Question about Weber Grilling
Can not adjust flame.
We purchased a used Weber grill without any manuals. This model is set up to use disposable propane bottles. When you hook up a bottle and try to light the grill it only lights up like a pilot light by the igniter. After taping on the burner finally the whole burner lights but never more than just small blue flames. There doesn't seem to be any way to increase the flame no mater which way you turn the regulator knob. Do you think that we may need a new regulator or is there some air to gas adjustment that we can adjust.
    Problem Solver:
  • 8 Answers
It sounds like the grill just needs a good cleaning, plus when you do clean it check that the burner tubes and orfaces are free of any debris.
The orface is a tiny hole inside a small brass threaded insert where the gas blows through into the burner tubes, it is very critical that this is clear as well as the burner tubes.
Posted on Jul 29, 2009
When I turn on the grill the gas flame does not go beyond about 1/3 of the way along the connector tube to the rear burner.
It could be a partially blocked gas jet or insufficient gas pressure is reaching the jet.
Clearly the pipes and valve should be checked if cleaning the jet doesn't provide a cure.
It is a good idea to compare the jet size and air bleed size with specifications. If it is set up for propane and being used with butane it will display the inefficiency you described.
There have been a few appliances designed for use with bottled gas that weren't intended to be used with a pressure regulator and lots of propane appliances that need a higher pressure than the standard fixed regulator can supply and an adjustable regulator should be used instead.
Sep 04, 2015 | Weber Genesis Silver B Grill
Hooked up new bottle,will not get hot,low flame
Turn off burners. Turn off gas. Disconnect regulator from propane tank. Reconnect regulator. Turn on burners Turn off burners. Turn on propane SLOWLY. Turn on burner and ignite.
Aug 18, 2014 | Weber Genesis E-310 Gas Grill
I have Weber Genisi Silver model 8133 which has been hook up to a natural gas line. We have moved to a new location and can only use a propane tank hook up. Do I need a adaption for conversion to...
Unfortunately, you cannot use your Natural Gas Grill on Propane Gas. In addition, there is no conversion kit for Weber Grills. That's why they make two different gas models. Conversion of a grill becomes a safety issue. As each model Weber grill is tested and approved only for the specific gas type. Attempts to convert it voids that approval.
I'm sorry I didn't have better news. Thanks for choosing FixYa.
Jul 27, 2011 | Weber Genesis Silver B Grill
Regulator vibration
If you are using a disposable propane bottle, make sure it is not horizontal when it's hooked up. It should be at a 45 degree angle or higher. You may be getting liquid out of the bottle (instead of vapor) at the angle you have it hooked up. Hope this helps. Douglas
Jun 06, 2010 | Weber Baby Q Grill
Hi, I have just bought a Weber 100 BBQ. I have a
You have a couple of questions. In order: 1. Flame may not be visible because it burns very clean. 2. When they say 'turn gas off', they actually mean 'turn gas tank off'. 3. It's not necessary to remove the tank after every use. Just make sure the gas valve is off and the entire grill and tank are covered. I do remove the tank, and store it in an outdoor shed during the winter.
May 18, 2010 | Grilling
Weber grill three burner. New tank of propane but
The new style2_bing.gif OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This should solve your problem
IF not you might want to remove the cap (white) on your regulator and try slowly adjusting the regulator, make small adjustments and try the BBQ My Weber if I set the front and back burners to MED I get right at 350 degrees in 60 degree outdoor temps. Adjusting the regulator will take some time to get it right but If it is not your tank it is most likely your regulator out of adjustment
Mar 29, 2010 | Weber Genesis Silver B Grill
I just hooked up an LPG bottle and hose to my Weber Q, and when I light it, the flame is very weak. In fact, the flame extinguishes after about 10 seconds. I can't seem to get the proper flow of gas to...
if using the adapter hose for large tank weber has had problems with hose call weber and get new one or call bbq galore and ask for a 4ft. adapter hose 214-696-0030
Aug 10, 2009 | Weber Q Grill
Burners will not light
Check to see if the bottle is full or empty ? could be a number of problems . Bottle empty ? bottle wasn't purged properly or you may have spiders that have nested in the propane lines which is a common problem.
Jul 26, 2009 | Grilling
Grilling Logo
256 people viewed this question
Top Weber Grilling Experts
paulcarew
Dan Webster
Dan Webster
Treefrog15
Treefrog15
Are you a Weber Grilling Expert? Answer questions, earn points and help others
