resolution is set at.
btw, what graphics card are you using?
Posted on Mar 22, 2008
How do i stop my monitor from going into sleep mode
A couple of possibilities here. Try using a different cable first to rule out the cable being the problem.
If that doesnt work, try using a different monitor if available.
If that fixed the problem then its your monitor.
If it didnt, then its your computer.
let me know what you find.
Sep 26, 2014 | ASUS Computers & Internet
How do I fix the error no vga input signal no dvi input signal monitor going to sleep
Check if you VGA is properly settled in the PCI slot. Try to take it out, clean the slot for dust.
If that doesn't help, it is well possible that you VGA is not working any more.
Jun 10, 2012 | HP Computers & Internet
I have a HP vs17 monitor that keeps going to sleep. It will flash to windows when I first start and immediately goes into sleep mode. When this first happened, I had managed to make sure any sleep modes,...
trixieb1, It's NOT going to sleep mode. Use warranty if possible!! If that not option you will need to read about "cold-cathode-fluorescent-lamps" and the voltage inverters that power them. Learn to do flashlight test when screen goes to black or blank n black!!! Read my fixya profile and those of other ccfl back-lit lcd monitor technicians. We already know what is wrong with your unit. And It is a VERY big problem for all LCD monitor manufacturers. Just do some reading before you do anything else. Good luck with the repair. 12fixlouie
Mar 31, 2010 | HP w2207 Monitor
My computer says its our of range to adjust settings.
right click on the desktop click on screen setup and click on sleep mode add 20 minutes to it, then right click on the desk top and go to properties choose 32 bit and 900 dpi and click ok see if that's better if it is click ok, need more info or that does not work just re-post a comment and I will get back to you..
Jun 26, 2009 | Sony SDM-HS73P 17" LCD Monitor
Can't switch on monitor screen
You must go into the BIOS of you computer and turn off the sleep mode and also in windows. Disconnect the monitor and power it on without hooking it up to the computer. If the monitor turn on and is working , then hook it up to the computer and try with with the sleep controls off to see if it works correctly.If this works you must check the owners manuals of the motherboard and monitor for the correct operation of the sleep mode functions.Then reinstall the sleep mode operation and see if everything works correctly. If the monitor fails to work. Try the monitor on another computer and see if it will function. If all this fails to get the monitor working , then you will need to have the monitor tested in a service center to find the problem and have it repaired. You should also check your computer on another monitor just to maker sure you don not have a problem with the computer too. Hope this helps you with your problem.
May 12, 2009 | Mag Innovision LT776s 17" LCD Monitor
Going to Sleep
Due to the power surge, it is highly possible that the monitor was given a boot by your computer on it's way out.
This will short out a very small transistor inside the monitor on the video board and in turn, then monitor cannot see that there is a signal so goes to sleep.
If you get brave enough to venture inside the screen, then check near the cable input. The transistors are only around 3mm and have 3 legs (two one side and one in the middle on the other).
If you find anything like that burnt (get a magnifying glass) then replacing the board is the easiest option. Just don't be tempted to wipe the board before you look at everything very closely, you may wipe away the tiny bit of evidence you are looking for.
Hope it helps =)
Feb 12, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
Stuck in "sleep mode"
a possible fix would be to go into the bios and select "standard settings" or something close to that statement,then re-boot the system
hope this will help
good luck
Oct 17, 2007 | HP Pavilion F1703 17" LCD Monitor
HP Compaq WF1907 Monitor Logo
250 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
